VolcanoBox 1.9.2
Whats new ?
Worlds 1st Mstar Flash for unlock !!
Coolsand detection/Pinfind Solved !!
MTK6250 flashing update
Click here to Download
Details :
What is World's 1st Mstar Flash for Unlock ?
Some Mstar phones come to you shop with usercode. you try to read flash and read it's code. you tried but all codes given by Software is incorrect. You plug other boxes and read codes from all boxes and All boxes given codes you tried but all of them are not working. Mobile says Incorrect code. Now you have only 2 ways left !!
1- You search for flash file
2- you search for same working phone
1- you search for flash file. you waist your important time in search and download and flash your phone. after all results is all available files are completable with your phone. you tried lot of Flash files. some files results is your phone power on but on your phone White screen. some Flash file results is your phone is dead and so on.
2- You search for same working phone. you waist lot of your important time for search same phone in market and you didn't get. if you get you read flash and write on faulty phone result is phone not power up cause of Flash ic difference or LCD white or keybaord not working fine and so on
SO WE RELEASE FLASH FOR UNLOCK OPTION IN MSTAR
what you need to do is. simply read flash of your faulty phone by clicking READ FLASH then click on Flash for unlock and click on run. it will ask you for file give path of your read flash and it will start writing.after writing your phone code will be removed !!
This is World's 1st and unique Solution for those Mstar phones which Show Wrong code after you read code from all Chinese boxes. !!
i don't want to write name of boxes and phone model name which we test. cause of i don't want bla bla.... i am not in Fighting mode
VolcanoBox ver 1.9.2 have firmware update !!!!
when you run it 1st time. do not attach any phone with volcano box. also make sure your pc will not shut down or your will not have Electricity failure...
