Kết quả 1 tới 10 của 10
    Thành viên tích cực ThùyThương_GSM's Avatar
    May 2011
    Mặc định 2730 contact sevice cần dúp
    em nhận cây 2730 contact sevice em đã flass lại rùi đây là log của em nó ạ
    MXKEY Serial: [FT SCR2000 0] - C0848F40
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.67
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Processing MCU file: rm578__10.47.mcusw
    [BB5,BB5 ALGORITHM] size: 21.65 MB
    Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
    Waiting for USB device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2609CF45
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101023000
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0F90000A66F88D56080C87E27031FF780DE59DCA
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3AAFD673
    Verifying communication to device OK.
    Erase size: 23.25 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.687 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.703 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.579 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.296 s
    CMT FLASH,NOR area [00140000-0155FFFF] erased in 1 min 41.688 s
    CMT FLASH,NOR area [01560000-0175FFFF] erased in 10.203 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 16.875 s
    Processing PPM file: rm578__10.47.ppm_x
    [BB5,BB5 ALGORITHM] size: 6.78 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01760000-01FFFFFF] erased in 43.031 s
    Programming completed in 25.406 s
    Processing CNT file: rm578__10.47_005.image_x_ctv_id_v2_4r0c9
    [BB5,BB5 ALGORITHM] page size: 128 K size: 16.27 MB
    Erase size: 31.75 MB
    CMT FLASH,NOR area [02000000-0245FFFF] erased in 27.672 s
    CMT FLASH,NOR area [02460000-03FBFFFF] erased in 2 min 54.937 s
    Programming completed in 1 min 0.281 s
    Total time for flashing process(boot+erase+write) was 9 min 14.016 s
    Waiting for device boot up ...
    Device connected: nmwcdc\Nokia 2730 classic USB Phonet, PORT_ID: 33864E32
    Phone type: RM-578 (Nokia 2730 classic)
    SW version: V 10.47 27-08-10 RM-578 (c) Nokia
    Imei plain: 35937003485190-1
    Product code: 0585313
    Battery voltage: 3847 mV, current: 64 mA
    Language Pack:
    - not available.
    Detected as PA_SL3 phone.
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 359370034851901
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.453 s
    em đã thử flass lại bằng ATF log cũng đẹp long lanh à
    sư huynh nòa có cao kiến gì chỉ dùm em với.em vẫn chưa làm phần chứng
    V.I.P hanghuu's Avatar
    Cổ tự Nghĩa
    Nếu như phần mềm ok thì bắt đầu tiến hành làm cứng thôi bạn, thử phần nguồn trước.
    hanghuu1982@yahoo.com.vn
    0933.286.489
    V.I.P minh thai's Avatar
    Lỏi cứng , thay trước cặp nguồn đi
    Bến Lức_Long An
    minhthai379
    đóng lại 2 con nguồn trc bạn
    Thành viên mới panda_e's Avatar
    Aug 2011
    sao ko thử thay màn khác, kiểm tra camera đã bạn
    May 2010
    ĐIỆN BIÊN
    pan này chắc do 2 con nguòon rồi bạn làm lại chân ko đc thay con khác nhé.chắc là done
    TRUNG HIẾU MOBILE
    Sep 2008
    làm con nguồn lớn trước đi bạn
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    cú phải từ từ mà làm, làm mền rồi tới cứng, con nào dể thì làm trước chủ yếu là hên xui
    Học Học Nữa Học Mãi
    May 2011
    Hà Nội City
    Cái này cũng hơi kỳ kỳ hay sao ý
    Bạn xóa full nạp lại + Wr pm + unclock + facroryset
    Làm đến đây mà not ok thì hãy áp dụng dao kéo
    Thành viên chính thức bonmobile89's Avatar
    Dec 2010
    Trích Được post bởi ĐẶNG BẢO_GSM™ Xem bài viết
    cái này sl3 mà xóa full thì dễ contacsevic thật sự luôn quá. thay cặp nguồn đi bạn . đã gặp và lắc ky lúc cặp nguồn là done
  1. x3-00 contact sevice nhờ anh em dúp
    By tiendatmobile2010 in forum BB5
    Bài viết cuối: 07-09-2012, 17:34
  2. x2-02 2sim bị contact sevice
    By tuongmobil@_1987 in forum DCT4 - WD2
    Bài viết cuối: 11-05-2012, 20:05
  3. 5130 contace sevice cần dúp
    By ThùyThương_GSM in forum BB5
    Bài viết cuối: 11-05-2012, 16:16
  4. 1110i bị contact sevice
    By AH.TRÍ.ÀH in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 15-12-2009, 08:41
