Kết quả 1 tới 8 của 8
    Thành viên tích cực thanhlaman's Avatar
    Mặc định 2700c contacservic
    infor BẰNG hỘp n-b0x
    MCU SW : V 09.97 18-06-10 RM-561 (c) Nokia
    PPM SW : V 09.97 18-06-10 RM-561 (c) Nokia V
    Product : Nokia 2700 classic
    Prd.Code: 0579808
    Bpr.Code: 0577212
    Prod.Sn : DAQ574373
    HW Vers : 1000
    EM VILMA: 16
    EM BETTY: 22
    RFIC Ver: 06540601
    DSP Vers: ICPR72_09w26
    LCD Type: SEIKO
    CAM Prim: NIMMIIIIRRFF00000000_XXXXXX (DCC Mismatch)
    IMEI : 354192-03-122936-9
    SL Serv : SIMLOCK SERVER
    SL Conf : 244-07-00000000000
    SL Prof : 0000000000000000
    SL Count: 00 00
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    Provider: Nokia Test;Finland
    xong nhìn cũng đẹp lắm mà sao vẫn bị
    Detected: V 09.97 18-06-10 RM-561 (c) Nokia
    1ST BOOT : C0,07 [Rm-561] [2.2.0.0]
    CMT ASICID: 000000010000022600010006030C192101033000
    EM 1 ID : 00000296
    EM 2 ID : 00000B22
    CMT PUBID : 1D50020199397F56FE08C677A32E6A9B5BC3B741
    CMT MODE : 00
    CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROMID : 273F6D55DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 00898982-00008A31, Int NU48F512
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
    CMT KSIG0 : 3EA22A1DDA660002E56108DB5072A10F8709443F
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm561__09.97.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00040000-000BFFFF
    CMT NOR Erase Area: 0x000C0000-0013FFFF
    CMT NOR Erase Area: 0x00140000-0137FFFF
    CMT NOR Erase Area: 0x01380000-0151FFFF
    CMT FLASH ERASE OK, Time: 01:30
    Written: 8 Certificate(s)
    CMT FLASH WRITE OK, Time: 02:04
    Chip SECTOR_SIZE: 128k
    Warning, Must be Used 128Kb Sector_Size CNT File
    CONVERSION: Already 128K Paged Source
    IMAGE : rm561__09.97.image_v_blac
    CMT NOR Erase Area: 0x01DC0000-0215FFFF
    CMT NOR Erase Area: 0x02160000-03FBFFFF
    CNT FLASH ERASE OK, Time: 02:50
    CNT FLASH WRITE OK, Time: 01:24
    IMAGE : rm561__09.97.ppm_v
    CMT NOR Erase Area: 0x01520000-01DBFFFF
    PPM FLASH ERASE OK, Time: 00:32
    PPM FLASH WRITE OK, Time: 00:44
    Flashing Completed, Rebooting Mobile
    All Done, Time: 09:29
    AE gặp rồi xin hướng dẩn em làm.xin cảm ơn AE !
    LUÔN LUÔN LẮNG NGHE.LÂU LÂU.......... MỚI HIỂU.cần mua bộ vỏ zin THEO MÁY N86 8M GIÁ CAO.ai có xác liên hệ dùm em .phone:0984323352
    V.I.P hoanglanhpromobile's Avatar
    Jul 2008
    korea
    nbox không nhìn thấy gì đâu bạn . có MX scan cái log lên bạn .
  3. ( hoanglanhpromobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thanhlaman (10-08-2011)
    V.I.P ThanhHai_GSM's Avatar
    cho cái log mxkey hay atf xem cái bạn
  5. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    có mxkey coi cho rõ anh ơi,simlock thì vẫn còn nếu bị mền có mxkey có thế cứu được
  7. ( tlpmobile_tk ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #5
    MÌNH chỉ có jap và nbox thoy ah.có cách nào khác ko bạn?
  9. #6
    Trích Được post bởi thanhlaman Xem bài viết
    như vậy có biết lỗi cũng chẳng giải quyết được gì
    bạn xem anh em quanh đó có mxkey scan thử
    nếu lỗi SIMLOCK_TEST failed! thì liên hệ admin unlock hoặc bạn thay cặp
    còn SECURITY_TEST failed! thì mxkey chiến ok
  10. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    May 2010
    ĐIỆN BIÊN
    thế thì thua rồi anh.nếu bị security_test failed thì 2 cái đó ko nhìn ra đâu
    TRUNG HIẾU MOBILE
  12. ( QUANGTRUNG_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #8
    ồ vậy xin thank AE nhiều để mình đi lên thằng bạn mượn.
    the end
  1. 1661 Bị Contacservic
    By sodepphamhuynh in forum DCT4 - WD2
    Trả lời: 11
    Bài viết cuối: 18-04-2013, 20:53
  2. 5130 bao contacservic
    By limienpack in forum BB5
    Bài viết cuối: 18-01-2013, 09:50
  3. 2690 Contacservic
    By sodepphamhuynh in forum BB5
    Bài viết cuối: 20-11-2011, 17:14
  4. 3110c contacservic
    By moivaonghenenga in forum BB5
    Bài viết cuối: 12-04-2011, 14:45
  5. 7210c contacservic
    By phucmobile123 in forum BB5
    Trả lời: 13
    Bài viết cuối: 16-02-2011, 19:20
