Added world's first support for LG A270, LG A270E, LG A275 and support for LG C333, LG C800DGDU, LG C800DGP, LG C800TKGO, LG C800VL, LG C800VLP cell phones!
Octoplus Box LG Software v1.0.1 Release Notes:
- Added support for the following models:
- Added Software manuals for supported phones.
- LG A270 - added world's first Direct Unlock, Read Codes, Write Firmware, Repair IMEI,
Read/Write/Repair EEPROM, Read/Write Full Flash, Read Phone Info.- LG A270E - added world's first Direct Unlock, Read Codes, Write Firmware, Repair IMEI,
Read/Write/Repair EEPROM, Read/Write Full Flash, Read Phone Info.- LG A275 - added world's first Direct Unlock, Read Codes, Write Firmware, Repair IMEI (A/B),
Read/Write/Repair EEPROM, Read/Write Full Flash, Read Phone Info.- LG A290 - added Direct Unlock.
- LG C333 - added Direct Unlock, Read Codes, Repair IMEI (A/B/C), Repair BT Address, Read/Write/Repair EEPROM, Read Full Flash, Read Phone Info.
- LG C800DGDU - added Direct Unlock, Write Firmware, Repair IMEI, Repair Security, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Reset Screen Lock (included Reset Password, Pin and Pattern locks).
- LG C800DGP - added Direct Unlock, Write Firmware, Repair IMEI, Repair Security, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Reset Screen Lock (included Reset Password, Pin and Pattern locks).
- LG C800TKGO - added Direct Unlock, Write Firmware, Repair IMEI, Repair Security, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Reset Screen Lock (included Reset Password, Pin and Pattern locks).
- LG C800VL - added Direct Unlock, Write Firmware, Repair IMEI, Repair Security, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Reset Screen Lock (included Reset Password, Pin and Pattern locks).
- LG C800VLP - added Direct Unlock, Write Firmware, Repair IMEI, Repair Security, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Reset Screen Lock (included Reset Password, Pin and Pattern locks).
- Released some improvements to the main software.
Octoplus Shell Software v1.0.1 Release Notes:
- Added possibility to manually download information about update.
- Added ability to disable automatic check for updates at the program start.
- Added ability to switch between phone help and JTAG help (for example, if the phone is supported via servicing software and JTAG, you can choose which manual to use).
- Added phone image preview of the selected phone model.
- Added Ukrainian and Russian translations to the main software.
- The program is now minimized to tray (not to the panel).
- Improved skins usability.
- Improved phone selection from the list.
Only world's first, only the best updates from the best box on the market - Octoplus!
Download Octoplus Box LG Software v1.0.1 and Octoplus Shell v1.0.1
