Kết quả 1 tới 4 của 4
    Thành viên chính thức hungnokia1990's Avatar
    Mặc định bác nào vào giúp em hộp volcano với
    tình hình là vào tính read flash con cpu mtk 6252 mà vào chọn binout cho em nó ko được hàn cả tx và rx mà không được.nó báo vậy nak Volcano Updated: 2013-08-30
    Connecting...
    Connection successful,connected state!
    Version: V3.8
    SN:754-777-763
    Port:COM17
    After format or Flash you have to press & hold power button for at least 1.30 mins.
    Note for win7 users :
    Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
    After that the spd drivers will have the ability to be loaded.
    Vcc: null
    Gnd: 1
    Short pins not detected.
    Detecting charge pin...
    Detecting 2 pin,Current: 44mA, Max: 200mA, Waiting-Time: 8s
    Charging pin:2
    Detecting 3 pin,Current: 17mA, Max: 17mA, Waiting-Time: 2s
    Charging pin:3
    For many phones, charge pins need to be set in order to identify USB devices.
    Detecting D+ and D-...
    Vcc: null
    Gnd: 1
    Detection initiated...
    Failed to detect.
    Detecting rx and tx...
    Vcc: null
    Gnd: null
    Detection initiated, connect the phone and power on it...
    Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient...
    Failed to detect.
    Available Ports:COM1 COM17
    IF Software stop here. you see Stop(red) button become Run(Green) please press and hold power button till boot downloading not start, then release power button, when you releaes power button if boot downloading stop this mean you have HARDWARE fault in your mobile
    Vcc: null
    Gnd: null
    Failed to detect.
    Vcc: null
    Gnd: null
    Identifying MT...
    Identifying SKY...
    Identifying SPD...
    Identifying AD...
    Identifying Philips...
    Identifying Infineon...
    Identifying TI...
    Identifying SI4904...
    Could not identify the Chipset.
    Vcc: null
    Gnd: null
    >>Failed to detect.
    anh em nào có thể chỉ giúp em với
    sát thủ nokia.chuyên vien luộc đồ nokia .đại gia cua gái
    ko bác nào giúp em với ah
    Feb 2008
    lâm đồng
    chon Detect mtk& spd nữa mới bootn dc
    D/C: LÂM HÀ_SUCCECSS_
    AGRIBANK-NGUYỄN NGỌC PHONG
    T/K ;5404205189065
    Thành viên kỳ cựu dinhtoan179™'s Avatar
    Nov 2012
    HOA BÌNH
    online gui tem minh giup cho
