unlock ok GS290
Con này Z3 Read Codes đúng 5s
P/S: Các bạn phải chế lại cáp RJ45 tới đầu USB 6500s hay đầu nào giống nó cũng được
tham khảo hình bên dưới sẽ rõ hơn
Good luck
unlock ok GS290
Good luck
GIALAI_GSM (17-09-2010), hoang long ha noi (02-11-2010)
unlock LG KE970 ok by Z3x
dùng cable KG800
mobile services
NHƯ HẠ
yahoo: gialai_gsm
CU720 unlock ok
UNLOCK ALL NOKIA SL3 1-12H iPHONE 4/4S 5 AT&T HTC LG CYON SAMSUNG AUYCALL LẤY NGAY
NHẬN:UNLOCK ALL NOKIA SL3 15 ~ 30 PHÚT+TÍNH CODE SL3+REPAIR BOOT MOBILE
ĐC:45/6A Xô Viết Nghệ tỉnh Vũng Tàu-BRVT
AgriBank: 6000205152069 Nguyễn Phước Thanh Hùng
Hotline: 0908.36.39.39 -091.888.53.53 - 0908.725.725
Welcome to : www.giaimadienthoai.com
unlock LG GS101 by z3xLG ok
mobile services
NHƯ HẠ
yahoo: gialai_gsm
nhâp imei và Provider ID là lụm lúa
Cu575 unlokc with z3x mất 2s
v.2.0.4
Select ComPort or use Search Phone button!
Elapsed: 0 secs. --> (v.2.0.4)
Mode: Normal
Model: CU575
Build version: Nov 12 200721:45:19Nov 08 200709:30:00CU575
SW Version: CU575-MSM21301210T-V10h-NOV-08-2007-ATT-US
IMEI: 01121200354028-1
BlueTooth Address: 00:1C:62E:71:6C
Flash Name: toshiba_ty9000a800jogg
Flash Info: 02D5/0040/0800
Mode: Normal
Model: CU575
Mode: Normal
Model: CU575
Mode: Normal
Model: CU575
Mode: Normal
Model: CU575
NV read...
NV save:..\backup\CU575_011212003540281_14102010_2047 41.cnv
Elapsed: 13 secs. --> (v.2.0.4)
Select Modem Port:COM84
Detect phone Ok!
Start Unlock
Unlock Ok!
Elapsed: 14 secs. --> (v.2.0.4)
NV file: CU575_011212003540281_14102010_204741.cnv
NV File Version: 1
NV File Model: CU575
NV Records: 747
Write NV...
Phone reboot!
KP110 nạp tv và unlock ok
log
v1.0.6beta
andrew_tm 2010(c)
supported models: 159
Selected model: KP110
Selected port: COM8
Selected speed: 115200
Please press and hold power button!
Phone detected!
Loader startup Ok..
Reading phone info...
Flash ID: 012100
Flash type: S71PL129NB0
Flash size: 16Mb
IMEI: 359256-02-332675-9
Start unlock...
Read call. data...
Patch call. data
Write call. data...
Unlock succesfully!
Elapsed: 51 secs.
Read backup
Start read data...
Stop by user!
Phone disconnected
Selected port: COM8
Selected speed: 921600
Phone detected!
Loader startup Ok..
Flash ID: 012100
Flash size: 16Mb
Read backup
Start read data...
Call.data saved to:
C:\Program Files\Z3X\LG\LG2G\backup\CAL_KP110_359256023326759 _20102010_095539.bin
Read data done.
Start erase CodeData...
CodeData erase done...
Start erase AlchemyData...
AlchemyData erase done...
Start write CodeData...
Reading MOT file...
Reading MOT file succesfully completed !
Start write AlchemyData...
Reading MOT file...
Firmware write done.
For operation finishing do next:
- press "Disconnect" and power phone ON without SIM
- press 2945#*# for entering eng. mode
- select "Factory Reset"
Elapsed: 514 secs.
mobile services
NHƯ HẠ
yahoo: gialai_gsm
hoang long ha noi (02-11-2010), thanhkien90 (25-10-2010)
LG KH1200 unlock done by Z3
CTY TNHH TM-DV SAIGON MOBILE
635B TRƯỜNG CHINH P. PHÚ THẠNH Q. TÂN PHÚ TP.HCM .
DĐ:0975.722.711 ; 028.6267 3040 Vcb 0251002663023 ,
GIALAI_GSM (07-11-2010), HoangThong_hotrokythuat4 (23-12-2010)
Z3 Direct unlock thiếu 2s nữa là đúng 30s
Code:v1.1.3beta andrew_tm 2010(c) ;) supported models: 194 Selected model: GS108 Selected port: COM9 Selected speed: 115200 Connect phone and press Power ON! Connect ok! Send preloader ok! Send main loader Ok! Change BaudRate done! FlashId: 260600EC, flash size: 4Mb IMEI: 35xxx-xx-xxxxx-7 NCK Code: 7364 8488 0390 5990 Read eeprom... Eeprom saved to: C:\Program Files\Z3X\LG\LG2G\backup\EEPROM_GS108__19122010_170744.bin Patch eeprom data Write eeprom data... Start erase: 0x00BF0000-0x00C00000 OK! Start write 0x00BF0000-0x00C00000 OK! Unlock succesfully! Elapsed: 28 secs. --> (v.1.1.3beta)
LG CT810 Unlock Done By Z3
chanhtin_2104 (23-12-2010), HoangThong_hotrokythuat4 (23-12-2010)
