Kết quả 1 tới 2 của 2
    Thành viên mới vanchien89's Avatar
    Mặc định 1200 cần các a giúp gấp
    các a kiểm tra dùm em với
    Languages in ppm: English,Filipino,Vietnamase
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: \Products\RH-99\rh99_05.710
    Booting phone...
    MCU ID: 0x2292
    BOOT file: D:\JAF\Flash\u3_2nd.fia
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x72888900
    Flash loader is D:\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 84C943FD594441E7A5FB9A8C49
    MSID decoded: 3E4EBAE900184194AA000000
    FAID: B165FCE6A6D49248B779E7B4
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 37 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 19 seconds...
    Restarting MCU...
    PPM: \Products\RH-99\rh99_05.71md
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: 2D 5A B2 10 09 BE 09 00 44 50 01 60 40 2A 64 04
    Loader is ready...
    MSID: 84F40C6F50598B323C537B1000
    MSID decoded: 3E4EBAE900184194A8000000
    FAID: 33A6D4F2156A75D52CF5C07A
    Erasing PPM...
    Found 2 interval(s) to erase
    Writing...
    Restarting MCU...
    CNT: \Products\RH-99\rh990_nai5.71md
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84D789C2865405B784EC5CA936
    MSID decoded: 3E4EBAE900184194A9000000
    FAID: 0168DBC778857B0C811A39EF
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 6 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    thank các a nhiu
    Yêu cầu : Edit lại cái Tiêu đề cho rỏ ràng. Sau 6h, tiêu này không thay đổi thì sẽ đưa vào thùng rác.
    xóa full flash chạy lại coi sao nha bạn
  1. Trả lời: 3
    Bài viết cuối: 29-11-2012, 12:30
  2. 1200 xin giúp
    By khanhnokia in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 12-03-2011, 14:21
  3. n-1200 hỏng đèn,xin giúp đỡ!!
    By hienbeomobile in forum DCT4 - WD2
    Bài viết cuối: 07-09-2009, 23:12
  4. 1200 cần giúp
    By mobichat in forum DCT4 - WD2
    Bài viết cuối: 22-07-2008, 23:11
  5. 1200 bệnh lạ cân giúp
    By giakhang84 in forum DCT4 - WD2
    Bài viết cuối: 22-07-2008, 00:26
