Trang 8 của 36 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... CuốiCuối
Kết quả 71 tới 80 của 352
  1. #71
    Moderator thanhphuek's Avatar
    Feb 2010
    Eakar Đến PLeiku
    Volcanobox V1.4.8 Added Coolsand Ct8853A - Imei Generator & more
    How to unlock HUAWEI U Series Phones with VolcanoBox
    Click here to View PDF
    http://forum.gpgindustries.com/downl...ownload</font>
    ĐIỆN TỬ-ĐIỆN THOẠI THANH PHÚ
  2. #72
    Thành viên chính thức hungthinhmobi's Avatar
    Mar 2012
    VolcanoBox 1.4.9 Huawei Modem Direct Unlock Beta & many more
    Whats new ?
    • Added Huawei Modems Direct Unlock ( BETA NEED TEST Reports )
    • Added cooland CT8853B-SPI8M Read/Write
    • Modify Coolsand Read pass Algo ( you must check password from 2 ways 1st Find Password 2nd Unlock code )
    • Modify Mstar Find pass Algo
    • Huawei U Series Bug Solve if still have problem please report us
    • Added New PDF Manual
    • Added Huawei U Series Drivers
    i want to share some thing about Coolsand Wrong passwords
    VolcanoBox Coolsand Wrong password Detailed info & help needed
    i had seen Few Friends was asking that Volcano Box reading Wrong code from Coolsand Phones. we really investigate it deeply and I want to share with you guys
    whenever you got coolsand phone before do any thing 1st of all read info like this
    at the end of log you will see
    0x400000 (4M)
    0x800000 (8M)
    You must check this before you do anything. If you have 4MB then you must select 4MB Flash ID from volcanobox and if you have 8MB then you must select 8MB Flash id.
    How could I know which flash id is 4mb and 8mb ?
    Mostly Flash id which have “32” figure in flash id name is 4 MB
    For example
    EN71PL032
    GQ25QL032
    CT8853B-Q32
    Built-in Ct1129D
    Like these are 4mb Flash id
    Mostly Flash id which have “64” figure in flash id name is 8mb
    For example
    GQ25QL064
    MS25U6435E
    Why need this to verify ?
    I had seen many Friends just read flash and try to find password from them and some time they got wrong password. What I saw and what I make experiments is. If you flash id is 4MB and you select 8MB flash id for sure flash file will not readed correctly when flash file not readed correctly then how it’s possible it will give you correct password ? some time Friends select 4MB flash id and their phone have 8MB and they read flash file and try to find password as flash is 8MB and they read just 4MB for sure file is not readed complete !! as file not readed complete for sure it will give you wrong password or no password found error.
    So always 1st make read info then select 4MB or 8MB Your desire Flash id and read flash after for sure password will be read correct !
    After some Friends post issue about this problem so we decide make tour of market and read password of all available coolsand phones and will check what wrong so I go and make test. During my Tour I Test about 400 phones total and from these 400 phones I got 250 different phones which was Coolsand. I read password from all of them and I am surprised all password was correct. How I was doing take phone set any password and read password from volcano and it’s reading correct password from all coolsand phones
    Then I make search in forum try to collect coolsand phones name which was giving wrong password. I got few of them when I check all password read correct. From Market I check lot of models and Brands like
    Gright5130 mini
    Vell comm Ve1661
    Ken Xin da F911
    Cell com ve1209
    Jmobile J228
    Gboss G200
    Vell comm a2656
    Xptel c1
    Nokia c1
    Nestle 2232
    Nestle mini N5212
    More C3322
    Cptel G101
    XPtel G101
    Lehar loot 77
    Spice S1332
    Samsung W279
    Httel K81
    Xptell C00-1
    Sprice C2
    Spice S16
    Spice S18
    Samsung C3322
    Also lot of other models. I read password and all of them are working password. I did not encounter with any wrong password. After what we make experiment we take two same phone ( same models same brand but board was not same ) put password on of it and read flash and read password it read correct password from flash file then I write that file into another phone ( same brand . same model but board was not same ) after flash it mobile alive and working fine but that password is not working on it. Then we take same phone same as phone which I write flash file on it not from I read flash we took same mobile ( mobile same. Model same . board same means 100% ) I set password and read flash and write on that phone which phone I write flash file before and which was not accepting correct code. We write flash file and we read password it was correct and mobile accept. Then again we remove password from that phone which I read flash file 1st (same brand . same model but board was not same ) read flash and write on that phone which was not accepting password. After write flash mobile power on and working fine but keypad was not working good when ever we press 1 mobile type 8 we press 2 mobile type 0 we type 5 mobile type 7 like this keypad was not accurate
    So we found this could be reason as Customer never tell true so we don’t know is some buddy played it before or no
    So 1st reason we found cause of bad flash file keypad not working fine cause when ever we insert password in password box we can’t see digits we see only Stars ****
    For example I write 786 you can read it but i write *** can you read it ? both type I write 786 so in password box we don’t know what mobile is typing ( writing ) so this could be 1st possible reason
    2nd reason could be some time mobile keypad ic damaged and mobile not write correct what we press buttons . some time this happen like customer make password on mobile and its was working fine but after some time his baby put mobile in his ***** cause of WET keypad damaged or keypad ic damaged now customer will put mobile in sun shine and after 3 to 4 hour he will take mobile and when it power on for sure mobile will ask for password and when he will type if keypad ic or keypad damaged for sure password will not open and we can’t see what mobile is typing in password box
    3rd reason could be some time we press 9 and mobile write # we press 7 and password write * as we don’t know what mobile is writing in password box so it will not open even box read password correct
    So if you found any case Please investigate it deeply as our Users is our Beta testers and tell me what you found you can contact me via sonork 100.1577177
    @ All please make test as many of you have mobile for sell and some of you have Big Dealer in china mobiles please try to do this
    Take phone set password like 9999
    Read info of mobile and check what size it have as I explain you already
    Set correct Flash id and read flash
    After read flash click on Find password
    Give path of flash file and see is your password which you set on phone before read. Volcano show you or no . if incase volcano can’t show please Contact me on sonork 100.1577177
    If you got any phone which have password and you don’t know what password is on phone. Please try to take same phone ( 100% same ) when you found same phone please contact me on sonork 100.1577177 Don’t Read flash from unprotected phone ( normal phone ) and write on Protected phone ( phone which have password ) this is really useless for us but it will work for you
    I asked you to contact me cause of if you read flash from same mobile from working phone and write on that same phone which have password it will work fine for you but we can’t implement it and when ever you got such
    phone and you have not same phone in hand for sure you can’t do it !!
    I hope it will clear and if you really got such case for sure you will contact me !!
    About Huawei U Series unlock
    1.remove micro sd card from phone.
    2.check battery level(it's important, without battery phone can't connect to pc)
    3, remove battery from phone fo 5 sec, then replace it back in phone.
    4. enter in fastboot mode(check if drivers not have !, it's important, if drivers conflict will not work ok).
    5. press unlock.(if used check phone...repeat same from step number 2).
    PS . use directly to usb port don't connect cable threw hub and make sure correct drivers installed.
    if again problem not solve please test it on FRESH Windows pc for sure it will unlock your phone also make sure you are not making these mistakes
    For example your problem can be:
    1.Battery level not ok, phone lost communication(error writing buffer exactly this mean).
    2.Phone is in incorrect mode and not respond ok after send loader.
    3.Drivers is wrongly installed.
    4.Used WIN7 or Vista and not opened with admin right.
    5.Firewall block exe in some way.
    6.USB not have power to keep phone.
    7.Phone have custom rooted, moded , supermoded firmware.
    8.your antivirus creating problem.
    Click here to download
    support us and vote for us. Will encourage us give you more support
    __________________
    HƯNG THỊNH mobile
    >> Unlock- Mở Mạng - Sửa Lỗi Phần Mềm - Nạp TV Mobile<<
    yahoo: HưngThịnh0939157157-
    DĐ: 0939157157
    stk VCB 0671000411744
    Unlock-Mở Mạng-Sửa Lỗi Phần Mềm-Nạp TV
    Y!h:hungthinh0939157157
  3. #73
    May 2011
    Hà Nội City
    VolcanoBoxV1.5.0 Huawei Blast,Hot Imei Service featuring Iphone Imei Checker(paid)
    Whats new ?
    • spd 6610/20 added two more Flash id
    • modify mtk 6250/52 file-write algo
    • modify mstar find pass also
    • modify spd find pass also
    • mtk boot V5.1205 added 6236 USB read,write,format
    • Added Huawei G Series phones by Cables & by Imei
    • Solved Huawei U Series unlocking
    • Added PDF Manual How to Unlock Huawei U Series phones
    We are updating our Document & Help section
    Go to your VolcanoBox installed Folder and read
    \VolcanoBox\Documents & Help\ PDF files
    for sure it will solve lot of problems
    Huawei G Series Models List
    G5500 By Cable
    G5510 By Cable
    G6600 By Cable
    G6603 By Cable
    G6609 By Cable
    G7050 By Cable
    G7105 By Cable
    G7300 By Cable
    KNP Touch By Cable
    T-Mobile energy By Cable
    VM820 By Cable
    G3501 By Imei
    G5010 By Imei
    G5726 By Imei
    G6005 By Imei
    G6210 By Imei
    G6605 By Imei
    G6608 By Imei
    G6620 By Imei
    G6622 By Imei
    G7002 By Imei
    G7210 By Imei
    G7510 By Imei
    G7600 By Imei
    Mobistar Onda By Imei
    Panama By Imei
    VM720 ByImei
    G20 By Imei
    Huawei U8180 Successful Unlock !!
    Downloading Loader..
    Downloading OK
    Rebooting phone, this can take few second....
    Reconnecting to phone..
    Connection OK.
    Reading Phone Info..
    Phone SN: D5J4CD1192802843
    Phone Firmware: U8180-1V100R001C33B621_E
    >>Simlock Status : Locked.
    Searching Phone..
    Phone found.
    Product: U8150
    Version: 0.5
    Downloading OK
    Connection OK.
    Clearing Simlocks...
    >>All Done.
    Huawei u8652 Unlock done !!
    [YOUTUBE]PX_oPBN8NQk[/YOUTUBE]
    Volcano Box 7 in 1 Cable Coming Soon !!
    [YOUTUBE]u2xa6dbL69A[/YOUTUBE]
    How to Check IPHONE IMEI SIMLOCK & Carrier
    Go to Unlocking Solutions, Real Time Unlocking Solutions, Free Unlock Solutions, Unlocking Tools, Social Tools
    Register your account by using This link
    http://oneunlock.com/en/0c568212c42b...338a1db051e796
    Login to your Account
    Topup Your account
    Click on News
    Scroll Down
    Find Apple iphone network finder by imei or click here iPhone Network Check
    Scroll Down
    Write your imei
    Click on Make Request
    After Submit your imei
    wait for 1 to 5 mins
    refresh you page
    and you will get info
    Simlock & Carrier !!
    OneUnlock.com is our Friend and Providing Such a Great Services
    Please take a look on these videos
    OneUnlock.com => How to Register your account & How to Topup
    [YOUTUBEHD]rh4mEZVX4i4[/YOUTUBEHD]
    OneUnlock.com => How to Check your Iphone Simlock & Carrier
    [YOUTUBEHD]CCEUYj1ZpMk[/YOUTUBEHD]
    OneUnlock.com => Fast Tour to Great Services and Good Support
    [YOUTUBEHD]OjXJN5UU6SY[/YOUTUBEHD]
    WE BELIEVE IN NON STOP UPDATES RATHER THAN ADVERTISING!
    OUR BEST WAY TO GET A NAME IN THIS BUSINESS IS THE SATISFACTION OF OUR CUSTOMERS!
    Be Ready for SPD 6530A Cpu !!
    Download Full Installer Link
  4. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    VŨ PRO (23-08-2012)
  5. #74
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    ((: VolcanoBox 1.5.1 Pure for chinese mobiles )
    VolcanoTool_v1.2.6.5.1 BY SAEEDULLAH_KHAN.rar
  6. #75
    Feb 2010
    Eakar Đến PLeiku
    Mặc định VolcanoBox V1.5.2 World's 1st MEDIATEK MT 6162N Imei Changed Supported
    Modify 6800H Write Flash
    Modify 6610/20 Write Flash
    Modify MSTAR MSW8532B,MSW8533B,MSW8532B2 Write Flash
    Modify MTK Boot V7.1216 Andriod Read/Write Flash
    World's 1st MEDIATEK MT 6162N Imei Changed Supported by Android Tool
    While Other Duplicating their products to catch more customers with some fishy tricks… Volcano Box… AHEAD OF ALL
    Download link
    BEST UFC in the World !!
    GPGUFC
  7. #76
    Administrators ThanhHaMobile™'s Avatar
    Dec 2006
    Hoa Phượng Đỏ
    Thumbs up VolcanoBox V1.5.3 Unlock Samsung I9300 etc Which Relock after Frimware update & More
    !! 1st of All Watch the Video !!
    [YOUTUBE]VR1g5UB4nMc[/YOUTUBE]
    Adjust 6800H Write Flash
    Adjust 6610/20 Write Flash
    Fix 6800H bug
    Adjust Mstar Write Flash
    Adjust MTK Andriod Read Flash
    Adjust Coolsand Find Pass Algo.
    World's Most Wanted Solution =Unlock Your Samsung I9300 Etc Which RELOCK After Firmware Update...
    Many other failed !!
    Now in these days Many Samsung i9300 coming which are Relocked by users & Shop keepers after Firmware update.... Your phone will Unlocked but when you update firmware your phone will Relock and then Trouble comes. after relock many other devices are failed to unlock again. So we specially make solution for them who have phones in hand with this condition. other boxes say phone unlocked but actually phone is still locked. this problem came in new firmwares in phones. you get unlock your phone by Service center and you update your firmware and after update your phone will Relock like these type of trouble you can easily solve with VolcanoBox. simply Root your phone....Connect usb cable....select model and Tick on ADB unlock thats it.... after run in few mins your phone will Unlock and Will Not RELOCK AGAIN !! How's that
    MTK Android Flashing Hints & Tips
    In these days lot of Chinese mobiles comes with MTK 65xx Cpu
    like MTK 6575, 6516, 6573, 6577 etc
    mostly all of them are supported by Volcano Box
    in some phone there have some tricks to connect which i want to share with you guys. we support Almost All mtk Android phones for ReadFlash, Write Flash, Repair imei etc All you can do with simple usb cable. No need to find rx tx or opening phones, as Rx Tx method is really slow so we don't do it yet. so for imei repair you have to perform these steps
    1- Insert sim into phone
    2- Insert Battery into phone
    3- power on phone
    4- Make sure Usb Debug mode on
    5- Connect Usb cable
    6- install drivers
    7- open volcano -> mtk -> press ALT + CTRL + i
    8- Select Android Tool
    9- Press run & read instructions
    Your phone's imei will repair
    for Read or Write flash just perform these steps
    1- open volcano -> mtk
    2- select boot 7.1216
    3- select Read Flash or Write flash ( if write Flash select Flash file 1st)
    4- Tick usb mode
    5- Insert battery into phone
    6- Press Run button
    7- inset usb cable
    Your phone will read flash or write flash as you select Desire option !!
    There is some boot keys for these Android phones
    Some phones you need to press and hold these keys before plug usb cable
    Vol +
    Vol -
    Vol + and Vol -
    Camera key
    Vol - and power button
    Vol + and power button
    Vol - and vol + and power
    camera key and power
    camera key and vol +
    camera key and vol -
    power button
    we face some phones which need these boot keys rest you can play with them
    sample video for you
    [YOUTUBE]98c6T7mzfPU[/YOUTUBE]
    Nếu cần liên hệ, xin vui lòng ... liên hệ theo thông tin ở dưới đây!
    CUNG CẤP THIẾT BỊ CHẠY PHẦN MỀM CHÍNH HÃNG
    • Repair Boot - Unlock giải mã - mở mạng - mở mã pass người dùng - sửa lỗi phần mềm, nạp tiếng Việt, chuyển đổi ngôn ngữ cho các dòng máy Mobile • CUNG CẤP & TƯ VẤN SỬ DỤNG THIẾT BỊ CHẠY PHẦN MỀM MOBILE CHUYÊN DỤNG • CUNG CẤP SẢN PHẨM DUNG DỊCH PHÁ KEO IC, BÃO HÒA TẢN NHIỆT IC, KEO DẪN ĐIỆN, THIẾC BỘT, CHÌ XẢ MỐI HÀN, DAO PHÁ KEO • KEO DÁN MÀN HÌNH CẢM ỨNG iPHONE, iPAD, LAPTOP, GIA CỐ CPU CÁC LOẠI ...
    ThanhHaMobile™ Service Center
    Số: 411 Tô Hiệu (ngay ngã tư An Dương, đối diện siêu thị HONDA Hương Giang) - Hải Phòng.
    ĐT: Gphone 0225.609.239 - 0983.717.628 - 0912.050.858.
    • Tài khoản Anypay Viettel số: 0987 250 552
    • Tài khoản giao dịch: DongAbank - Chủ tài khoản: Nguyễn Đức Thanh
      Mã số TK: 0104365048 chi nhánh Lê Chân - Hải Phòng.
    • Tài khoản giao dịch: Agribank (NNPTNT) - Chủ tài khoản: Ngô Thị Thu Hà
      Mã số TK: 2112205015281 chi nhánh Lê Chân - Hải Phòng.
    • Tài khoản giao dịch: VietCombank - Chủ tài khoản: Ngô Thị Thu Hà
      Mã số TK: 0031001023873 chi nhánh Lê Chân - Hải Phòng.
  8. #77
    Thành viên mới leanhmoble's Avatar
    SPD 6530a Supported... VolcanoBox v1.5.4 440volts Shock to other╭∩╮ World's 1st Added SPD 6530a Read/Write Flash
    World's 1st Added SPD 6530a Find Pass
    Modify MTK 6250 Read/Write Flash
    Modify MTK Encryption Algo.
    Added Samsung EFS(Backup) Restore for ADB Unlock ( After unlock if you want just write backup your phone will Relock )
    !! World's 1st SPD 6530a READ FLASH DONE !!
    !! World's 1st SPD 6530a WRITE FLASH DONE !!
    VolcanoBox 7in1 cable in action
    Volcano Box Basic Manual
    VOLCANO
    Unlock Server
    Very Special Thanks to Mobileclinic to providing the Phones
    Download new ver
    VolcanoTool_v1.5.4.rar - Downloads - GPGIndustries - Forum
    Other Team still Dreaming that they are giving shock to others but infact WE VolcanoBox team giving shock to them...
  9. #78
    Bình Dương
    VolcanoBox V1.5.5 Presents World's 1st SPD 6530a Format... Where are Other Teams?
    • World's 1st Added SPD 6530 Read Info
    • World's 1st SPD 6530 Read Password
    • World's 1st SPD 6530 Format ( BETA )
    • Adjust Coolsand Read Password Algo
    format :
    1- read Flash file as backup
    2- select format
    3- select readed flash file
    4- Click on ok ( Don't put manual format address )
    Format done... keep in mind it's BETA. can be have some bugs
    VOLCANO
    Unlock Server
    Download new ver
    VolcanoTool_v1.5.5.rar - Downloads - GPGIndustries - Forum
    After our updates they try to copy us and take ages and when they release they said we are world's 1st... infact they are world's last.
    VolcanoTool_v1.5.5.rar - 4shared.com - chia sẻ và lưu trữ - tải xuống tập tin trực tuyến
  10. #79
    Bình Dương
    BAM BAM Volcano 1.5.6 released! MTK 625a Support and more!!!
    Download Volcano 1.5.6 Click here
  11. #80
    Bình Dương
    World's 1st
    SUPPORTED
    Infact it was supported since VolcanoBox 1.4.x
    This mean this cpu was supported From last FEW MONTHS
    we keep on looking for new phones to search and develop we found that some new CPU already supported.
    It's World's 1st cause of no other Team announce it 1st
    We did come Polish and giving you Grand Update !!
    What new in this ver ?
    Added Coolsand CPU RDA8853A
    For. READ FLASH. WRITE FLASH. FORMAT. IMEI REPAIR
    Modify MT625A Write Flash
    Modify MT6250DA Write Flash
    Added Samsung firmware
    Rename Coolsand Tab to Coolsand & RDA
    Added Live News & Tips Section in VolcanoBox Software ( internet Required )
    Click here to Download
    VolcanoBox & GPGindistries Presents:
    Media Library for GSM Friends
    as you guys know that Youtube is Blocked in many Countries so we Decide to make Media Library for you guys. where you can see Lot of Videos, Tutorials etc. Hope you people will love it. it will update regular. Tomorrow will add lot of Videos etc
    Click here to VISIT
    Go to forum.gpgindustries.com & click on MEDIA
    THE BEST ONLINE UNLOCKING SERVER EVER !!
    download:VolcanoTool_v1.5.8.rar
Hiện có 11 người đang xem bài này . Bao gồm : 0 thành viên và 11 khách
  1. NS Pro Update Post here
    By DNA in forum NS Dongle
    Trả lời: 72
    Bài viết cuối: 10-09-2016, 01:13
  2. GB-Key New Update AE Post Ở Đây
    By Lính Khang in forum Các thiết bị khác
    Bài viết cuối: 16-11-2012, 07:14
  3. Axe Box New Update AE Post ở đây
    By TuấnPhát_GSM in forum AxeBox
    Trả lời: 27
    Bài viết cuối: 16-01-2012, 09:38
  4. MT Box New Update AE Post ở đây !!!
    By HoangThong_hotrokythuat3 in forum MT-Box
    Trả lời: 35
    Bài viết cuối: 23-11-2011, 08:07
  5. CPF Box II New Update AE Post ở đây
    By TuấnPhát_GSM in forum CPF-BOX Ⅱ
    Bài viết cuối: 06-08-2011, 15:31
