This Was Given By Mr.Elco To NSpro Users And Here It Is Now For All
Very Easy Steps And All Files Are In One File
I9000 - I897 - T959 Unlock For Free
Here is USB Drivers
Đọc kĩ hướng dẫn sử dụng trước khi dùng
I9000 unlock instructions
Code:
1. Power on the phone and go to Applications->Settings->About Phone->USB
settings
2. Select Mass Storage
3. Connect the phone to USB cable
4. Swipe down the top notification bar then tap “USB Connected” then select
MOUNT
5. Copy update.zip file to phone mass storage root
6. Power off the phone
7. Press Volume Up+Home+Power on key to start the phone into recovery
mode
8. Go to “apply sdcard:update.zip” using volume keys then select it using
home key
9. Power on the phone then go to Andoid Market and install Terminal
Emulator
10. Run Terminal Emulator
11. Type cat /efs/nv_data.bin >> /sdcard/nv_data.bin into terminal then type
Enter
12. Connect the phone to PC in USB Storage Mode then copy nv_data.bin file
to your pc
13. Open nv_data.bin file with any hex editor (ex. Hex workshop) then go to
address 00181460
14. There are the codes
15. Power on the phone with any unaccepted sim card inside then type in the
first code to unlock the phone
I897 unlock instructions
Code:
1. Power on the phone and go to Applications->Settings->Applications->USB
settings
MOUNT
7. Press Volume Up+Volume Down+Power on key to start the phone into
recovery mode
8. Go to “reinstall packages” using volume keys then select it using home key
Emulator
Enter
to your pc
address 00181460
T959 unlock instructions
Code:
settings
MOUNT
recovery mode
Emulator
Enter
to your pc
address 00181460
Report Post
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitterStumble this Post!
