    Technical Assistance GIALAI_GSM's Avatar
    Dec 2009
    GIALAI
    Mặc định nokia x3 flash =usb by ATF ok
    Number of Image Files: 3
    Processing Image File :
    rm540__08.50.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 19500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 136
    Entry Point: 0x0259
    Page Format : -1
    MAX PAGE : 0x00040000
    rm540__08.50.ppm_a
    CMT Type : BB5
    Number of Blocks : 24
    Entry Point: 0x011D
    Page Format : -1
    rm540__08.50.image_a_0580697_004
    CMT Type : BB5
    Number of Blocks : 55
    Entry Point: 0x0154
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Flashing DOES NOT Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly..
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    BootRom Verified!
    BootFlashModeDCT5Ex Succeeded First Time
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00000001
    ID DWORD 3 : 020C1921
    ID DWORD 4 : 02054100
    cmt hardware : 02054100
    2 ROM_ID 15
    Block Length : 5 (05)
    ID DWORD 0 : 00001040
    3 ROM_ID 15
    ID DWORD 0 : 00001030
    4 PUBLIC_ID 12
    ID DWORD 0 : 2910030C
    ID DWORD 1 : 80170049
    ID DWORD 2 : 6E4C308D
    ID DWORD 3 : EDDD33FC
    ID DWORD 4 : 723F29BC
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 67E82268
    CRC 1 : F29CEA60
    START FLASHING
    RawLoaderExtract: Processing rm540__08.50.mcusw
    Match LOADER : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg
    Loader Uploaded.....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Device ID : 0000 -> BAD FLASH TYPE
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0030 -> K5W1G13ACB
    Revision ID : 0321
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data :
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 00800000 (8388608)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    ROOTHASH : 7B045400E1752022F9EB80B0DEA9C65D
    Match File.....C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_X SR17_alg.fg
    Done!
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 353401045939561
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\353401045939561\3534010459395 61_44746.rpl
    Pabub KEY Request
    C5012A1500CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E 970000000000000000
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 0004
    Partition 1
    Attribute : 00000002
    Start Address : 000A0000
    Partition 2
    Partition 3
    Partition 4
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x00E1 (225)
    ERASE Blocks : 0x0004 (4)
    erase blocks : 4
    CurrPos : 03
    CurrEraseLen : 4B
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x4B (75)
    Device Index : 0x00
    0 : 00020000-000203FF
    1 : 00060000-0009FFFF
    2 : 000A0000-0025FFFF
    3 : 003E0000-005DFFFF
    4 : 005E0000-010DFFFF
    5 : 01EC0000-01EDFFFF
    6 : 027C0000-02CBFFFF
    7 : 077C0000-07B3FFFF
    8 : 010E0000-01EBFFFF
    CurrPos : 50
    CurrEraseLen : 2F
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 00000000000000080000000000000002000000640000000200 00000200000001000000000000
    CurrPos : 81
    CurrEraseLen : 2F
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000A0000000100000002000000640000000200 00000200000001000000000000
    CurrPos : B2
    CurrEraseLen : 2F
    3 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 00000200000001000000000000
    ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
    ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 0002000000640000000200000002000000010000000000003E
    ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 0002000000640000000200000002000000010000000000003B
    ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 0002000000640000000200000002000000010000000000003B
    Successfully erased..
    Total blocks to write : 136
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    StartErase_DCT5...
    BlockLength : 0x000E (14)
    ERASE Blocks : 0x0001 (1)
    erase blocks : 1
    CurrPos : 03
    CurrEraseLen : 0B
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01EE0000-027BFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
    Total blocks to write : 24
    StartErase_DCT5...
    BlockLength : 0x003F (63)
    ERASE Blocks : 0x0002 (2)
    erase blocks : 2
    CurrPos : 03
    CurrEraseLen : 0B
    Device Index : 0x00
    0 : 02CC0000-077BFFFF
    CurrPos : 10
    CurrEraseLen : 2F
    Device Index : 0x00
    ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
    Total blocks to write : 55
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000001
    Additional Bad : 00000001
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 2
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:01:29
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up...(Max 100 seconds)
    Elapsed Time: 5 Seconds...
    Elapsed Time: 10 Seconds...
    SW: V 08.50 19-07-10 RM-540 (c) Nokia
    CONFIG KEY: 0000000000000000
    Provider : AT&T;U.S.A. (3650)
    Counters : 0/3 , 0/10
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SP Lock Status : Not Locked
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : PASSED
    SECURITY_CODE : 12345
    SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  2. ( GIALAI_GSM ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
    hoang long ha noi (12-09-2010), MT BOX (13-09-2010), trong khai (13-09-2010)
  1. nokia 700 flash xong treo nokia
    By thuanwhisky90 in forum BB5
    Bài viết cuối: 23-09-2014, 21:44
  2. Infinity-Box Nokia [BEST] v1.94 released: Nokia X2 support: Android, Service, Flash
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 05-08-2014, 09:39
  3. Flash nokia thành công bằng BB5 Easy Service Tool (BEST) Nokia Dongle anh em post tại đây nhé
    By HoangThong_hotrokythuat5 in forum BB5 Easy Service Tool (BEST) Nokia Dongle
    Trả lời: 16
    Bài viết cuối: 13-01-2014, 08:57
  4. Trả lời: 7
    Bài viết cuối: 08-08-2013, 09:10
  5. Trả lời: 2
    Bài viết cuối: 10-10-2009, 17:46
