Open file "D:\TONG HOP\phan mem simen Joker_356\phan mem simen\ax72 tv\ax72 read tv\AX72lg2Sw02_00-100_FF.bin" for write in Flash.
FullFlash file info:
FlashID: 0001/2221
SIEMENS AX72 Sw02 lg2
RealLgPack: lg7
Start...
Cancel.
FlashID: 0001/2221
RealLgPack: lg7
Start...
Loading BootsModel(AX75)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Warning: HASH data error!
SIEMENS AX72 lg2 Sw02
Soft FlashID: 0001/2221
FlashID: 0001/227E-2221-2201
Flash Size: 16Mb, WriteBuffer: 32 bytes
Region(1): Blocks 128, Size 128Kb
Start EEPROM segments at addres 0x7A0000
FSN: 07176A38 -> PhoneID: 386A1707
OTP IMEI: 357402005105215
HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Error: EEP0067 not found!
Error: EEP0076 not found!
Read EEP5005 block (ver00), size 64 bytes - Ok.
Read EEP5007 block (ver00), size 10 bytes - Ok.
Read EEP5008 block (ver00), size 224 bytes - Ok.
Read EEP5009 block (ver00), size 10 bytes - Ok.
Read EEP5012 block (ver00), size 14 bytes - Ok.
Read EEP5077 block (ver00), size 232 bytes - Ok.
Read EEP5093 block (ver00), size 76 bytes - Ok.
Read EEP5121 block (ver00), size 56 bytes - Ok.
Read EEP5122 block (ver00), size 6 bytes - Ok.
Read EEP5123 block (ver00), size 12 bytes - Ok.
EEPROM blocks is written in ".\Backup\AX72lg2Sw02_Backup070824141703.eep" file.
ClearFlashSeg at 0x000000 does not answer!
nó cứ báo hoài .em không flash được thanks
đã flash nhiều full mà vẫn báo đều như vậy cả
 LinkBack URL About LinkBacks
			 xem dùm em cái log AX72 này
			 Được post bởi son_nx2007
