Hi everyone
- Added WORLD FIRST, USB ONLY, NO TP ROOTING FOR RM-801 LUMIA 800
- Added WORLD FIRST, USB ONLY, NO TP ROOTING FOR RM-802 LUMIA 800C
All NOKIA DLOAD OSBL loaders are supported (even latest one!)
Instructions:
1. Run Cyclone, it will be auto-updated
2. Update your Box Firmware to v2.20
3. Go to WP7 -> Simlocks Tab
4. Select Product and click ROOT!
It should go this way:
Quote:
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[Urządzenie kompozytowe USB]: WinUSB Port opened OK!
[Nokia USB Connectivity]: WinUSB Port opened OK!
Switching to RAW Mode...
OSBL Details
Protocol: v1.1
Version: v257.6
Build: 12
Timestamp: 2012-02-17 14:40:05
OSBL Bootloader Ready
USB&UART Tracing set
RSA Signature Calculated for QCB Boot, Writing...
OSBL Certificate Details
Magic: WP70
Version: 0
Signer Server ID: 0x98031573
Signer Timestamp: 2011-09-28 15:52:12
Signer S/N: 23
Signer User ID: 10046114
Auth Level: Care
Data Encryption: 0
Image Index: 0
Asic Index: 0
Type: Image Write
Hashtable Parsed OK
Certificate Accepted
[ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200
Write taken 0.358s (Average speed: 19462,61kBits/s)
Restoring Modem from BACKUP_RAMFS_IMAGE...
Restore OK
Restarting MCU...
Rooting Finished!
After rooting, Qualcomm Bootloader is installed. That means phone will be detected as Mass Storage Device, and you will have full access to eMMC.
Because patching is not good solution, we will add some good news aswell in next days
However, if you need simlock patching badly you can use some free tools around to patch AMSS (i.e. NSS).
Release Notes:
1. Supported products: Cyclone Box Classic, Cyclone Box Reloaded, Cyclone Key
2. Firmware Required v2.20
3. Need No TP Activation, is COMPLETLY FREE for all Cyclone Key users, for rest you need have 60 credits on your account and your box will be automatically activated (credits will not be withdrawn from box anyway, this is just threshold).
4. We also have solution to completly root rest of lumias, including 610, 610nfc, 900, etc... however it will be released ONLY if this solution WILL NOT BE COPIED. If somebody copy solution - it will be kept private.
5. No need new installer, however if you need one, always latest one is here: http://www.karwos.hk/CycloneBoxInstaller.exe
Best Regards,
Cyclone Team
