Release note:
Support for "StandAlone BB5 SL20 RPL" unlock (button SL2 RPL)
Some bug fixed
"StandAlone BB5 SL20 RPL" module activation is obtained using MT Tool v3.14 ( button Check Activations)
Once activated box will not connect to server for generating RPL for SL20 phones (RAP3 and RAPIDO)
AutoUnlock support for 'SL20 RPL': in griffin.ini in [interface_options] if there is entry 'autostart=1'
MT Box will enter in auto mode when you click 'sl20 rpl' in this mode,
MT should detect when phone is connected, unlock it with RPL and then prompt you to disconnect phone.
All you need to do to unlock another phone is just connect it to MT Box. When you want to terminate "AutoUnlock" mode, click the button on the 'message box' that is shown in MT.
Supported all models with HASH 9DDBF:
3600 Slide (RM-352)
5220 Xpress music (RM-411/410)
6600 Fold (RM-325)
6600 Slide (RM-414)
6600i Slide (RM-570)
7210 Supernova (RM-436)
7310 Supernova (RM-379/378)
7510a Supernova (RM-398/399)
7610s (RM-354)
6790s-1c (RM-599)
6790s-1b (RM-492)
Accounts which can be used for this activation:
GT server full access accounts
MT PRO accounts
SL20 accounts
Credits needed for activation:
If box already activated for BB5+ - 20 credits
If box has no BB5+ module activated - 80 credits
How to activate "StandAlone BB5 SL20 RPL" module for MT Box Nokia:
Visit the link: BB5 SL20 RPL(pin) activations
Enter your MT Box serial number – SN
Enter your GT server or MT PRO user name
Enter your GT server or MT PRO password
Select – I want to use this server account to enable MT-Box serial number specified above for StandAlone BB5 SL20 RPL Activation!
Click to Activate BB5 SL20 RPL button
Download MT Tool
Connect your MT box to USB
Run MT Tool.exe from directory where is MTB_NK.EXE (i.e. where is located file griffin.ini in most cases C:\Program Files\GriffinTeam\MT-box) and click button ‘Update’.
Do not use MT Box update tool v3.13 or older because will not work
How to activate "StandAlone BB5 SL20 RPL" module for MT Box Nokia using "Box Account" (SL20) credits:
Download and install MT box update tool
Start MT box update tool v3.14 (do not use older version because will not work)
Press INFO button, software will read your MT box information
Press "Check Activation" button
Software will connect to GT server and show you all available module activations
Select desired module activation and press OK button
If you have enough credits on your "Box Account" (credits info is shown on top of window) activation will be done in just few seconds
If you does not have enough credits on your "Box Account" need to order it from your reseller
How to order "Box Account" credits:
Press GET SN button, box sn is now copied to clipboard
Paste your MT box serial number to order form, email or IM (depend which way your reseller use for "Box Credits" order)
Reseller need to inform you when your MT box is recharged with new amount of credits or you can check by your self by pressing Info button in MT tool
Dowload:
MTB NK v2.10.exe
MTB NK setup v2.10
MT Box update tool v3.14
