18 Seconds Only...
15 Mhz + Nitro Mode...
Code:Number of Image Files: 3 Processing Image File : C:\Nokia Firmware\RM-638\rm638__07.10.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 020C192102034000 > 0203192102034000 > 020C192102034100 > 0203192102034100 > 0203192102054100 > 020C192102054100 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 137 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02054100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 23400315 ID DWORD 1 : C70F0049 ID DWORD 2 : 87B1021B ID DWORD 3 : A7BA57B0 ID DWORD 4 : FFAD15FB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 Checksum 1E SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Application\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0321 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 36 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0321 RAP3Gv40_XSR17_alg.fg First Algo byte : 56 Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00800000 (8388608) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \AdvanceBox Application\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x00E1 (225) ERASE Blocks : 0x0004 (4) erase blocks : 4 CurrPos : 03 CurrEraseLen : 4B 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-000203FF 1 : 00060000-0009FFFF 2 : 000A0000-0025FFFF 3 : 003E0000-005DFFFF 4 : 005E0000-010DFFFF 5 : 01EC0000-01EDFFFF 6 : 027C0000-02CBFFFF 7 : 077C0000-07B3FFFF 8 : 010E0000-01EBFFFF CurrPos : 50 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 0000000000000008000000000000000200000064000000020000000200000001000000000000 CurrPos : 81 CurrEraseLen : 2F 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A000000010000000200000064000000020000000200000001000000000000 CurrPos : B2 CurrEraseLen : 2F 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000B000000000000000200000064000000020000000200000001000000000000 ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B000300000600000009FFFF120B000300000A00000025FFFF120B000300003E0000005DFFFF120B000300005E0000010DFFFF120B00030001EC000001EDFFFF120B000300027C000002CBFFFF120B000300077C000007B3FFFF120B000300010E000001EBFFFF3D ERASE_REQUEST_BB5 : 5001192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000003E ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000100000002000000640000000200000002000000010000000000003B ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B0000000000000002000000640000000200000002000000010000000000003B Successfully erased.. Time Taken to Erase : 00:00:01 Is Flashing CLOCK AUTO : 0 Processing : rm638__07.10.mcusw Total blocks to write : 137 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:07 Processing Image File : C:\Nokia Firmware\RM-638\rm638__07.10.ppm_r CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 020C192102034000 > 0203192102034000 > 020C192102034100 > 0203192102034100 > 0203192102054100 > 020C192102054100 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 30 Entry Point: 0x011D Page Format : -1 MAX PAGE : 0x00040000 ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01EE0000-027BFFFF ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74 Successfully erased.. Time Taken to Erase : 00:00:00 Is Flashing CLOCK AUTO : 0 Processing : rm638__07.10.ppm_r Total blocks to write : 30 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:02 Processing Image File : C:\Nokia Firmware\RM-638\rm638__07.10_003.image_r_ctv_cn_v2_95989 CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 020C192102034000 > 0203192102034000 > 020C192102034100 > 0203192102034100 > 0203192102054100 > 020C192102054100 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 67 Entry Point: 0x0154 Page Format : -1 MAX PAGE : 0x00040000 ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 000A0000 Size : 02720000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x003F (63) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02CC0000-077BFFFF CurrPos : 10 CurrEraseLen : 2F 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 0000000000000008000000000000000200000064000000020000000200000001000000000000 ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90 ERASE_REQUEST_BB5 : 5001192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000003E Successfully erased.. Time Taken to Erase : 00:00:00 Is Flashing CLOCK AUTO : 0 Processing : rm638__07.10_003.image_r_ctv_cn_v2_95989 Total blocks to write : 67 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:04 Total Flash Write Time (Flashing Only) : 00:00:14 Total Flashing Time (Booting + Erase + Flashing) : 00:00:18 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 05 Device Type : 0F Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 07.10 25-03-10 RM-638 (c) Nokia IMEI: 352682049751422 Product code : 0598959 Model : Nokia 6303ci ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED
So here is the CORRECT Pinout.
You can use your old 6303 Cables but you need to ADD the MBUS_2 line.
			 First in the world 6303ci RM-638 FBUS Flashing (18 Seconds) by ATF
