ddasdasdas
    Nov 2010
    Mặc định ATF DRIVE v12.30 Update!! 19 MAY 2015!!
    Release Date: May 19, 2015
    Firmware Version Required : 11.0.10 or 11.0.12
    ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
    ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
    ATF Plus eMMC Tool 4.0 (PRO)
    Introducing ATF Drive !!! 100% FREE FOR ALL ATF BOX USERS
    D.R.I.V.E. = Data Recovery Interface Via EMMC
    First In the World Solution that will MOUNT eMMC Partitions as a Windows Removable Disk!
    Now you can Recover Data from a Dead Phone by Simply using Windows Explorer "Search" and "Copy + Paste".
    Special Features:
    --> Supports Windows XP, Vista, 7, 8.0 and 8.1 (All 32-Bit and 64-Bit Versions)
    --> You can load Partitions via Direct ISP eMMC Connection (4 wires + Vcc/VccQ) or via eMMC Binary Dumps
    --> Supports FAT12, FAT16, FAT32, exFAT, NTFS Windows Phone Partitions
    --> Supports EXT2, EXT3 and EXT4 Android Partitions (1)
    --> You can READ + WRITE to Mounted Partitions as if they were USB Drives on your PC! (2)
    --> Supports Recovery of Windows Phone 8.0/8.1/10 DATA Partition EVEN if MBR, GPT and BOOTLOADERS are ERASED!
    --> Faster READ/WRITE Speeds when compared with other Products
    --> Supports MBR + GPT Partitions of Android and Windows Phones
    Video Demonstration on Lumia WP8 Phone Here:
    ATF D.R.I.V.E Demonstration on Lumia 630 Phone
    Video Demonstration on Android Phone Here:
    ATF D.R.I.V.E. Demonstration on Android GT-i9505 Phone
    (1) : EXT2, EXT3 and EXT4 Support Requires Additional Installation of
    a FREE Software Paragon EXTFS which can be downloaded here:
    https://www.paragon-software.com/home/extfs-windows/
    (2) : WRITE Operations on EXT2, EXT3 and EXT4 are not Supported by FREE Software
    Paragon EXTFS. If you want to WRITE to Android/Linux Partitions, you can
    still do so "AT YOUR OWN RISK" via using another FREE Software named
    Ext2Explore. More Information here:
    Ext2Read download | SourceForge.net
    ---> Added "Samsung eMMC Write CID" Function for writing Custom CID to Samsung eMMCs
    Lumia 8.0 + 8.1 BOOT RECOVERY via USB
    --> Windows Phone 8.0/8.1/10 Flasher now has an improved BUILT-IN BOOT REPAIR Function via USB.
    --> If your WP Phone is TOTALLY DEAD or HALF DEAD or TOTALLY ALIVE, ATF WILL FLASH it via USB ONLY! (3)
    Added Support for 40 New Lumia 8.1 Phones
    RM-1068 : Lumia 435 DS
    RM-1069 : Lumia 435 DS
    RM-1070 : Lumia 435
    RM-1071 : Lumia 435
    RM-1114 : Lumia 435 DS
    RM-1017 : Lumia 530
    RM-1018 : Lumia 530
    RM-1019 : Lumia 530 DS
    RM-1020 : Lumia 530 DS
    RM-1031 : Lumia 532 DS
    RM-1032 : Lumia 532 DS
    RM-1034 : Lumia 532
    RM-1115 : Lumia 532 DS
    RM-1089 : Lumia 535
    RM-1090 : Lumia 535 DS
    RM-1091 : Lumia 535
    RM-1092 : Lumia 535 DS
    RM-976 : Lumia 630
    RM-977 : Lumia 630
    RM-978 : Lumia 630 DS
    RM-979 : Lumia 630 DS
    RM-974 : Lumia 635
    RM-975 : Lumia 635
    RM-1027 : Lumia 636 4G
    RM-1010 : Lumia 638 4G
    RM-1040 : Lumia 730 DS
    RM-1038 : Lumia 735
    RM-1039 : Lumia 735
    RM-1078 : Lumia 735
    RM-983 : Lumia 830
    RM-984 : Lumia 830
    RM-985 : Lumia 830
    RM-1049 : Lumia 830
    RM-927 : Lumia Icon/929
    RM-1045 : Lumia 930
    RM-1087 : Lumia 930
    RM-937 : Lumia 1520
    RM-938 : Lumia 1520
    RM-939 : Lumia 1520
    RM-940 : Lumia 1520
    Refreshed Support for 28 Old Lumia 8.0 Phones
    (Now uses loaders based on RM-xxx Type)
    RM-820 : Lumia 920
    RM-821 : Lumia 920
    RM-822 : Lumia 920
    RM-824 : Lumia 820
    RM-825 : Lumia 820
    RM-846 : Lumia 620
    RM-860 : Lumia 928
    RM-867 : Lumia 920T
    RM-875 : Lumia 1020
    RM-876 : Lumia 1020
    RM-877 : Lumia 1020
    RM-885 : Lumia 720
    RM-887 : Lumia 720T
    RM-892 : Lumia 925
    RM-893 : Lumia 925
    RM-910 : Lumia 925
    RM-913 : Lumia 520T
    RM-914 : Lumia 520
    RM-915 : Lumia 520
    RM-917 : Lumia 521
    RM-941 : Lumia 625
    RM-942 : Lumia 625
    RM-955 : Lumia 925T
    RM-994 : Lumia 1320
    RM-995 : Lumia 1320
    RM-996 : Lumia 1320
    RM-997 : Lumia 526
    RM-998 : Lumia 525
    (3) : Not all Phones can be Repaired via USB Cable Only. Some Phones might have a
    buggy eMMC Inside which requires Direct EMMC Connection or JTAG to Repair.
    BUG FIXES:
    1. Fixed Bug on Nokia X2 (Android) Flashing/Boot Repair
    Added New Lumia Models to Nokia.ini
    --> Lumia 540 Dual SIM (RM-1140)
    --> Lumia 540 Dual SIM (RM-1141)
    *** WARNING ***
    Starting ATF 12.30, "Skip Flash File Checksum Verification Before Flashing" is
    now SELECTED in "Settings" ---> "Nokia Settings".
    This allows FASTER LUMIA Flashing Procedure on Slower PCs. However, your Phone
    might DIE if your FFU File is Corrupted. Anyway, you can still repair the phone
    via USB Cable after your have Downloaded a NON-CORRUPTED FFU File.
    Who will buy this if you can get more in ATF?
    __________________________________________________ ________________________
    DOWNLOAD HERE:
    ATF V12.30 Full Installer
    ATF DRIVE v12.30 Update!! Public Discussion Thread:
    ATF v12.20 Update Public Discussion Thread:
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    The Master Piece
  2. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuanvan2012 (19-08-2015)
