Octopus Box LG Software v2.3.4
- LG E739BK - added Direct Unlock, Repair IMEI, Repair Security,
Repair BT Address, Write Firmware, Write Security Backup, Read/Write/Repair NVM,
Read Full Flash, Reset Screen Lock (included Reset Password, Pin and Pattern locks).- LG E739KWP - added world's first Direct Unlock, Repair IMEI,
Repair Security, Repair BT Address, Write Firmware, Write Security Backup, Read/Write/Repair NVM,
Read Full Flash, Reset Screen Lock (included Reset Password, Pin and Pattern locks).- LG BL20GO - added Direct Unlock, Repair IMEI, Repair Security, Repair BT Address,
Write Firmware, Write Security Backup, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Dump RAM.- LG BL20t - added Direct Unlock, Repair IMEI, Repair Security, Repair BT Address,
Write Firmware, Write Security Backup, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Dump RAM.- LG GS500GX - added Read Codes, Repair IMEI, Write Firmware,
Read/Write/Repair EEPROM, Read Info, Factory Reset.- LG GW520GO - added Direct Unlock, Repair IMEI, Write Firmware,
Read/Write EEPROM, Read Info, Factory Reset.- LG GB102GO - added Direct Unlock, Read Codes, Repair IMEI,
Repair BT Address, Write Firmware, Read/Write EEPROM, Read/Write Full Flash, Read Info, Factory Reset.- LG GM205GO - added Direct Unlock, Repair IMEI, Write Firmware,
Read/Write EEPROM, Read/Write Full Flash, Read Info, Factory Reset.- Added a lot of software manuals for supported phones.
- Released some improvements to the main software.
- Firmwares for the above mentioned phones where uploaded into the Support Area.
Good is not enough. You deserve the best servicing solutions and the most
up to date tools for your business, so stay with us cause there's gonna be more!
Download Octopus Box LG Software v2.3.4
