Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
ASIC ID: 0x1052 [TikuEdge ver: 1.1]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0020 [Samsung KFM1216Q2M,512 Mbits] type: NAND hw: EIJA(E)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
UEM ID: 001F8A53:3B8ADA60
ASIC type: 6
UEM Imei: 35664100155413
Flash Imei: 35664100155413
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35664100155413_BA CK.rpl"
Processing MCU file: rm13_33_11004.170
[TIKU BT2,TIKU ALGORITHM] size: 9.87 MB
Supported Ids: 1052, 2051
UEM ID: 001F8A53:092EDA60
Area [00000000-0000FFFF] erased in 0.641 s
Area [00010000-009FFFFF] erasing ...
Error while erasing 0x00150000-0x0016FFFF, Result: 04000000
flashing terminated !
Flashing terminated with error(s) in 1 min 14.141 s
RX Buffer: 0400000000B172
báo như vậy đó thử chạy jaf như vậy luôn
			 anh  em dúp 8800 rm 13 nạp phần mêm bị lổi check ok info không được nạp báo lổi log
