Martech BOX III v0.1.2.2225
Ford CAN code reader - new activation for Box III.
Activation allows you to:
- read the original radio code
- read, reset, and change the VIN stored in the radio
The reading process takes a while and is done by CAN (radio must support this protocol).
Procedure can be performed on bench or in the car:
Ford MS-Can | Martech Box3 Help
Supported models:
- radios based on NEC D70F3357, TMS470, MC9s12, ST92 (KW2000, GGDS) with V or M prefix
- navigation modules produced by Visteon and Bosch (C307 / C214 Nav module, FX - LSRNS, NX - HSRNS)
NOTE: activation reads the original factory code.
If it happens that the code does not match, it means that it has been changed and you should read the processor / memory depending on the device.
How to update Box III? Run martech_ams3.exe or download:
http://box3.martech.pl/martech_ams3.exe
Check supported models and functions in demo version:
Check our Youtobe channel for videos:
MartechTeam - YouTube
Best Regards
Martech Team
Martech
