Kết quả 1 tới 10 của 19
    Thành viên tích cực hoangthanhmobilee's Avatar
    mytho. tien giang
    Cool Giúp em cây N95 2G imel bị rổng
    Using device: J.A.F, FW ver: 01.B2
    Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
    APE Data :
    SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
    ASIC MODE ID: 00
    PUBLIC ID: 73E429697BB74F1492695316970B90E1F2DB1206
    ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 11E0000CD36B005840D1411EDB90B4E50BF48C29
    ASIC MODE ID: 00
    ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
    ROM ID: A8C1D6713E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
    Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
    FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
    ExtDEVC: FFFF 0000 - 0000 0000
    Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
    RAP PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
    SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
    Supported APE Ids: 24200703, 24200704, 24200705, 24200706
    FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
    ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
    Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
    APE PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
    Original Imei: Empty
    Original Product code: Empty
    Phone not responding !
    máy ban dầu xài bình thường nhưng bị lổi camera, e sx4 nhưng nó báo lổi nên xóa flash rồi nạp lại thì nó báo rổng imel,có backup lại hết rồi, 6300,6280,N70... e làm ok hết nhưng chỉ bị cây này!!!! e dùng MT,MXKEY,JAF,HWK. Ai có kinh nhiệm xin giúp. Thanks
    yahoo: hoangthanhmobilee
    DT : 0909168878
    Thành viên mới khoanmobile92's Avatar
    Mar 2010
    phai mua lok ve ma chem meo lai thoi ban oi may bi mat neo roi
    mytho. tien giang
    Imei: 35483501694032
    Restoring RF/BB DATA from backup ...
    Error unable to detect product !
    Updating WARRANTY ...error 0x0
    Updating PROD ...error 0x0
    Updating BT ...error 0x0
    Certificate programmed successfully !
    khi write thi MXKEY nó báo lổi này, dể e dùng MT rồi dưa log lên A,E rtham khảo giúp
    DT : 0909168878
    mytho. tien giang
    OX: 001f3d8b7c - Nokia Flash/Repair v1.60
    Box: CR V 1.002 256
    Code: NK V 1.001 1049
    SN: 001f3d8b7c
    Nokia Unlimited: 1933 times started
    SonyEricsson Trial: 10 left, each max 15min
    Scanning files, please wait...
    Done
    Selected Highest installed version: 35.0.002
    Mcu RM-159_35.0.002_PR.C0R
    Ppm RM-159_35.0.002_PR.v18
    Content RM159_31.0.002_039_U01_uda.fpsx
    Using Tx2 Data line.
    BB5 PM back Phone is in: Phone is not responding!
    Processing File: RM-159_35.0.002_PR.C0R
    Boot...
    RAPIDOv11_2nd.fg
    RAPIDOv11_algo.fg
    omap2420_m1_2nd.fg
    RAPIDOv11_2nd.fg
    RAPIDOv11_algo.fg
    omap2420_m1_2nd.fg
    CMT Certificates
    HWC 0x0100
    CCC 0x0200
    APE Certificates
    NPC 0x0300
    HWC 0x0300
    CCC 0x0300
    C:\Program Files\GriffinTeam\MT-Box\rpls\8FF26ECC1DCE5DC.rpl
    Erase RAP3 [00080000 - 007B1641]
    Erase RAP3 [00000000 - 0005FFFF]
    Erase RAP3 [00880000 - 00FDFFFF]
    Erase APE [00000200 - 0000AFFF]
    Erase APE [0000B800 - 000AFFFF]
    Erase APE [00000000 - 00000FFF]
    Erase APE [0000D800 - 0000E9FF]
    Erase APE [00080000 - 000BFFFF]
    Erase APE [000E0000 - 0045FFFF]
    Erase APE [004C0000 - 0073FFFF]
    Erase APE [00A40000 - 0633FFFF]
    Erase[110.89 MB]...
    in 0.17s
    Flash[70.30 MB]...in 102.52s
    * * Processed file in 132.39 seconds
    Processing File: RM159_31.0.002_039_U01_uda.fpsx
    Boot...
    RAPIDOv11_2nd.fg
    RAPIDOv11_algo.fg
    omap2420_m1_2nd.fg
    Erase APE [06340000 - 0FA3FFFF]
    Erase[151.00 MB]...
    in 0.72s
    Flash[47.45 MB]...in 90.52s
    * * Processed file in 118.08 seconds
    Extract content...fail
    Processing File: RM-159_35.0.002_PR.v18
    Boot...
    RAPIDOv11_2nd.fg
    RAPIDOv11_algo.fg
    omap2420_m1_2nd.fg
    Erase APE [04C40000 - 0633FFFF]
    Erase[23.00 MB]...
    in 0.20s
    Flash[9.74 MB]...in 14.23s
    * * Processed file in 24.27 seconds
    * * * Phone flashing done in 5:57 minutes
    Post Flash serial tunning of phone....
    Pooling mode for full factory set...
    Phone not responding, try to set manually!
    Pooling mode for profile update...
    RM-159\RM159_0534839_35.0.002_001.dcpf\Refurbish\RM15 9_PP_DEFAULT.xml
    Sending Profile to Phone...Fail
    dây là log khi flsh bằng MT
    DT : 0909168878
    mytho. tien giang
    Box: CR V 1.002 256
    SN: 001f3d8b7c
    Nokia Unlimited: 1936 times started
    Done
    Boot...
    Trying boot BB5 phone...
    RAPIDOv11_2nd.fg
    RAPIDOv11_algo.fg
    omap2420_m1_2nd.fg
    BOOT OK...
    CMT Send NPC Certificate
    CMT Send HWC Certificate
    CMT Send CCC Certificate
    APE Send NPC Certificate
    APE Send CCC Certificate
    APE Send HWC Certificate
    Phone Type: BB5
    ----------------- RPL Restore Certificate Status --------------------
    RPL RAP3 Certificate sent SUCCESSFULLY
    Waiting for 30 seconds for phone TX...
    Delay additional 3 seconds
    ============= Set FBus mode for info =============
    NO SERIAL COMMUNICATION WITH PHONE
    NOT SENDING SIMLOCK AND SUPERDONGLE
    CHECK CABLE!
    VBat is 4.03V
    Vpp pin has 0.09V, Not Connected
    Pins:
    Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
    log khi write imel của MT
    DT : 0909168878
    Thành viên mới thanh_lap's Avatar
    Mar 2010
    emvua moi cao dien dan cho em hoi lam sao gui bai viet len dien dan duoc ah
    mytho. tien giang
    APE Data :
    ASIC MODE ID: 00
    RAP Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Original Imei: 35483501694032
    Original Product code: 0548986
    Bluetooth ID: 001ADCD5B090
    WLAN ID: 001ADCE4F2CE
    log khi info của MXKEY
    DT : 0909168878
    mytho. tien giang
    Trích Được post bởi thanh_lap Xem bài viết
    viết tiêng việt có dấu nhé bạn, kẻo bị pan nick đó. thấy chữ REPLY TO THREAD kg nhấn vào đó rồi tạo bài viết lên
    DT : 0909168878
    Vi phạm nội quy hungkute.tb's Avatar
    Feb 2010
    Thumbs down 8800 gold cần bán
    em có máy 8800 gold bị lỗi camera , mọi chức năng khác vẫn bình thường. a e nào cần mua thì pm lại cho e nhé
    Mar 2010
    chữ REPLY TO THREAD mình tìm mà ko tháy nơi
  1. cần anh em giúp check imel
    By quangthang007 in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Bài viết cuối: 24-02-2014, 16:43
  2. xin giúp 1280 nạp pm imel ?????????????
    By lethanhtam92 in forum DCT4 - WD2
    Bài viết cuối: 09-10-2012, 17:56
  3. N73 mất imel cần anh em giúp !
    By vutruonghd in forum BB5
    Bài viết cuối: 13-08-2010, 06:29
  4. giúp em nạp imel
    By huynhthien in forum DCT4 - WD2
    Bài viết cuối: 17-01-2010, 13:57
  5. imel ?????? xin giúp
    By tranthao in forum BB5
    Bài viết cuối: 25-07-2009, 16:05
