What`s new:
- Added full support for X550 : DirectUnlock/IMEI Rebuild/Lock/ReadCodes/Flash-EEP-FFS RW
- Added full support for X540 : DirectUnlock/IMEI Rebuild/Lock/ReadCodes/Flash-EEP-FFS RW
- Added full support for E200 : DirectUnlock/IMEI Rebuild/Lock/ReadCodes/Flash-EEP-FFS RW (MSL Bypass does not supported in new FW versions)
- Added full support for E830 : DirectUnlock/IMEI Rebuild/Lock/ReadCodes/Flash-EEP-FFS RW (MSL Bypass does not supported in new FW versions)
- Added full support for D900i : DirectUnlock/Flash-EEP-FFS RW
- Added full support for Z240
- Automatic search for UST Pro II box implemented, UST Box can be detect on any port now, You can use UST/SeTool/Forious/Cruiser/S-Card,etc... in SAME time together.
- Agere IMEI Rebuild process improved.
- X430,X450,X450C,X458 Flashing bugs fixed.
- Added support for new SAMSUNG flash chips, like KAP29WN,etc...
Note : For X540 & X550 IMEI Rebuild/ReadCodes/Lock, you need 2 cables, one is normal E700 cable, other one is X540 unlock cable. first connect with E700 cable and after bypass MSL, use X540 unlock cable for Rebuild IMEI or other functions.
New version can be downloaded from http://www.ust-pro2.org
