Kết quả 11 tới 17 của 17
    Nov 2010
    C1-02 flash ok by BesTool máy mất nguồn ATF ngồi ngó
    Selected FlashSettings : Manual
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : rm643__05.45.mcusw
    PPM : rm643__05.45.ppm_v
    CNT : rm643__05.45.image_v_0597711
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    Waiting for USB device...
    -> If Windows say "Unrecognized device" - just reinsert battery
    -> If flashing freeze - reinsert cable and try again
    --- Press phone's power button or insert charger! ---
    Connection opened successfully
    DBG : F00A1FB300020303010100FF
    CPUID : SGOLD 213
    2nd boot Ok, 01
    2nd ready, AA
    Sending Algo
    Algo sent Ok
    BL : Quantum_Bootloader_2.5_M1S1
    Speed accepted, use 6.500.000
    FLASHID : 89008289
    FLIC conf set, RST set
    Boot done!
    ===Flashing [MCU]===
    File : rm643__05.45.mcusw
    Image : rm643__05.45.mcusw_ebl_psi.fls
    Cert block found, sending....
    Cert sent
    Found 5 region(s)
    Processing Region 1/5
    Erase , Start : 0x40000000 , Len : 0x00020000
    Erasing, wait ...
    Erase done, time : 00:00:00
    Write , Start : 0x40000000 , Len : 0x00020000
    Flashing , wait ...
    Region flash done, time : 00:00:00
    Processing Region 2/5
    Erase , Start : 0x40040000 , Len : 0x00040000
    Erasing, wait ...
    Erase done, time : 00:00:01
    Write , Start : 0x40040000 , Len : 0x00040000
    Flashing , wait ...
    Processing Region 3/5
    Erase , Start : 0x40080000 , Len : 0x00020000
    Erasing, wait ...
    Write , Start : 0x40080000 , Len : 0x00020000
    Flashing , wait ...
    Processing Region 4/5
    Erase , Start : 0x400A0000 , Len : 0x00100000
    Erasing, wait ...
    Erase done, time : 00:00:05
    Write , Start : 0x400A0000 , Len : 0x00100000
    Flashing , wait ...
    Region flash done, time : 00:00:01
    Processing Region 5/5
    Erase , Start : 0x40400000 , Len : 0x01800000
    Erasing, wait ...
    Erase done, time : 00:02:07
    Write , Start : 0x40400000 , Len : 0x01780000
    Flashing , wait ...
    Region flash done, time : 00:00:34
    ===Flashing [PPM]===
    File : rm643__05.45.ppm_v
    Image : package_v.ppm_ebl_psi.fls
    Cert sent
    Found 1 region(s)
    Processing Region 1/1
    Erase , Start : 0x41C00000 , Len : 0x00600000
    Erasing, wait ...
    Erase done, time : 00:00:22
    Write , Start : 0x41C00000 , Len : 0x0040BEA8
    Flashing , wait ...
    Region flash done, time : 00:00:04
    ===Flashing [CNT]===
    File : rm643__05.45.image_v_0597711
    Image : package_v_0597711.image.fls
    Cert sent
    Found 2 region(s)
    Processing Region 1/2
    Erase , Start : 0x42200000 , Len : 0x01C60000
    Erasing, wait ...
    Erase done, time : 00:03:14
    Write , Start : 0x42200000 , Len : 0x00D40000
    Flashing , wait ...
    Region flash done, time : 00:00:17
    Processing Region 2/2
    Erase , Start : 0x43E60000 , Len : 0x000E0000
    Erasing, wait ...
    No write data, skip
    Flashing done!
    Total flash time : 00:06:57
    Reboot phone now...
    Afterflash not selected, skip
    Done!
    Connect phone on selected interface...
    Elapsed: 00:07:08
    Phone found!
    Series 40 Device detected!
    read info... - Ok
    Reading Phone Info....
    Connected phone - C1-02
    Software ver : V 05.45 22-06-11 RM-643 (c) Nokia
    IMEI : 354334043609218
    Ape Ver :
    APE Var :
    APE ADSP:
    DSP Ver :
    APE Test:
    PPM : V 05.45 22-06-11 RM-643 (c) Nokia V
    CNT : Content: v_0597711 V 05.45 22-06-11 RM-643 (c) Nokia
    Product SN : 012E734AH
    Product code : 059B0F6
    Base Prd.code: 0591126
    Module code : 0204487
    Long Prod.SN : 0
    Hardware info=======
    HWID : 1000
    Retu :
    Tahvo :
    Batery: 4019 mV
    Camera:
    CMT BT: 19b5-22012
    APE BT:
    APE HW:
    LCDVer: AUO
    RF ic :
    Lock info ===========
    IMEI spNet : 3A 45 33 04 34 06 29 01
    IMEI svNet : 33 45 33 04 34 06 29 11 F6
    Sl Conf : 001-01-00000000000
    Sl Prof : 800000000003000-B
    Sl Aux : 000B0000
    Hw Sig : E74818AF40D9D969
    Provider : Default Test Operator
    Lock info:
    Block 1
    L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
    Block 2
    Block 3
    Block 4
    Block 5
    Block 6
    Block 7
    CRT308 Backup Created
    INFINEON : SuperDongle not exist (It is Ok)
    SimLock status : Ok
    Security status : Ok
    PA_SL3 phone , SP_CODE_LEN : 15
    User Code : 12345
    MMC pwd : no any record found
    UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
    Done!
    Resetting selected items...
    Check phone mode...
    Phone already in Test mode, skip change...
    Settings Full Factory Defaults...
    Set OK!
    Settings Software Upgrade Defaults...
    Set OK!
    Settings Service Centre Defaults...
    Set OK!
    Settings Production Tune Defaults...
    Set OK!
    Settings User Data Defaults...
    Set OK!
    Settings Leave Factory defaults...
    Set OK!
    Elapsed: 00:00:01
    Nov 2010
    Lumia 710 RM-803 Flashing.... OK - Máy xách tay Hàn Quốc
    Thành viên tích cực hieungau1983's Avatar
    Dec 2008
    cho em xin cái linh loat về dùng cái bác ơi
    Jan 2009
    Hải Phòng
    flash ok 5310 by best dongle . mx, atf not ok
    card found: S/N 3F6F:0118
    registered to: sonsay
    Core : v1.47 , FlashEngine : v1.5
    MCU : rm303__10.10.mcusw
    PPM : rm303__10.10.ppm_c
    CNT : rm303__10.10_ISM_006.image_movi_es2_blue
    Check files done...
    Getting product info...
    --- Press phone's power button or insert cable & charger! ---
    Waiting for communication response.
    ASIC ID: 000000010000022600010006010C192101013000
    CPU ID : RAP3Gv3 , Features : No any extended features
    RAP_PUB: 205002130B280354D0053EAA9B72A59A75A86CE0
    CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1
    PatchRAWLoader: Patched OK
    Processing RAWLOADER...
    Processing UPDAPP...
    Processing PASUBTOC...
    TIME : Boot time : 00:00:06
    Reopening the connection...
    Waiting for response: 30
    ADL -> [2nd] changing...
    ADL Server confirm flashmode!
    ADL : Check data
    ADL : Data accepted
    ADL : ASIC CMT select Ok
    Erase : Processing rm303__10.10.mcusw
    Found 6 areas to erase
    Erasing area 0x00000000 - 0x000006BF, NOR, CMT
    Result: 0000
    Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
    Result: 0000
    Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00140000 - 0x010DFFFF, NOR, CMT
    Result: 0000
    Erasing area 0x010E0000 - 0x0121FFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:01:03
    Write : Processing rm303__10.10.mcusw
    Total 1107 [1107/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [NOLO]
    CMT : Writing Hash CERT [KEYS]
    CMT : Writing Hash CERT [PRIMAPP]
    CMT : Writing Hash CERT [PASUBTOC]
    CMT : Writing Hash CERT [PAPUBKEYS]
    CMT : Writing Hash CERT [UPDAPP]
    CMT : Writing Hash CERT [DSP0]
    CMT : Writing Hash CERT [MCUSW]
    TIME : Write time : 00:01:29
    MCU Write done
    Erase : Processing rm303__10.10.ppm_c
    Found 1 areas to erase
    Erasing area 0x01220000 - 0x0189FFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:00:23
    Write : Processing rm303__10.10.ppm_c
    Total 266 [266/0/0] blocks to write, writing...
    TIME : Write time : 00:00:22
    PPM Write done
    Erase : Processing rm303__10.10_ISM_006.image_movi_es2_blue
    Found 2 areas to erase
    Erasing area 0x018A0000 - 0x01B1FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x01B20000 - 0x03FBFFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:02:50
    Checking content info...
    Check Image : Content size is 128k, use direct write mode
    Write : Processing rm303__10.10_ISM_006.image_movi_es2_blue
    Total 1152 [1152/0/0] blocks to write, writing...
    TIME : Write time : 00:01:38
    CNT Write done
    ADL : End flashing
    Flashing done!
    Total flash time : 00:07:47
    Reboot phone now...
    Connected phone - Nokia 5310 XpressMusic
    Software Info: V 10.10 23-03-09 RM-303 (c) Nokia
    IMEI: 356419028698324
    PPM version : V 10.10 07-05-11 Xperia Edit:Huongdc@ovi.com I
    Product code: 0565806
    Checking...
    SimLock status : SimLock is Ok
    Security status : Security is Ok
    Read Info Done!
    Settings After Flash Defaults...
    ProductTuneSet...OK!
    SwUpgradeSet...OK!
    Checking User Certificates...
    Total - 0 certs
    Uploading certificates...
    Writen 21 certs!
    AfterFlash operations done ;D
    Done!
    Elapsed: 00:08:26
    Phone found!
    read info... - Ok
    Phone disconected!
    Thành viên chính thức mjnhtuan123's Avatar
    Nov 2010
    best tooln ok thiêt,mới flash tv cho n8 rm 596
    máy xach tay về.flash mất gần 2p.
    Jan 2009
    Hải Phòng
    flash nokia bb5 sl3 500 RM-750 thành công sau 41 giây
    Core : v1.48 , FlashEngine : v1.7
    -> File : RM750_005_000_M019_2G.fpsx not found! Check it!
    MCU : RM-750_011.033_71i92_prd.core.fpsx
    PPM : RM-750_011.033_19.01_Vietnam_71i92_prd.rofs2.fpsx
    PPM2 : RM-750_011.033_C02.01_SEAP_71i92_prd.rofs3.fpsx
    CNT : RM-750_v0.007_APEONLY_prd.fpsx
    APE : RM-750_011.033_U03.01_71i92.uda.fpsx
    Check files done...
    --- Insert cable and charger or press phone's power button! ---
    Waiting for communication response...
    BootRom : 1st boot ok
    ASIC ID: 000000030000022600010007400C192103032108
    CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB
    EM0 ID: 00001040
    EM1 ID: 00001060
    PUBLIC ID: 421A0000FFFB3C403E040DA19B2F82F79DDB6925
    ASIC MODE ID: 00
    ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
    ROM ID: 2CAC45E23BC33C8B
    Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0
    FLIC : 005000EC
    Req : XSR 1.6
    Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0
    Processing PASUBTOC ...
    Processing ALG ...
    Boot Done!
    TIME : Boot time : 00:00:02
    Waiting for response: 29
    ADL: Check mode
    Select ASIC [C900]
    PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0
    ADL: phone is in flash mode
    Backup enabled, will read all certificates...
    Reading NPC certificate...
    IMEI : 359744045594728
    Reading CCC certificate...
    Reading HWC certificate...
    Reading R&D certificate...
    Reading VARIANT certificate...
    Reading PARTNERC certificate...
    Reading MDM_KEYS certificate...
    Cert Read done!
    NPC Certificate saved...
    CCC Certificate saved...
    HWC Certificate saved...
    RPL saved : c:\InfinityBox\BEST\Backup\Cert\359744045594728_CR T_2nd.rpl
    Erase : Processing RM-750_011.033_71i92_prd.core.fpsx
    Partitioning....
    Partitioning Ok...
    Erasing....
    Erasing Ok...
    TIME : Erase time : 00:00:01
    Write : Processing RM-750_011.033_71i92_prd.core.fpsx
    CMT: Writing Hash CERT [ADA]
    CMT: Writing Hash CERT [KEYS]
    CMT: Writing Hash CERT [PRIMAPP]
    CMT: Writing Hash CERT [RAP3NAND]
    CMT: Writing Hash CERT [SOS+PMML]
    CMT: Writing Hash CERT [SOS+DECOMP]
    CMT: Writing Hash CERT [PASUBTOC]
    CMT: Writing Hash CERT [PAPUBKEYS]
    CMT: Writing Hash CERT [GENIO_INIT]
    CMT: Writing Hash CERT [SOS*UPDAPP]
    CMT: Writing Hash CERT [SOS*DSP0]
    CMT: Writing Hash CERT [LDSP]
    CMT: Writing Hash CERT [SOS*ISASW]
    CMT: Writing Hash CERT [SOS+CORE]
    CMT: Writing Hash CERT [SOS+ROFS1]
    Total writen 512 blocks
    TIME : Write time : 00:00:17
    MCU Write done
    ADL: Request programm status
    NAND status : 00000000 / 00000000 / 00000000
    Erase : Processing RM-750_011.033_19.01_Vietnam_71i92_prd.rofs2.fpsx
    Erasing....
    Erasing Ok...
    TIME : Erase time : 00:00:00
    Write : Processing RM-750_011.033_19.01_Vietnam_71i92_prd.rofs2.fpsx
    CMT: Writing Hash CERT [SOS+ROFS2]
    Total writen 127 blocks
    TIME : Write time : 00:00:04
    PPM Write done
    ===Flashing [PPM2]===
    Erase : Processing RM-750_011.033_C02.01_SEAP_71i92_prd.rofs3.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing RM-750_011.033_C02.01_SEAP_71i92_prd.rofs3.fpsx
    CMT: Writing Hash CERT [SOS+ROFS3]
    Total writen 2 blocks
    TIME : Write time : 00:00:00
    PPM Write done
    Erase : Processing RM-750_v0.007_APEONLY_prd.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing RM-750_v0.007_APEONLY_prd.fpsx
    CMT: Writing Hash CERT [SOS*ENO]
    Total writen 17 blocks
    CNT Write done
    ===Flashing [APE]===
    Erase : Processing RM-750_011.033_U03.01_71i92.uda.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing RM-750_011.033_U03.01_71i92.uda.fpsx
    Total writen 419 blocks
    TIME : Write time : 00:00:16
    APE Write done
    ADL: Close_Session
    Content: 000300000000000000000000000000
    ADL: Reboot
    Flashing done!
    Total flash time : 00:00:41
    Reboot phone now...
    Connected phone - Nokia N00
    Software Info: V 79u_sr1_11w42 18-10-11 RM-750 (c) Nokia
    IMEI: 359744045594728
    Ape Version: 011.033
    Product code: 059G7B5
    Checking...
    Read Info Done!
    Battery voltage is enough for start
    Done!
    Elapsed: 00:01:10
    Phone found!
    Series 60 Device detected!
    read info... - Ok
    Phone disconected!
    Check files done...
    EM0 ID: 00001040
    EM1 ID: 00001060
    ASIC MODE ID: 00
    FLIC : 005000EC
    Req : XSR 1.6
    Processing ALG ...
    Boot Done!
    ADL: Check mode
    Select ASIC [C900]
    Cert Read done!
    Partitioning....
    Partitioning Ok...
    Erasing....
    Erasing Ok...
    MCU Write done
    Erasing....
    Erasing Ok...
    PPM Write done
    Erasing....
    Erasing Ok...
    PPM Write done
    Erasing....
    Erasing Ok...
    CNT Write done
    Erasing....
    Erasing Ok...
    APE Write done
    ADL: Close_Session
    ADL: Reboot
    Flashing done!
    Reboot phone now...
    Checking...
    Read Info Done!
    Done!
    Elapsed: 00:01:03
    Phone found!
    read info... - Ok
    Check phone mode...
    Phone in Local mode
    Seting Test mode... wait...
    Test mode set
    Set OK!
    Set OK!
    Set OK!
    Set OK!
    Set OK!
    Set OK!
    Elapsed: 00:00:09
    Phone disconected!
    Thành viên mới namphuongkg's Avatar
    Oct 2009
    flash ok N72 by bét
    DLL not found...
    BB5 Easy Service Tool v1.14.1 (c) Infinity-Box Team Ready
    Phone found!
    read info... - Ok
    Read and Check phone data...
    RAP_BOOT: 0D01010103010000
    RAP_PUB: 0D90000E998C0344386C3609796C6B5109E74B63
    CMT_ROOT: 25B977A055BE9B5DEC0C38A2A279C695
    RAP_PAPUB: 660D81A4455F6F7F9B81D5D10F5336B14B50635E
    Live Test Ok!
    CMT Flash ID : 005800EC < UNKNOW [NOT IN BASE]
    SDD Key status : SD Data is Ok
    PA_SimLock Version :
    PA_SL3 phone detected
    Done!
    Reading User code...
    User Code is: Error! Crypted user code!
    Done!
    Done!
    Done!
    Done!
    Done!
    Done!
    Done!
    Reading ASK request file...
    Saved to: C:\Documents and Settings\Microsoft\Desktop\352724048345739.ask
    Done!
    Searching for MMC pwd...
    Generation : [S60]
    Check phone mode...
    Phone in Normal mode
    Test mode set
    SmartPhone algo initialise...
    Setup data...
    StartUp FileSystem...
    Fsrun OK...
    Detect Symbian OS Generation...
    Detected: [Symbian OS 9.3/9.4] Phone!
    Warning! Many [9.3] and [9.4] phones not supported now
    Running : APE_TEST_SERVER,w19_09,(c)NMP
    Password Base not found at all
    Error during read...
    Done!
    Generation : [S60]
    Operating mode is OK, no need change...
    Setup data...
    Fsrun OK...
    Done!
    Phone disconected!
    Phone found!
    read info... - Ok
    Phone disconected!
    Phone found!
    read info... - Ok
    Phone disconected!
    Phone found!
    read info... - Ok
    Phone disconected!
    Phone found!
    read info... - Ok
    Phone disconected!
    Phone found!
    read info... - Ok
    Phone disconected!
    Phone found!
    read info... - Ok
    Phone disconected!
    Phone found!
    read info... - Ok
    Live Test Ok!
    Done!
    MCU : rm530_091.003_prd.core.fpsx
    PPM : rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
    PPM2 : rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
    CNT : rm530_091.003_U007.000_prd.uda.fpsx
    APE : RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx
    Check files done...
    -> SWversion check skipped : Manual mode selected
    Backup CRT308 data...
    CRT308 Backup Created...
    Check communication with phone....
    ADL req restart
    Communication verify done... Preparing...
    Gathering phone info...
    Reboot....
    [BB5 FLASH]: Bootrom Ok!
    ASIC ID: 000000030000022600010007600C192102011104
    EM0 ID: 00001040
    EM1 ID: 00001030
    PUBLIC ID: 0D90000E998C0344386C3609796C6B5109E74B63
    ASIC MODE ID: 00
    ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    Use RAPUv11_2nd.fg Rev : 3.0 Ver : 12.2.0
    FLIC : 005800EC
    Req : XSR 1.6
    Use RAPUv11_XSR17_alg.fg Rev : 3.0 Ver : 12.2.0
    Boot Done!
    TIME : Boot time : 00:00:01
    ADL: Check mode
    Select ASIC [C900]
    IMEI : 352724048345739
    Cert Read done!
    SimLock Data saved...
    SimLock Key saved...
    WMDRM_PD Data saved...
    RPL saved : C:\Documents and Settings\Microsoft\Desktop\BEST infinity ****.VN HUNGPHUTHO\Backup\Cert\352724048345739.rpl
    Erase : Processing rm530_091.003_prd.core.fpsx
    Partitioning....
    Partitioning Ok...
    Erasing....
    Erasing Ok...
    TIME : Erase time : 00:00:02
    Write : Processing rm530_091.003_prd.core.fpsx
    Total writen 451 blocks
    TIME : Write time : 00:00:25
    MCU Write done
    NAND status : 00000001 / 00000001 / 00000000
    Erase : Processing rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing rm530_091.003_44.01_Vietnam_QW_prd.rofs2.fpsx
    Total writen 225 blocks
    TIME : Write time : 00:00:13
    PPM Write done
    Erase : Processing rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing rm530_091.003_C00.01_DEFAULT_prd.rofs3.fpsx
    Total writen 35 blocks
    TIME : Write time : 00:00:02
    PPM Write done
    Erase : Processing rm530_091.003_U007.000_prd.uda.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing rm530_091.003_U007.000_prd.uda.fpsx
    Total writen 55 blocks
    CNT Write done
    Erase : Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx
    Erasing....
    Erasing Ok...
    Write : Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx
    Total writen 12 blocks
    APE Write done
    ADL: Close_Session
    Content: 000300000000010000000100000000
    ADL: Reboot
    Flashing done!
    Total flash time : 00:00:51
    Reboot phone now...
    Connected phone - Nokia E72-1
    Software Info: V ICPR82_11w16.3.11 29-03-12 RM-530 (c) Nokia
    IMEI: 352724048345739
    Ape Version: 091.003
    Product code: 0587055
    Checking...
    Read Info Done!
    FullFactorySet...OK!
    SwUpgradeSet...OK!
    Set phone to Normal mode...
    AfterFlash operations done...
    Done!
    Elapsed: 00:01:25
    Anh nghèo nhưng dòng họ anh đông
    Mỗi người một đồng , anh cũng cưới đc em
  1. BB5 Easy Service Tool (BEST) Nokia Dongle new update
    By TUYHOAGSM™ in forum Infinity Box
    Bài viết cuối: 09-06-2015, 14:08
  2. XIN GIÚP TOOL Nokia Best (BB5 Easy Service Tool Crack) MỚI NHÂT!
    By qthangmobile in forum Tool - Soft và phần mềm free!
    Bài viết cuối: 12-03-2013, 19:49
  3. BB5 Easy Service Tool [BEST] Dongle
    By saigonmobile in forum GIỚI THIỆU THIẾT BỊ - CABLE - GIẢI PHÁP MỚI NHẤT
    Trả lời: 26
    Bài viết cuối: 11-09-2012, 12:49
  4. Trả lời: 5
    Bài viết cuối: 12-01-2012, 20:34
  5. Video hướng dẫn chạy BB5 Easy Service Tool (BEST) Nokia Dongle
    By HoangThong_hotrokythuat5 in forum BB5 Easy Service Tool (BEST) Nokia Dongle
    Bài viết cuối: 27-09-2011, 09:41
