Octoplus / Octopus Box Samsung Software v.2.2.3 Release Notes:
  • Added support for the following models:
- SM-G930F - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G930FD - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G930K - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G930L - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G930S - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G930W8 - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G935F - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G935FD - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G935K - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G935L - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G935S - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-G935W8 - added Direct Unlock, Read Codes, Read/*Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-J320FN - added Direct Unlock, Read Codes, Repair IMEI, Repair Network, Read/Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-J105B - added Direct Unlock, Reac Codes, Repair Network, Repair IMEI (A/B), Read/Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-J105H - added Direct Unlock, Reac Codes, Repair Network, Repair IMEI (A/B), Read/Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
- SM-J105M - added Direct Unlock, Reac Codes, Repair Network, Repair IMEI (A/B), Read/Write Cert, Read/Write Security, Read/Write EFS, Write Firmware
*You should use only original Certificate of the phone for "Write Cert" operation. Writing of another phone's Cert file will make the phone unable to receive Network.
  • Improved Write Cert operation for A7, Note 4 series.
  • New Cert files were uploaded into the Support Area!
  • All supported operations described in details in the manual ("Cable & Manual" button in Software)
More info and discussion are HERE
___________________________________
WBR,
Octoplus Box Team
