    Mặc định 1200 cần giúp đở
    em có cây 1200 rớt nước mất nguồn , đã vệ sinh kĩ máy có nguồn nhưng báo contact sẻvice em đã làm lại nguồn + u nhưng k hết chạy ct máy báo lỗi ae xem xem
    MCU ID: 0x2292
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.91
    27-03-09
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: WIN:MYKS:04
    ST7507
    PPM version: r $ÓÊ…ÖPñħØKDW³Šå–0EfY‘„Ç ˜<kjw
    ªË¶
    ADSP SW version: no NAI version
    Production serial number: IGR250012
    Product code: 0574502
    Module code: 0203402
    Basic production code: 0571402
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356858029601953
    IMEI spare to net: 3A 65 58 08 92 06 91 05
    IMEI SV to net: 33 65 58 08 92 06 91 75 F0
    Master Code: 7344311721
    Phone type: RH-99, Software version: 5.91, Language Pack: ªË¶
    User code: ÿ#
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code: 0574502
    Checking path: \Products\RH-99\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.910
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.91mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.91mr
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.910
    Booting phone...
    Phone didn't answer to request flash routine!
    Causes:
    1. UPP damaged -> replace UPP
    MCU ID: 0xEEEE
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84F6AE7DA9FCBBB10DAA0B656F
    MSID decoded: 3E4EBAE9009312A5A8000000
    FAID: 6C22526CDF43CF1BFCB2AF16
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 19 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.91mr
    Booting phone...
    Causes:
    MCU ID: 0xEEEE
    Failed! Aborting!
    FAILED
    dùm cai loock của nó em cảm ơn
    khách đang chờ mấy bác giúp em với
    Thành viên tích cực BUIVANCHUNG's Avatar
    Kim Anh Mobile Đồng Nai
    con này bạn lam sw không được,thì thay upp là giải pháp hy vọng nhât
    Thành viên tích cực linhanh_919's Avatar
    Dec 2008
    kinh bắc
    MCU ID: 0xEEEE
    Failed! Aborting! chẳng nhìn thấy u đâu cả chắc ra đi mãi ko bao giờ trở lại rồi
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    thay con u cho nó đi anh
    Thành viên mới kt_0986031070's Avatar
    ban đem qua mt quất 1 phát len ngay ah sau đó đem lai jaf unlock la ok
    Thành viên tích cực hunggsm's Avatar
    đúng đó bạn à bạn mang qua ráp unlock cho nó phát
    Thành viên mới thanhtuanvn's Avatar
    Dec 2007
    Trích Được post bởi kt_0986031070 Xem bài viết
    cái này coi bộ "tào lao mế lao nè" cái ji mà sàng qua sàng lại kinh thế.vậy =>đối với nhửng kon máy "mắc tiền" như 1200 anh em kỉ thuật kòn đau đầu hơn bb5????????:rolleyes:
    Dec 2007
    Trích Được post bởi hunggsm Xem bài viết
    kòn cái bác này nửa cái box "ráp" bán nhiu cái zại.chưa nhận cpu như trên người ta phân tích kìa.thấy chưa,múc cpu đi ngồi niệm chú làm ji nửa khổ chủ
  1. Trả lời: 3
    Bài viết cuối: 29-11-2012, 12:30
  2. xem giúp em cái log 1200
    By bomnokia in forum DCT4 - WD2
    Bài viết cuối: 23-04-2012, 07:17
  3. Xin giúp log 1200
    By Lão_Đại in forum DCT4 - WD2
    Bài viết cuối: 27-07-2011, 17:33
  4. 1200 cần giúp
    By 990608 in forum DCT4 - WD2
    Bài viết cuối: 08-01-2010, 13:10
  5. 1200 cần anh wm giúp ỡ
    By vietluan in forum DCT4 - WD2
    Bài viết cuối: 13-12-2009, 09:55
