Kết quả 1 tới 10 của 13
    Thành viên mới hmmx4's Avatar
    Apr 2010
    Mặc định 1200 liệt phím 2
    em có con 1200.bị liệt 1 số phím.sau khi thay ic phím thì các phím đã được duy chỉ có phím 2 là không đc.e thử thay ic phím khác rùi mà vẫn không được.pác nào đã gặp qua trường hợp này chỉ em với ạ.thank !
    Thành viên mới cucanh's Avatar
    Jun 2010
    Getting MCU ID
    MCU ID: 0x2201
    FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
    Checking path: \Products\RH-93\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02qa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02qa
    Languages in ppm: English,Chinese S,Chinese T
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    BOOT file: D:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x7E2A0100
    Flash loader is D:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: c6
    Loader is ready...
    MSID: 848B3A46C87C5A8D5D2D69A68C
    MSID decoded: 3E4EBAE9005405D0AA000000
    FAID: F00E1D09017D5ACB2CFED891
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 27 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02qa
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8449DC252F9AB7A5246D662ADF
    MSID decoded: 3E4EBAE9005405D0A8000000
    FAID: 8BC538EA578FF3639EDB0080
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02qa
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 54 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-93, Software version: 7.02
    IMEI: 356450018785367
    Product Code: 0537102
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: 2
    SW version: 7.02
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 01
    MCU ID: 0x2201
    Algo is ready...
    Erasing area: 01140000 - 0115FFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2201
    Algo is ready...
    Done!
    DCT4 unlock counter: 36
    Done!
    Oct 2009
    tân phú-đồng nai
    đo coi nó có áp ko bạn
    văn yên_yên bái
    Trích Được post bởi cucanh Xem bài viết
    Getting MCU ID
    MCU ID: 0x2201
    Algo is ready...
    Done!
    Phone Restarted...
    Phone Type:
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Reading...
    Resetting PPC...
    Done!
    Done!
    Unlocking...
    ASIC: 2
    SW version: 7.02
    Decrypting flash...
    Encrypting....
    Patch status: 01
    MCU ID: 0x2201
    Algo is ready...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2201
    Algo is ready...
    Done!
    Done!
    bác này làm cái gì ở tô píc người ta thế ?
    Thành viên chính thức anhdungbt's Avatar
    bị mạch rồi, coi nó bị đứt bên ngòai hay bên trong rồi coi sơ đồ câu phím đó lại
    Thành viên tích cực phu quy's Avatar
    Sep 2007
    bạn đo cả trong lẫn ngoài fim 2 xem nếu thông thì kiểm tra lại con ic fim thay mới đã chuẩn chưa bị 1 fim vẫn do ic fim là bình thường còn yên tâmddi là đứt bo mêm chăc ko bao giơ bị 1 fim đâu
    QUÊ HƯƠNG HƯNG ĐẠO VƯƠNG
    Thành viên mới tran_but's Avatar
    nghệ an
    Trích Được post bởi hmmx4 Xem bài viết
    bạn làm thế này nha : câu từ điểm trong của phím 2 đến điểm trong của phím 0 . câu từ điểm ngoài của phím 2 đến điểm ngoài của phím 3 . ok 100% chúc bạn thành công , nhớ thank nha
  8. ( tran_but ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hmmx4 (16-07-2010)
  9. #8
    Thành viên tích cực duytrong_pro's Avatar
    đóng ic phím chẩn lại đi pác
    saigonmobile.vn đả làm tôi ngày một lớn khôn
  10. #9
    Thành viên kỳ cựu duyquang_mobile's Avatar
    Oct 2009
    bạn đo xem có thông mạch mát từ fims1 sang ko .điện áp từ fim2-->5 có mất áp ko .ở đâu mất thì câu ở đấy bạn nhé .
    wa yahoo mình hướng dẫn chi tiết cho ( nguyenquang_201086)
    SỐNG TRÊN ĐỜI PHẢI CÓ CHỮ TÂM . DTDD :0922972486
    MUỐN THÀNH CÔNG PHẢI CÓ CHỮ NHẪN.... yahoo nguyenquang_201086
  11. #10
    Thành viên chính thức le quang's Avatar
    bị 1 phím số 2 là đứt mạch rồi bạn ơi.xem đo nối lại đi.nếu ic phím thì thường bị 1 dãy luôn bạn chứ kg bị 1 phim đâu.
    con đường học vấn dài lâu.
    tìm đi lối tắt,dễ đâu mà thành.
  1. Trả lời: 3
    Bài viết cuối: 29-11-2012, 12:30
  2. xin sơ đồ câu led 1200
    By LươngTuyên_mobile in forum DCT4 - WD2
    Bài viết cuối: 12-10-2012, 15:00
  3. 1200 rớt nước
    By danbui88 in forum DCT4 - WD2
    Bài viết cuối: 05-03-2010, 21:39
  4. help me log 1200
    By huynhduy in forum DCT4 - WD2
    Bài viết cuối: 04-02-2010, 15:23
  5. 1200 ko den` cua
    By nhattan0812 in forum DCT4 - WD2
    Bài viết cuối: 15-12-2008, 20:26
