Trang 12 của 16 Đầu tiênĐầu tiên ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CuốiCuối
Kết quả 111 tới 120 của 159
    Jan 2007
  2. ( namnhatrang ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    hoalinhmobile (22-06-2014), Xuân Toàn (28-05-2014)
    Jan 2007
    ATF WP8.1, SPI, Android and Samsung JTAG v11.40 Update!! Public Discussion Thread: Release Date: May 31, 2014
    Firmware Version Required : 11.0.00
    ATF Box USB Driver Required: 2.10.0.0
    Lumia WP 8.1 + Nokia Android + SPI Programmer + Samsung JTAG
    Nokia Lumia WP 8.1 by Microsoft Initial Support
    --> Updated Windows Phone Flashing Module to support Lumia 630 and 635
    --> Updated Windows Phone Normal Mode Module to Support Lumia 630 and 635
    --> Fully tested on Actual Lumia 630 Test Phone
    --> Test Mode Functions for Lumia 630 and 635 is still not Supported
    Nokia Android Firmware Flasher for X/X+/XL Updated
    --> Fixed Flash Error "62%" when using older WinUSB Drivers
    --> Warns End User when REVISION 2 Flash Files are detected
    --> Fully tested on Actual Nokia X, X+ and XL Actual Test Phones
    ATF JTAG 1.0.8
    --> Added Built-In AFP File Downloader inside ATFJ.exe
    --> You can access it through "Help" ---> "Updates"
    --> Support added for Samsung Phones FULL BOOT Repair
    --> (Download then via the Built-in ATFJ.exe Downloader)
    Samsung GT-I8150
    Samsung GT-I8150B
    Samsung GT-I8150T
    Samsung GT-I8260
    Samsung GT-I8260E
    Samsung GT-I8260L
    Samsung GT-I8262
    Samsung GT-I8262B
    Samsung GT-I8262D
    Samsung GT-I8350
    Samsung GT-I8550L
    Samsung GT-I8550E
    Samsung GT-I8552
    Samsung GT-I8552B
    Samsung GT-I8700
    Samsung GT-S6310
    Samsung GT-S6310L
    Samsung GT-S6310N
    Samsung GT-S6310T
    Samsung GT-S6312
    Samsung GT-S7560
    Samsung GT-S7560M
    Samsung GT-S7562
    Samsung GT-S7562L
    Samsung GT-S7572
    Samsung SCH-W789
    Samsung SCH-I829
    Samsung SGH-T679
    Samsung SGH-T679M
    --> Added ATF JTAG Scripting Language
    Supports Manual Debugging of Snapdragon SOC Modem Core
    --> Initial Documentation Released
    --> http://www.advace-box.com/jtag/ATF_J...ING_MANUAL.pdf
    SPI Tool 1.0 Initial Release
    --> Direct In Circuit Programming for Small SPI Flash ICs
    --> NO NEED to remove SPI Flash from PCB
    --> Ideal for Nokia 105 and 106 Direct SPI Flash Programming
    --> Ideal for HUAWEI WiMax Modem SPI Reprogramming
    --> Read/Write Speeds upto 30 Mhz
    --> Supports CPOL=0, CPHA=0 and CPOL=1, CPHA=1 SPI Modes
    --> Auto Verify and Auto Rewrite Corrupted Sectors
    --> Selectable VCCIO Voltage (1.80v, 2.80v and 3.30v)
    --> Selectable Instruction Set according to SPI Flash IC Brand
    --> Automatically Detects Flash IC Capacity for Micron/Numonyx
    --> Automatically Skips IMEI, Simlocks and PM Region of Nokia 105 and 106
    * When used with Nokia 105 and 106, you can:
    ----> Read Full Dump from 100% Working Phone and write it to another phone without
    damaging the IMEI, Simlocks and PM Region.
    ----> Write MCU+PPM+CNT, or just PPM+CNT or just PPM only
    ----> Allows Cross Version PPM Files to be written on any MCU Firmware Version
    ----> Now you can write your prefered BIG Language Packs which was not supported in FBUS
    ----> You can read FULL DUMP via FBUS and write it to other phones via SPI Tool
    [SD Card Password Bruteforce Update]
    --> Fixed Resume File Saving when CSD was Invalid
    --> Added Support for UHS-I and UHS-II SD Cards
    [Samsung Unbrick Image Creator 1.5]
    --> Added Support for newer 4.4.x tar.md5 2014 Flash Files
    --> Added Support for newer PIT Factory Files
    [ATF Box Driver Update]
    --> New ATF Box Signed Drivers for 32/64 Bit Windows XP, 7, 8 and 8.1 (Version 2.10.0.0)
    --> If you are using Windows 7 or Windows 8, the Drivers will be
    Downloaded Automatically via Windows Driver Update Servers
    [General Updates]
    --> Complete Product Listing in Nokia.ini as of May 31, 2014
    (Nokia X+, Nokia XL, Lumia 630, Lumia 635 and Lumia 930 were added)
    DOWNLOAD HERE:
    https://www.mediafire.com/?p79cclx8wfyk4zc
    ATF_v11.40_Full_Installer - Download - 4shared - Linus Hernandez
    Nov 2010
    ATF Android Root Kit 1.2 Update 11.41 04-June-2013
    Release Date: June 4, 2014
    Download ATF 11.41 via the AUTOUPDATE SERVER!!!
    Nokia Android Root Kit 1.2
    Universal ROOT Method For Nokia X, X+ and XL
    Tested On:
    Nokia X Firmware:
    ----> 10.0.3
    ----> 11.11.1
    ----> 1.1.2.2
    ----> 1.1.3.20 (REVISION 2)
    Nokia X+ Firmware:
    ----> 1.1.0.2
    Nokia XL Firmware:
    ----> 1.1.0.6
    ----> 1.1.1.0 (STOCK)
    ----> 1.1.2.20 (REVISION 2)
    *** After Phone is ROOTED, you can Install Google Services + Launcher
    *** After Phone is ROOTED, you can Backup IMEI, Simlocks
    WARNING:
    ATF DOES NOT USE ADB.EXE or FASTBOOT.EXE. Please make sure that ADB.exe and FASTBOOT.exe are not RUNNING before trying to ROOT your Phone because ATF will automatically close ADB.exe and FASTBOOT.exe even if you are still busy flashing an HTC Phone or doing some other Android Tweaks via ADB...
    For this Update, we give Credits to:
    ----> Chainfire - author of SuperSU.zip
    ----> dhacker29 - author of TWRP for Nokia Android
    ----> Dee Troy - author of TWRP
    ATF Android Root Kit 1.2 v11.41 Update!! Public Discussion Thread:
    ATF WP8.1, SPI, Android and Samsung JTAG v11.41 Update!! Public Discussion Thread:
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - Advance Turbo Flasher - By Advance Team - ATF Lightning - ATF Nitro - Fastest Flasher in world - Nokia flasher - ATF Samsung - First in the world
  5. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Nov 2010
    ATF Pre-Update Surprise 11.45 - June-20-2014
    Release Date: June 20, 2014
    Download ATF 11.45 via the AUTOUPDATE SERVER!!!
    Quick Fix for Nokia X, X+ and XL Flashing
    Nokia Android New Method of
    BACKUP/RESTORE IMEI/SIMLOCKS
    --> fully Compatible with Nokia X+ and XL
    (MODEM_FSG Write is now ENABLED)
    (Requires ROOT).
    ( First in the WORLD )
    This is a pre-release update. If you encounter problems flashing Nokia X, X+ and XL with 11.45, please report it properly here:
    ATF WP8.1, SPI, Android and Samsung JTAG v11.45 Update!! Public Discussion Thread:
    SURPRISE:
    First 15 ATF End Users
    who will show complete successful logs of Full Flashing
    Nokia X, X+ or XL via ATF 11.45 will get
    FREE JTAG Activation for their ATF BOX!
    You need to just create a New
    Thread
    in ATF Section and post Full
    Logs + Screenshot.
    WARNING:
    ADB.exe or FASTBOOT.exe are not RUNNING before trying to ROOT your
    Tweaks via ADB...
  7. #5
    Jan 2007
  8. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Jan 2007
    ATF v11.50 Update!! Public Discussion Thread:
    Release Date: June 27, 2014
    ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
    ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
    Nokia Lumia WP 8.0/8.1
    --> Added "Easy Flashing" Mode for DEAD and ALIVE PHONE
    ----> No need to press VOLUME DOWN Button (Just Connect USB Cable to POWERED OFF PHONE)
    --> Fixed Dead Mode detection on WP 8.0 (bug from 11.45)
    Nokia Android
    --> Added Full IMEI/Simlock Backup/Restore for Nokia X/X+/XL including "V2" Devices
    --> Added Support for Writing Back MODEM_FSG via Partition Restore
    --> Updated TWRP Recovery Image for ROOTING
    --> Full Rooting for ALL Currently Released Nokia Android Phones
    --> Full Google Services Installation Support for all Released Nokia Android Phones
    --> Fixed Firmware Flashing Stall Issues (Thanks to Beta Testers)
    Samsung Unbrick Image Creator 1.6
    --> Added support for older Qualcomm APQ8060 PIT files
    --> Fixed SDC Decrypt Issue on Corrupted SDC Files
    SDC Tool 1.6
    --> Added more delay when detecting older/brandless SD Cards
    eMMC Tool 2.6(PRO)
    --> Added Support to Change Default Boot Partition of eMMC
    --> Added Support for Lumia eMMC using external VccQ & Vcc
    --> Added Support for SmartGsm 4-in-1 Adapter version 2
    --> Added BIG BOOT mmc Files (Latest Firmware Versions)
    520T RM-913 3056.40000.1349.2004
    520 RM-914 3056.40000.1408.0007
    520 RM-915 3056.40000.1402.0008
    521 RM-917 3056.40000.1404.0035
    525 RM-998 3055.40000.1347.1008
    526 RM-997 3055.40000.1347.2002
    620 RM-846 3056.40000.1408.0002
    822 RM-845 3051.40000.1352.0042
    810 RM-878 3043.0000.1326.0017
    720 RM-885 3056.40000.1408.0005
    720T RM-887 3046.0000.1334.0002
    Download eMMC Files Here:
    <<<<<< ALL LUMIA DEAD BOOT REPAIR FILES - Direct Links >>>>>>
    ATF JTAG Updated BIG BOOT FILES (Latest Firmware Versions)
    625 RM-941 3056.40000.1402.1005
    625 RM-942 3056.40000.1349.2003
    625 RM-943 3056.40000.1349.2004
    820 RM-824 3051.40000.1347.1006
    820 RM-825 3051.40000.1351.2006
    820 RM-826 3051.40000.1347.1006
    920 RM-820 3051.40000.1347.1004
    920 RM-821 3051.40000.1351.2005
    920 RM-822 3051.40000.1349.0005
    920T RM-867 3051.40000.1349.0007
    925 RM-892 3051.40000.1351.2004
    925 RM-893 3051.40000.1404.0011
    925 RM-910 3051.40000.1345.1003
    925T RM-955 3048.0000.1328.0001
    928 RM-860 3051.40000.1352.0058
    1020 RM-875 3051.40000.1345.1012
    1020 RM-876 3051.40000.1345.1003
    1020 RM-877 3051.40000.1347.0007
    1320 RM-994 3056.40200.1407.0004
    1320 RM-995 3056.40200.1418.0011
    1320 RM-996 3056.40200.1407.0002
    Download JTAG AFP Files Here:
    <<<<<< ALL LUMIA DEAD BOOT REPAIR FILES - Direct Links >>>>>> - GSM-Forum
  10. #7
    Nov 2010
  11. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    gamoi.gsm (14-07-2014)
  12. #8
    Jan 2007
    ATF v11.50 + ATF JTAG 1.0.9 Update Public Discussion Thread:
    ATF JTAG 1.0.9 build 4684
    Release Date: July 1, 2014
    Cherry Mobile Update
    CM Hyper Full Factory Restore + EFS Write
    ~---> Repairs Phone Back to Original State
    ~---> Works on blank eMMC or Replaced eMMC
    CM Flare 2.0 Full Factory Restore + EFS Write
    CM Titan 2.0 Full Factory Restore + EFS Write
    Download Links:
    ATFJ 1.0.9 build 4684 - EXE ONLY
    Cherry Mobile AFP Factory Repair Files
    Nokia Android
    SDC Tool 1.6
    eMMC Tool 2.6(PRO)
  13. #9
    Jan 2007
    Download Links:
    Nokia Android
    SDC Tool 1.6
    eMMC Tool 2.6(PRO)
  14. #10
    Nov 2010
    ATF 11.60 Update!! 21 JUL 2014!!
    Release Date: July 21, 2014
    Added Nokia Lumia WP8.1 and Android Dead Boot Repair via eMMC (July 2014 Files)
    <<<<<< ALL NOKIA LUMIA/ANDROID DEAD BOOT REPAIR FILES - Direct Links >>>>>>
    Lumia 630 RM-974 - via eMMC - Exclusive
    Lumia 630 RM-976 - via eMMC - Exclusive
    Lumia 630 RM-977 - via eMMC - Exclusive
    Lumia 630 RM-978 - via eMMC - Exclusive
    Lumia 630 RM-979 - via eMMC - Exclusive
    Lumia 636 RM-1010 - via eMMC - Exclusive
    Lumia 638 RM-1027 - via eMMC - Exclusive
    Nokia XL RM-1030 1.1.1.0 - via eMMC
    Nokia XL RM-1030 1.1.1.4 - via eMMC
    *** Take note that "via eMMC" Files are 100% FREE and NO NEED ACTIVATION!
    Samsung Unbrick Image Creator 2.0
    --> Added Automatic Detection of Required SD Card Size
    --> Fixed Missing Partitions on APQ8060 and MSM8930 PIT Files
    --> PIT Info (OPEN RESIZABLE or CLOSED NON RESIZABLE) now shown in LOGS
    --> Number of Partitions written Now Shown in Logs
    --> Intended Default eMMC Size Now Shown in Logs
    *** Please note that an "OPEN" PIT file means SDC File will work with any
    *** eMMC Size (4GB, 8GB, 16GB, 32GB, 64GB 128GB etc...) and a
    *** "CLOSED" Pit file means SDC File will only work with a specific eMMC SIZE.
    Try Out New SDC Unbrick Files Created by Image Creator 2.0
    SAMSUNG SDC FILES by Linus H. - 4shared
    GT-I9295_4.2.2_16GB_I9295XXUBML3.sdc
    GT-I9295_4.4.2_16GB_I9295XXUCNF1.sdc
    GT-I9505_4.2.2_16GB_I9505XXUBMEA.sdc
    GT-I9505_4.3_16GB_I9505XXUEMKF.sdc
    GT-I9505_4.4.2_16GB_I9505XXUFNBA.sdc
    GT-I9505G_4.2.2_16GB_I9505GUEUAMFD.sdc
    GT-I9507_4.2.2_16GB_I9507ZHUAMJ1.sdc
    GT-I9507V_4.2_16GB_I9507VZNUANB3.sdc
    SC-04E_4.3_32GB_SC04EOMUBNC3.sdc
    SCH-I535_4.0.4_32GB.sdc
    SCH-I535_4.0.4_16GB.sdc
    SCH-I535_4.3_16GB.sdc
    SCH-I535_4.3_32GB.sdc
    SCH-I535_4.3_64GB.sdc
    SCH-I545_4.3_16GB_I545VRUEMK2.sdc
    SCH-I545_4.4.2_16GB_I545VRUFNC5.sdc
    SCH-R970_4.2.2_16GB_R970TYUFND1.sdc
    SCH-R970_4.3_16GB_R970TYUEMK2.sdc
    SCH-R970C_4.3_16GB_R970CVRUEMK4.sdc
    SCH-R970C_4.4.2_16GB_R970CVRUFND1.sdc
    SGH-I337_4.3_16GB_I337UCUEMK2.sdc
    SGH-I337_4.4.2_16GB_I337UCUFNB1.sdc
    SGH-I337M_4.2.2_16GB_I337MUMUAMJ1.sdc
    SGH-I337M_4.3_16GB_I337MUMUEMK6.sdc
    SGH-I337M_4.4.2_16GB_I337MUMUFNE2.sdc
    SGH-I337Z_4.4.2_16GB_I337ZTUUBNE2.sdc
    SGH-I537_4.2.2_16GB_I537UBUAMG2.sdc
    SGH-I537_4.3_16GB_I537UCUBML2.sdc
    SGH-M919_4.3_16GB_M919UVUEMK2.sdc
    SGH-M919_4.4.2_16GB_M919UVUFNB4.sdc
    SGH-M919N_4.3_16GB_M919NUVUEMK5.sdc
    SGH-M919V_4.3_16GB_M919VWXUEML3.sdc
    SGH-M919V_4.2.2_16GB_M919VWXUAMH1.sdc
    SGH-M919V_4.4.2_16GB_M919VWXUFNE2.sdc
    SGH-S970G_4.2.2_16GB_S970GUDUAMH3.sdc
    SGH-N075_4.3_32GB.sdc
    SM-G7102_4.3_8GB_G7102XXUANE2.sdc
    SM-P605_4.3_16GB_P605XXUBMJ9.sdc
    SM-P605_4.4.2_16GB_P605XXUCNF2.sdc
    SM-S975L_4.3_16GB_S975LUDUANB1.sdc
    SPH-L720_4.4.2_16GB_L720VPUFNAE.sdc
    SPH-L720T_4.3_16GB_L720TVPUAMK5.sdc
    SPH-L720T_4.4.2_16GB_L720TVPUBNC6.sdc
    *** If Unbrick via SDC Does not work, you can try Unbrick via JTAG which is already
    *** Supported by ATF JTAG 1.0.10
    MAYBE YOU WANT FREE ACTIVATION? Check our forum here for more INFO:
    http://http://forum.gsmhosting.com/vbb/f609/
    ATF Network Update
    --> Removed SL3 Credits Checking for Faster Transaction
    ATF JTAG 1.0.10 Build 4755
    Firmware Version Required : LogiCore 11.0.00
    Change Log
    --> Added New Method for Reading UNLOCK Codes from LIVE Lumia 610, 610C, 510 and 505
    -----> V3 Unlock Method makes it SUPER EASY to read Unlock Codes (ALL LEVELS) from
    -----> LIVE 610, 610C, 510 and 505 Phones.
    --> Added Support for Samsung Qualcomm LTE Phones CUSTOM READ/WRITE Flash Storage
    -----> SAMSUNG_LTE_CUSTOM_READ_WRITE.afp
    Supported CPU:
    APQ8064, APQ8064-AU, APQ8064AB, APQ8064T, APQ8060,
    APQ8060A, MSM8230, MSM8230AB, MSM8630, MSM8630AB,
    MSM8930, MSM8930AB, MSM8260, MSM8260A, MSM8660,
    MSM8660A, MSM8960, MSM8960 Lite, MSM8960T
    Supported Storage:
    eMMC, NOR, NAND, SPI
    --> Added Full Boot Repair with Multi-Version BOOTS for the Following Samsung Phones:
    Samsung GT-i9295 : 4.2.2 + 4.4.2
    Samsung GT-i9505 : 4.2.2 + 4.3 + 4.4.2
    Samsung GT-i9505G : 4.2.2
    Samsung GT-i9507 : 4.2.2 FIRST IN THE WORLD
    Samsung GT-i9507V : 4.3 FIRST IN THE WORLD
    Samsung SC-04E : 4.3
    Samsung SCH-i545 : 4.3 + 4.4.2
    Samsung SCH-R970 : 4.3 + 4.4.2
    Samsung SCH-R970C : 4.3 + 4.4.2
    Samsung SGH-i337 : 4.3 + 4.4.2
    Samsung SGH-i337M : 4.2.2 + 4.3 + 4.4.2
    Samsung SGH-i337Z : 4.4.2
    Samsung SGH-i537 : 4.2.2 + 4.3
    Samsung SGH-M919 : 4.3 + 4.4.2
    Samsung SGH-M919N : 4.3 FIRST IN THE WORLD
    Samsung SGH-M919V : 4.2.2 + 4.3 + 4.4.2
    Samsung SGH-S970G : 4.2.2 FIRST IN THE WORLD
    Samsung SM-S975L : + 4.3 FIRST IN THE WORLD
    Samsung SPH-L720 : 4.4.2
    Samsung SPH-L720T : 4.3 + 4.4.2
    You can download the AFP Files from "Help" ---> "Updates" in ATFJ Software or via
    Direct Links from 4shared here:
    SAMSUNG by Linus H. - 4shared
    *** Please Take Note that each AFP is compatible with any eMMC Storage Size (16GB, 32GB or 64GB).
    *** ATFJ will automatically rewrite MBR and GPT to accommodate actual eMMC Size UNLESS if PIT File
    *** is LOCKED to a Specific eMMC Size.
    --> Added High Firmware Version BIG BOOT FILES for ALMOST ALL Nokia LUMIA and ANDROID PHONES
    Lumia 520 RM-914 [3056.40000.1408.0007] [BIG BOOT V2]
    Lumia 520 RM-915 [3056.40000.1402.0008] [BIG BOOT V2]
    Lumia 520T RM-913 [3056.40000.1349.2004] [BIG BOOT V2]
    Lumia 521 RM-917 [3056.40000.1404.0035] [BIG BOOT]
    Lumia 525 RM-998 [3055.40000.1347.1008] [BIG BOOT]
    Lumia 526 RM-997 [3055.40000.1347.2002] [BIG BOOT]
    Lumia 620 RM-846 [3056.40000.1408.0002] [BIG BOOT]
    Lumia 625 RM-941 [3056.40000.1402.1005] [BIG BOOT]
    Lumia 625 RM-942 [3056.40000.1349.2003] [BIG BOOT]
    Lumia 625 RM-943 [3056.40000.1349.2004] [BIG BOOT]
    Lumia 720 RM-885 [3056.40000.1408.0005] [BIG BOOT]
    Lumia 720T RM-887 [3046.0000.1334.0002] [BIG BOOT]
    Lumia 820 RM-824 [3051.40000.1347.1006] [BIG BOOT]
    Lumia 820 RM-825 [3051.40000.1351.2006] [BIG BOOT V2]
    Lumia 820 RM-826 [3051.40000.1347.1006] [BIG BOOT]
    Lumia 920 RM-820 [3051.40000.1347.1004] [BIG BOOT]
    Lumia 920 RM-821 [3051.40000.1351.2005] [BIG BOOT]
    Lumia 920 RM-822 [3051.40000.1349.0005] [BIG BOOT]
    Lumia 920T RM-867 [3051.40000.1349.0007] [BIG BOOT]
    Lumia 925 RM-892 [3051.40000.1351.2004] [BIG BOOT]
    Lumia 925 RM-893 [3051.40000.1404.0011] [BIG BOOT]
    Lumia 925 RM-910 [3051.40000.1345.1003] [BIG BOOT]
    Lumia 925T RM-955 [3048.0000.1328.0001] [BIG BOOT]
    Lumia 928 RM-860 [3051.40000.1352.0058] [BIG BOOT]
    Lumia 1020 RM-875 [3051.40000.1345.1012] [BIG BOOT]
    Lumia 1020 RM-876 [3051.40000.1345.1003] [BIG BOOT]
    Lumia 1020 RM-877 [3051.40000.1347.0007] [BIG BOOT]
    Lumia 1320 RM-994 [3056.40200.1407.0004] [BIG BOOT]
    Lumia 1320 RM-995 [3056.40200.1418.0011] [BIG BOOT]
    Lumia 1320 RM-996 [3056.40200.1407.0002] [BIG BOOT]
    Nokia X RM-980 [1.1.2.2] [FULL BOOT]
    Nokia X RM-980 [10.0.3] [FULL BOOT]
    Nokia X RM-980 [11.1.1] [FULL BOOT]
    Nokia X V2 RM-980 [1.1.3.20] [FULL BOOT] <--- For V2 Phones ONLY!!!
    Nokia X RM-981 [1.1.0.1] [FULL BOOT]
    Nokia X+ RM-1053 [1.1.0.2] [FULL BOOT]
    Nokia XL RM-1030 [1.1.0.6] [FULL BOOT]
    Nokia XL RM-1030 [1.1.1.0] [FULL BOOT]
    Nokia XL RM-1030 [1.1.1.4] [FULL BOOT]
    Nokia XL V2 RM-1030 [1.1.2.20] [FULL BOOT] <--- For V2 Phones ONLY!!!
    via Direct Links from 4shared here:
    FOR THIS UPDATE WE WOULD LIKE TO SPECIALLY THANK THE FOLLOWING PEOPLE:
    LEMOR, SMARTGSMTEAM, JACOB OF DAVAO CITY, and all the BETA TESTERS of SAMSUNG LTE JTAG.
    __________________________________________________ ________________________
    ATF v11.60 Update!! Public Discussion Thread:
    ATF 11.60 Update!! Public Discussion Thread:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    The Master Piece
  1. Update Mcn-pro anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum McnPro Box
    Trả lời: 91
    Bài viết cuối: 31-01-2015, 07:58
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Update Z3X China anh em vui lòng post ở đây
    By htv1810 in forum Z3X Dongle for Сhina Editor
    Trả lời: 16
    Bài viết cuối: 26-04-2012, 17:30
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
