em nhận của khách con 1202 khi bật nguồn lên nokia rùi treo lun.em chạy nó báo thế này.các bác chỉ giúp em xem bây giờ em phải làm sao.em làm lại cpu va uem rùi mà vẫn vậy.
Incorect MCUID!
Causes:
1. Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line
MCU ID: 0xFFFF
Can't find boot file...
Failed! Aborting!
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.03
29-06-09
RH-112
(c) Nokia
HW version: 1005
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w22_U
LCD version: WIN:SERI:8a
NT7542
PPM version: V 04.03
29-06-09
RH-112
(c) Nokia
MR
ADSP SW version: V 04.03\n29-06-09\nRH-112\n(c) NMP\nmr
Production serial number: DXR521083
Product code: 0562324
Module code: 0204036
Basic production code: 0558505
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 351550044967494
IMEI spare to net: 3A 15 55 00 44 69 47 09
IMEI SV to net: 33 15 55 00 44 69 47 19 F9
Master Code: 1077045571
Phone type: RH-112, Software version: 04.03, Language Pack: MR
User code: Gen
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code: 0562324
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
Phone Type:
MCU Flash file: D:\file nokia\RH-112 v4.03\rh112_004.030
Phone Type:
PPM Flash file: D:\file nokia\RH-112 v4.03\rh112_004.03mr
Phone Type:
CNT Flash file: D:\file nokia\RH-112 v4.03\rh1120_nai04.03mr
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: D:\file nokia\RH-112 v4.03\rh112_004.030
Booting phone...
Incorect MCUID!
Causes:
MCU ID: 0xFFFF
This MCU ID is not supported in chosen flash file...
Error booting phone...
			 giúp em con 1202 treo máy
