Samsung Tool PRO 29.7 Update. First in the world New SHANNON based phones read codes.
After months of research we present new 1st world exclusive solution for read codes from SHANNON cpu based new phones. - First in the world
Important thing: KNOX must be 0!!! If knox = 1 you can not read codes!!!!!
Added:
- support SM-J727A (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-J727AZ (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-J727S (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-J727U (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-T395N (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SC-04J (Flashing, Backup/Write EFS, Backup/Write CERT, Unlock (Root), Direct Read codes via Server, Repair, patch CERT(repair network), reboot download/recovery) - First in the world
- support SM-A720S (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-N950F (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-J327W (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-J330N (Flashing, Read/Write EFS, Unlock via MSL, Direct READ codes via server, reboot download/recovery) - First in the world
- support SM-A320F (Direct read codes via server) - First in the world
- support SM-A320FL (Direct read codes via server) - First in the world
- support SM-A320Y (Direct read codes via server) - First in the world
- support SM-A520F (Direct read codes via server) - First in the world
- support SM-A520K (Direct read codes via server) - First in the world
- support SM-A520L (Direct read codes via server) - First in the world
- support SM-A520S (Direct read codes via server) - First in the world
- support SM-A520W (Direct read codes via server) - First in the world
- support SM-A720F (Direct read codes via server) - First in the world
- support SM-G390F (Direct read codes via server) - First in the world
- support SM-G390Y (Direct read codes via server) - First in the world
- support SM-G390W (Direct read codes via server) - First in the world
- support SM-G570F (Direct read codes via server) - First in the world
- support SM-G570M (Direct read codes via server) - First in the world
- support SM-G570Y (Direct read codes via server) - First in the world
- support SM-G610K (Direct read codes via server) - First in the world
- support SM-G610L (Direct read codes via server) - First in the world
- support SM-G610M (Direct read codes via server) - First in the world
- support SM-G610S (Direct read codes via server) - First in the world
- support SM-G610Y (Direct read codes via server) - First in the world
- support SM-G950F (Direct read codes via server) - First in the world
- support SM-G950N (Direct read codes via server) - First in the world
- support SM-G955F (Direct read codes via server) - First in the world
- support SM-G955N (Direct read codes via server) - First in the world
- support SM-J326AZ (Direct read codes via server) - First in the world
- support SM-J327A (Direct read codes via server) - First in the world
- support SM-J327AZ (Direct read codes via server) - First in the world
- support SM-J327U (Direct read codes via server) - First in the world
- support SM-J330F (Direct read codes via server) - First in the world
- support SM-J330FN (Direct read codes via server) - First in the world
- support SM-J330G (Direct read codes via server) - First in the world
- support SM-J330L (Direct read codes via server) - First in the world
- support SM-J530F (Direct read codes via server) - First in the world
- support SM-J530FM (Direct read codes via server) - First in the world
- support SM-J530G (Direct read codes via server) - First in the world
- support SM-J530GM (Direct read codes via server) - First in the world
- support SM-J530K (Direct read codes via server) - First in the world
- support SM-J530L (Direct read codes via server) - First in the world
- support SM-J530S (Direct read codes via server) - First in the world
- support SM-J530Y (Direct read codes via server) - First in the world
- support SM-J530YM (Direct read codes via server) - First in the world
- support SM-J701F (Direct read codes via server) - First in the world
- support SM-J701M (Direct read codes via server) - First in the world
- support SM-J701MT (Direct read codes via server) - First in the world
- support SM-J730F (Direct read codes via server) - First in the world
- support SM-J730FM (Direct read codes via server) - First in the world
- support SM-J730G (Direct read codes via server) - First in the world
- support SM-J730GM (Direct read codes via server) - First in the world
- support SM-J730K (Direct read codes via server) - First in the world
- support SM-P585 (Direct read codes via server) - First in the world
- support SM-P585M (Direct read codes via server) - First in the world
- support SM-P585N0 (Direct read codes via server) - First in the world
- support SM-P585Y (Direct read codes via server) - First in the world
- support SM-P587 (Direct read codes via server) - First in the world
- support SM-P588C (Direct read codes via server) - First in the world
- support SM-T395 (Direct read codes via server) - First in the world
GUI changes:
- Fixed closing software after DB compact
- Removed "Solution" (Diagnostic data for server)
- Black skin improvements
- Link Login to current Card
(This function added for protect LOGIN/PASS from using on other CARD )
ATTENTION: PLEASE DON’T LOSE YOUR TIME WITH SHANNON PHONES IF KNOX=1.
IF KNOX=1 phone just will not answer on command. READ CODES AT THIS MOMENT NOT POSSIBLE IF KNOX=1!!!
CREDITS POLICY CHANGES:
From today the minimum pack - 30credits:
Success Read Codes Shannon phones: 5 credits.
Success Read Codes Qualcomm phones: 4 credits MEGA PROMO. ( from 00h-00m ,11 november to 13 november 23h-59m. TIME: GMT+2)
Success Read Codes Qualcomm phones: 5 credits FROM 14 november 00h-00m. TIME: GMT+2
Like usually new solution may have small bug, which will be fixed shortly.
Bug report welcome.
