Free unlock kp500 kp501 kp502
[x] Flash phone with a unbranded Software Version
[x] once finished enter 2945#*71001#
[x] NCK is asked and enter 00000000
[x] Phone Unlocked
Phone must be without sim card.
In this tutorial you will see how to flash lg cookie with new firmware.
1.) BACKUP
- First off all you should make a backup of your phone files (contacts, messages ...) because after flashing, all the files saved on the phone will be erased. I recommend that you use LG PC SuiteII.
- Dont forget to unplug your phone.
2.)DOWNLOAD GSMULTI AND FIRMWARE
FIRMWARE LG KP500 KP500AT-00-V10n-DEC-17-2008 (v10N) NEW!
Unknown Request - FileFactory
FLASHER LG - MultiGSM ver 3.0 + kp500 .dll file
3.)INSTALL THE SOFTWARE AND DRIVERS - DRIVERS WORKS ONLY ON XP WINDOWS
(Don't connect your phone on computer yet)
Downloaded files should be un-ziped (I unziped them in one folder which i made it on desktop)
You got next files:
program
- SETUP_GSMULTI_V30
- KP500_081002.dll
firmware
- KP500AT-00-V10n-CIS-XXX-DEC-17-2008
- KP500AT-00-V10n-CIS-XXX-DEC-17-2008.bin.mbn
3.1.) Install GSMULTI (SETUP_GSMULTI_V30). The icon will shows on your desktop otherwise the program install on C disk, folder GSMULTI
- start GSMULTI
- select: Settings/Configuration
- put .dll file and firmware file in and choose USB then click OK and close program
3.2.)Install DRIVERS (INFINEON and TI_NEPTUNE)
- First install INFINEON
- Second TI_NEPTUNE
4.) PREPARE AND CONNECT YOUR PHONE
- Now u take a phone (shut it down) and remove, BATTERY, SIM CARD and MEMORY CARD then
- conect it with your USB cable to computer (I suggest that u connect only in one USB port on computer)
- wait about one minute that comuputer recognize new device
5.) USBMap PROGRAM
- Run program USBMap_V01 (which can be found in C:\GSMULTI)
- Select INFINEON and then click MAPPING START
-WAIT (about one minute) that USBMAP will find USB port where is the phone connected
- When the port will be found click on (select it) and press SAVE&EXIT
6.)MAIN PART - FLASHING
- Run GSMULTI program (shourtcut is in your desktop)
- Check if settings/configuration are the same like we set it before (otherwise look step 3.1.)
- Now its everything ready to start flashing
- Check MODEL and SW VERSION and if that is correct just click START and wait until the program finished
4shared.com SETUP_GSMULTI_V30 et dll kp500 ks360 ProvinsPC.rar
			 Unlock Free  kp500 kp501 kp502
