Hi All Friends, I Want To Share With You Something
Here V3r 0a.52(r3443u2_g_0e.c0.17r) T-mobile Unlock Process:
But Before Do Something You Must Need Smartclip & Internet.
This Phone Not Support By Smartclip, It Showing "unlock Not Support Of This This Firmware" Massage.so You Can't Unlock It
By Smartclip Direcly.so I Find A New Idea For It.
Read Care Fully
1.first U Need Open The Phone
2.make Test Point
3.download P2k Easy Tool(i Give You Link Also)
4.start P2k Easy Tool
5.select V3r From List
6.mark Sp Locks
7.connect Phone With Usb Cable And Join Testpoint To Ground
8.put Batt.on Set And Click "do Select Jobs"
9.there Appear Massage Click Ok On Massage
10.remove Cable From Phone
Put Batt Anfd Check Your Phone If You Press Power On It Will
Blinking Only.
So Now You Make This Phone By Smartclip. Process Is......
1.launch Smart Moto
2.use Test Point Again And Click Search Button
3.smart Moto Will Found Your Phone
4. Make Sure Your Internet Connection
5.go On Repair Tab And Select V3r
6.click On Repair Pds
7.smartclip Will Auto Log In (wait Approx.2 Min)
8.after Pds Will Repair Done
9.but Don't Flash It
10. Remove Phone And Put Batt. And See Your Phone 1000% Unlock And Working Fine Also.
