Kết quả 1 tới 4 của 4
    Thành viên tích cực hoihue3con's Avatar
    Jan 2012
    Mặc định xin giúp hộp atf
    mình chạy bằng đường usb với các dòng máy asha , nhưng ko hiêu sao trong luc mình chọn file thì mình có chon luôn chế độ chạy song file thì tự factory reset nhưng sao đến lúc chạy hết 3file song thì nó ko reset đc đây là log mình chạy máy asha 305 xin ae giup thanks all
    Number of Image Files: 3
    Processing Image File :
    rm766__05.92.mcusw
    rm766__05.92.ppm_u
    rm766__05.92.image_001_u_059L0H6
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    Infineon USB Boot: F00A1FB300020303010100FF
    Sending PBL...
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Setting Transmission Speed Done...
    Flash Chip Manufacturer: Samsung Electronics Corp.
    Flash Boot Successful...
    Unique Data: 123018192B15280E
    Original Product Code: 059N2F8
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\354552055635041\3545520556350 41_23935.rpl
    Data Sections : 04
    Current File : rm766__05.92.mcusw
    Compile Name: rm766__05.92.mcusw_ebl_psi.fls
    Image Type : Main Firmware
    Data Size : 29117832 Bytes
    Sending Certificate Block
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01
    FIRMWARE Erase Block: 0x40000000~0x4001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 131072 bytes
    Data Checksum: 1369
    Uploading Data Blocks to phone...
    Block Write Successful...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02
    FIRMWARE Erase Block: 0x40040000~0x4005FFFE
    Start Erasing...
    Block Erase Done...
    Data Checksum: 73CD
    Processing Section 03
    FIRMWARE Erase Block: 0x40060000~0x4011FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 786432 bytes
    Data Checksum: C572
    Processing Section 04
    FIRMWARE Erase Block: 0x40120000~0x41BFFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 28065792 bytes
    Data Checksum: 7F36
    Processing Section 05
    FIRMWARE Erase Block: 0x43EE0000~0x43EFFFFE
    Start Erasing...
    Block Erase Done...
    Data Verification Successful...
    Data Sections : 01
    Current File : rm766__05.92.ppm_u
    Compile Name: package_u.ppm_ebl_psi.fls
    Image Type : PPM Image
    Data Size : 7106128 Bytes
    PPM Certificate Block Sent Successfully...
    PPM Erase Block: 0x41C00000~0x423FFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 7102784 bytes
    Data Checksum: A2A6
    PPM Data Blocks uploaded to phone...
    Data Sections : 01
    Current File : rm766__05.92.image_001_u_059L0H6
    Compile Name: package_u_059L0H6.image.fls
    Image Type : CONTENT Package
    Data Size : 13634832 Bytes
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x42400000~0x43EDFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 13631488 bytes
    Data Checksum: 4623
    CONTENT Data Blocks uploaded to phone...
    CONTENT Erase Block: 0x43F00000~0x43F7FFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:03:17
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    Operation Cancelled...
    Scanning USB Ports...
    ERROR: Active Phone Handle was NOT DETECTED
    TIP: Make sure that Phone USB Connection Mode is
    OVI Suite Mode
    or
    PC Suite Mode
    Phone is not Connected OR it is not in the
    Required Mode...
    Reboot the Phone and Enable "PC Suite" Mode
    Thành viên tích cực Chiến_mobile's Avatar
    Oct 2012
    thay sọi cáp khác đi pạn
    Jan 2012
    mình cũng thay sợi khác rồi vẫn ko đc a ơi
    Jan 2007
    THAI BINH CITY
    mình thấy dùng BEST chạy mấy cái may asah có vẻ êm hơn
