Mình thu 1 cây 1200.Tự nhiên đang để bình thường lại mất nguồn.Mình đưa vào hộp JAF để flash thử thỉ nó báo thế này.nhờ AE xem giúp.Mình mới vô nghề nên chưa có nhiều kinh nghiệm.Xin cám ơn tất cà !!
Getting MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: \Products\RH-99\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84623DC358CBF4C11A58AE87EA
MSID decoded: 3E4EBAE90090AA90A9000000
FAID: B617C4BF67F44947B92F1FE3
Operation took 0 minutes 6 seconds...
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 7 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 8436BBF15D4EE15E06E198B6EC
MSID decoded: 3E4EBAE90090AA90A8000000
FAID: D360DA4DE5689A60E29EED2A
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 22 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 8475BA668E82CCB50E60CBEBD6
MSID decoded: 3E4EBAE90090AA90AA000000
FAID: 69D2AACD3F67B04D97916F00
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 56 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
			 1200 mất nguồn nhờ AE xem giúp
			 Được post bởi luan_mobile83
