Unlock iPhone 3.1.3 3G 3GS with ultrasn0w
Sn0wbreeze 3.1.3 for Windows brings jailbreak for iPhone 2G, 3G and iPhone 3GS (older bootroms only) which can preserve your older baseband while upgrading you to the latest iPhone OS 3.1.3 firmware. This means that you can now unlock your iPhone 3G and iPhone 3GS using the current version of ultrasn0w (for 04.26.08 baseband) or blacksn0w (for 05.11.07 baseband) as they both are compatible to work with the respective older baseband versions.
Simply follow the simply step by step guide posted below for unlocking iPhone 3G and iPhone 3GS on 3.1.3 firmware using. iPhone 2G users should follow the guide posted here.
Step 1: First follow the complete step by step guide posted here to jailbreak iPhone 3GS or iPhone 3G on iPhone OS 3.1.3 firmware. Guide for iPhone 2G with redsn0w can be found here.
Step 2: Once your iPhone is jailbroken, start “Cydia” on your iPhone and touch on “Manage” tab on the bottom. Now touch on “Sources” as seen in the screenshot below:
Note: T-Mobile users should disable 3G before installing ultrasn0w.
Step 3: Touch on “Edit” and then on “Add”. You will be prompted to enter a url source as seen in the screenshot below. Type “http://repo666.ultrasn0w.com” and touch on “Add Source”.
Cydia will now automatically update your sources by following a series of automated steps.
Step 4: Once the repository has been added successfully, Search for “ultrasn0w” in Cydia and install this application. The latest version 0.92 of this app will automatically unlock your iPhone so that you can use it with any carrier with proper carrier name/logo.
Step 5: Now simply restart your iPhone. Voila! You should now have a fully unlocked iPhone 3G/3GS on firmware 3.1.3.
			 Unlock iPhone 3.1.3 3G 3GS with ultrasn0wUnlock iPhone 3.1.3 3G 3GS with ultrasn0w         Sn0wbreeze 3.1.3 for Windows
