Finally ASANSAM User's can Do Unlock/Repair/Flashing,...... for Some Non-Android Phones (at now 44 models of Samsung Sysol Platform)
Add
E1207T Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI(A+B) First in the World (One Click)
E1070M Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1200M-CIS Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1080F-SEA Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1081T-MEA Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1081T-SEA Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1081T-IND Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1081T Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
B130 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1110 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1117 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1310S Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
T239 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1210S Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1360S Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1080 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1086L Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1125Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1105T Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1100T Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
C270 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
C276 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1360 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
A137 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
T101 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
B270i Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2100 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2120 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2130 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1210M Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1360B Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2100B Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2100L Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2210B Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2210 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E2210L Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1085 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1070Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1120 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1160 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1130B Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1100 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
E1075 Read/Write Flash | Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
C3303i Read Lock | Direct Unlock | Read/Write EEPROM | Repair IMEI
About unlock/Repair Sysol Platforms
We add two methods for this
1- TAT Mode
2- Flash Mode
in TAT Mode (Recomended Solution) you can do Read Code/Direct Unlock/Repair IMEI
in Flash Mode you Can only Repair IMEI
By Default Software Doing TAT Mode Solution For Changing Method Just Going to Setting TAB and Uncheck Bypass Security in TAT Mode
IMPORTANT NOTE FOR ROOKIES:
We add Erase Flash for these models this ability was usefull when Phone Software is total damaged (for example blinking in Logo)
BUT IF YOU CHECK THIS OPTION IN SETTING TAB ALL YOUR CALIBRATION DATA ERASED MOST IMPORTANT THING IMEI WAS ERASED AND BECOME 00000000000000
GOOD THING IS YOU CAN REPAIR YOUR PHONE AFTER THAT HAPPENS BUT IF IT DONT NOT NECESSARY DON'T CHECK FULL ERASE BEFORE FLASH
DOWNLOAD
PLEASE UNINSTALL PREVIOUS VERSION OF ASANSAM THEN INSTALL THIS NEW ONE
BR
ASANGSM TEAM
