Trang 15 của 16 Đầu tiênĐầu tiên ... 5 6 7 8 9 10 11 12 13 14 15 16 CuốiCuối
Kết quả 141 tới 150 của 153
  1. #141
    Jan 2007
    Infinity-Box BEST NK2 v1.04 - Nokia MTK standalone support activated
    ATTENTION: To run this software you should copy licence file license_xxxxxxxx.dat from /BEST/ folder to /BEST2/ folder
    Nokia MTK standalone support activated !
    - Main
    MTK SP line support activated !
    For now the next features are supported:
    Nokia 1: FRT : FRONTIER : TA-1047/TA-1060/TA-1056/TA-1079/TA-1066
    Flashing ( Factory/BEST NB0 files )
    Dead Boot repair
    Reset Settings / FileSystem
    Reset FRP
    Identify
    Repair Security
    SP Unlock
    Nokia 3: NE1 : ESSENTIAL1 : TA-1020/TA-1028/TA-1032/TA-1038
    Reset FRP
    Identify
    Repair Security
    SP Unlock
    Nokia 3.1: ES2 : ESSENTIAL2 : TA-1049/TA-1057/TA-1063/TA-1070/TA-1074/
    Dead Boot repair
    Reset FRP
    Identify
    Repair Security
    SP Unlock
    - Other
    Flashing core revised
    Info:
    - MTK devices support is free and standalone
    - Firmwares can be found on support area
    - Firmware files need only for flashing, rest operations not require them
    - Make sure you select correct files for your device! ( Nokia 3 specific for now )
    Download and install latest MTK and QLM smartphones drivers:
    /pub/software/Drivers/Drivers_Nokia_HMD_2018-07-10
    Download link
  2. #142
    Jan 2007
    Infinity-Box [BEST] NK2 v1.05 - Nokia 3310(2G), Nokia 5.1 and other models support activated
    Nokia 3310(2G), Nokia 5.1 and other models support activated !
    - Nokia MTK Feature line support activated
    - Nokia 3310(2G) line support activated !
    Next revision of 3310 (2G) are supported:
    Nokia 3310 : RETRO : TA-1008/TA-1030
    > Firmware flashing ( Factory/BEST firmware packages )
    > Firmware reading
    > Format FS / Reset Settings
    > Identify ( read complete device info & check/verify security area )
    Other models support enabled ( supported in BEST v1.xx line ) :
    Nokia 108: RM-944, RM-945, RM-1124
    Nokia 220: RM-969, RM-970, RM-971, RM-1125
    Nokia 225: RM-1011, RM-1012, RM-1043
    Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122
    Nokia 215: RM-1110, RM-1111, RM-1112
    Nokia 105: RM-1133, RM-1134, RM-1135
    Nokia 222: RM-1136, RM-1137
    Nokia 230: RM-1172, RM-1173
    Nokia 216: RM-1187, RM-1188
    Nokia 150: RM-1189, RM-1190
    > Firmware reading
    Changes from v1.xx line:
    Complete protocol rebuild - faster, safer, more stable
    FW read/make now direct, do not need additional read/convert operations
    FW read now more faster
    Devices not stuck in flash mode after some operations
    - Nokia 5.1 : CO2 : TA-1061/TA-1075/TA-1076/TA-1081/TA-1088
    > Reset FRP
    > Identify
    > Repair Security
    > SP Unlock
    Support is standalone, no server and/or credits required !
    - Changes/Fixes
    > MTK SP line
    Fixed BROM mode support
    Fixed dead mode flashing
    Fixed SP unlock
    Improved flashing in MTK mode
    Fixed issues with FOTA after flashing
    > QLM SP line
    Removed legacy servicing methods
    Flashing engine updated
    - Other
    Settings Tab activated
    > Setup FeaturePhones DataPackage path
    > Setup SmartPhones DataPackage path
    > Setup IOS user credentials ( for use server-based operations )
    Lot of fixes and global changes at all
    - Support
    Hundreds of firmwares for Nokia 3310 (2G) are in support area
    > Check out for need region packages or language packages on support area first! Or read from any well working device which you have.
    Nokia 230: RM-1172, RM-1173 - HMD and MS LEGACY different firmwares are in support area
    Nokia 216: RM-1187, RM-1188 - HMD and MS LEGACY different firmwares are in support area
    Nokia 150: RM-1189, RM-1190 - HMD and MS LEGACY different firmwares are in support area
    Download link
  3. #143
    Jan 2007
    Infinity-Box [BEST] NK2 v1.06 - FP Forensic and other changes
    - Activated Forensic engine for MTK feature line devices
    Allow extract phonebook memory from alive/dead/semi-dead devices
    Extraction is direct ( from device )
    Support unicode
    Following models are supported for PhoneBook extraction:
    Nokia 3310(2G): TA-1008, TA-1030
    - Changes/Fixes
    > MTK FP line
    Fix/Change: Flash reading on some configurations may fail, fixed
    New feature: Activated speed selection setting (see software settings tab) Default value - Normal. Speed TOO MUCH depend on this configuration value !
    Fix/Change: Flash engine revised
    New feature: Activated complete FlashPackage verification during FWSelect and Flashing
    > MTK SP line
    Download link
  4. #144
    Jan 2007
    Infinity-Box [BEST] NK2 v1.07 - Nokia 130 (2017) support and new features
    - Nokia 130 (2017) line support activated !
    Next revision of Nokia 130 (2017) are supported:
    Nokia 130 (2017): KESA : TA-1017/TA-1019
    > Firmware reading
    - Changes/Fixes
    > MTK FP line
    Fix/Change: Flash engine revised : Automatic Repair Mode enable, if device semi-dead
    Fix/Change: AutoID in case of semi-dead device state may fail, fixed
    - Support
    Hundreds of firmwares for 130 (2017) have been uploaded to support area
    > Check out for required region packages or language packages in support area first! Also you can read from any good working device that you have.
    Download link
  5. #145
    Jan 2007
    Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features
    - Forensic engine for MTK feature line devices rebuild from scratch
    From now allow extract phonebook from memory dump ( made by external prommer or older BEST versions )
    > Press and hold SHIFT key before press "Extract PhoneBook" button for enable File mode
    Extraction is direct (from device) and from dump
    Support unicode
    All existing MTK FP models are supported now for PhoneBook extraction:
    Nokia 105(2017) : TA-1010, TA-1034, TA-1037
    Nokia 130(2017) : TA-1017, TA-1019
    - Changes/Fixes
    > MTK FP line
    New feature: SW version check during flashing activated. SW will verify data between phone and VPL.
    > In case of device dead ( no SW version data available ) - SW will warn about it.
    New feature: Complete language info during FlashFile selection ( will show all existing languages without need of manual flashing and verify )
    > MTK SP line
    Fix/Change : Flash engine revised
    Fix/Change : Repartition may fail during NK1 flashing, fixed
    Download link
  6. #146
    Jan 2007
    Infinity-Box [BEST] NK2 v1.10 - Nokia 3310 3G support and new features
    - Nokia SPRD tab activated
    Nokia 3G SS [TA-1006] supported
    Nokia 3G SS [TA-1022] supported
    Nokia 3G DS [TA-1036] supported
    - Identify
    - Reset Settings / Format FS
    - Firmware Flashing ( cross, nvm update, lang change )
    Info: Device security paired, store all NV backups to emergency case !
    Info: Crossflashing can be done and not touch security ( require enable NV update )
    - Nokia SP tab changes
    Identify now read BOTH part info for A/B devices
    Flash Engine updated
    "UserData preserve" mode updated
    Format FS / Reset FRP revised
    Nokia 5.1+ ( Nokia X5 ) supported ( TA-1102, TA-1105, TA-1108, TA-1109, TA-1112, TA-1120 )
    Nokia 3.1+ supported ( TA-1104, TA-1113, TA-1115, TA-1117, TA-1118, TA-1125 )
    - Identify
    - Reset Settings / Format FS / Reset FRP
    - Firmware Flashing
    - Nokia FP tab changes
    PhoneBook extraction engine updated
    Extract "from file" revised
    Download link
  7. #147
    Jan 2007
    Infinity-Box [BEST] NK2 v1.11 - More MTK and SPRD features activated
    - Nokia SPRD tab
    Activated Flash Dump feature
    Support another signed base driver ( can be found on support for both x86 and x64 systems )
    FlashEngine updated
    - Nokia MTK SP tab changes
    MT6755 line has been broken in previous release, fixed
    - Nokia MTK FP tab changes
    Backup security feature released, allow store device security
    Restore security feature released, allow restore device security backups
    Backup now also made during "Identify"
    During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set )
    - Other
    Minor bugfixes and changes
    - Additional info
    SPRD flash backups can be sent for processing via IOS FileUploader for adding new LangPacks on support.
    ETA of processing - 48 hours, then files can be found on support. All other ways will be ignored.
    NEW SPRD DRIVERS should be installed !
    Download link
  8. #148
    Jan 2007
    Infinity-Box [BEST] NK2 v1.12 - Nokia 106 (2019) line support activated
    Next revision of Nokia 106 (2019) are supported:
    Nokia 106 (2019) : NEMO : TA-1114
    > Firmware reading
    > Backup security
    > Restore security
    > Repair security ( via SWP )
    > SP unlock ( via SWP )
    > Complete repair ( via SWP )
    *SWP feature allowed due to Nokia security flaw, made in Nokia 106 and affect this model only for now.
    - Base
    Loader database updated
    Bugfixes and minor changes
    - Support
    Some firmwares for Nokia 106 can be found on support now
    Download link
  9. #149
    Jan 2007
    Infinity-Box [BEST] NK2 v1.13 - Universal Flasher/Unbricker, more Forensic and other stuff !
    MTK SP tab
    - Flasher engine updated
    Allow unbrick/repair almost all SW-related issues during flashing from now ( specially A/B devices )
    Fixed memory partitioning issues on fresh devices
    - Reset Settings/Format FS updated
    - Safe UserData flashing feature updated
    - Pre-Erase option can be activated/de-activated depend on user need
    MTK FP tab
    - Dead mode flashing revised ( incorrect identification during flashing semi-dead device )
    - Firmware reader engine updated
    - LangPack info extractor updated
    - Forensic engine updated
    Nokia 106 PhoneBook extraction activated/de-activated
    Universal Gallery extractor activated
    *Allow extract : Photos ( if device have camera ) , Audio records , Browser BookMarks and History ( Built-in MTK and Opera Mini supported )
    *Support all existing MTK Feature devices, made by Microsoft and HMD Nokia
    *Support Direct (from phone) and Dump (from file) mode
    Phonebook extraction updated
    SPRD FP tab
    - FullFlash reading optimized
    Unfortunately, all dumps, made by v112 are not usable. Please, repeat reading with new version, if you need get LangPacks.
    - Flash Engine updated
    - NVRAM verify and check revised
    Other
    - Some bugfixes and changes
    Support
    - All latest firmwares can be found on support !
    Download link
  10. #150
    Jan 2007
    Infinity-Box [BEST] NK2 v1.14 - Nokia 210 (2019) Full support activated
    Next revision of Nokia 210 (2019) are supported:
    Nokia 210 (2019) : TA-1139
    > Firmware reading
    > Backup security
    > Restore security
    > Forensic ( Gallery/Browser History/Browser BookMarks )
    *SWP feature allowed due to Nokia security flaw, made in Nokia 210 and affect this model only for now.
    *CROSS-SWP between affected models not allowed for now!
    - Base
    - Support
    Some firmwares for Nokia 210 can be found on support now
    Download link
  1. BB5 Easy Service Tool (BEST) Nokia Dongle new update
    By TUYHOAGSM™ in forum Infinity Box
    Bài viết cuối: 09-06-2015, 14:08
  2. BB5 Easy Service Tool (BEST) xin giúp
    By tuân gsm in forum Infinity Box
    Bài viết cuối: 24-05-2013, 20:54
  3. XIN GIÚP TOOL Nokia Best (BB5 Easy Service Tool Crack) MỚI NHÂT!
    By qthangmobile in forum Tool - Soft và phần mềm free!
    Bài viết cuối: 12-03-2013, 19:49
  4. BB5 Easy Service Tool [BEST] Dongle
    By saigonmobile in forum GIỚI THIỆU THIẾT BỊ - CABLE - GIẢI PHÁP MỚI NHẤT
    Trả lời: 26
    Bài viết cuối: 11-09-2012, 12:49
  5. Infinity-Box: BB5 Easy Service Tool [BEST] v1.08 released
    By hungphongmobile™ in forum Infinity Box
    Bài viết cuối: 08-09-2010, 01:00
