Octoplus/Octopus Box LG Software v.2.5.0 Release Notes:🐙 Added support for the following models:
- V520 - added Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address
- V521 - added Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address
- V521WG - added Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address
- V522 - added Direct Unlock (in Test Mode), Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address
- V525 - added Direct Unlock (in Test Mode), Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address
- K200DSK - added Direct Unlock (in Test Mode), Repair IMEI (A/B) (in Test Mode), Reset FRP, Write Firmware, Read/Write/Reset Security, Read/Write NVM, Read/Write QCN, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address
- K220DSZ - added Direct Unlock (in Test Mode), Read Codes (in Test Mode), Repair IMEI (A/B) (in Test Mode), Reset FRP, Read/Write Firmware, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
- K220Y - added Direct Unlock (in Test Mode), Read Codes (in Test Mode), Repair IMEI (A/B) (in Test Mode), Reset FRP, Read/Write Firmware, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
- K220Z - added Direct Unlock (in Test Mode), Read Codes (in Test Mode), Repair IMEI (in Test Mode), Reset FRP, Read/Write Firmware, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
🐙 Added Write Firmware in Upgrade Mode (non-direct) for firmware in "*.kdz" format for LG H731, H734, H735x, H736To write firmware in Upgrade Mode You need to select "*.kdz" firmware, check (enable) "Upgrade Mode" option and press "Write Firmware" button🐙 Added DIAG Mode (port Check Test) auto-enable before performing of any operation, while the phone is connected to PC in Normal Mode.
Tested for D855, H734, H815, H845, H860 models. Should also work for all new Qualcomm-base devices of K and H series🐙 Improved Firmware Convertor for old "*.tot" versions of firmware
🐙 Information regarding Reset FRP operation for Nexus 5x (H790, H790T, H791, H791F) phones with new firmware:After performing Reset FRP operation, the phone with new (latest) firmware may stuck on LG logo! To fix this problem you shall re-flash the phone with the latest firmware
Notification about possible issue was added into the Software.
🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software)More info and discussion are HERE
_______________________________________________
WBR,
Octoplus Box Team
