Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 21
    Thành viên chính thức qazxcdew's Avatar
    Mar 2012
    Exclamation nokia E63 lỗi phần mềm
    máy mở nguồn lên báo=> phone start-up failed..Contact the retailer
    em buscheck được thế này thôi....
    các anh xem giùm em với
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C08727CF
    Using device: HTI, FW ver: 00.50, SN: 01006314
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006
    400C192101031103 [RAPIDO3G ver: 1.13]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 059001099C928D52A479AC85174CCF07C7D228CE
    ASIC MODE ID: 00
    ROOT KEY HASH:
    9A28E119033B91D14D22838C86D0D53C
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D
    FUR: Adding Asic CMT as client OK
    CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
    Selected firmware certificate matched.
    Original Imei: 35150204654340
    Original Product code: 0590148
    Bluetooth ID: 5C57C8245DE0
    SIMLOCK PA identifier:
    [0] PA_SL2
    [1] PA_SL3
    Phone type: RM-437 (Nokia E63)
    SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia
    ApeCoreSw:
    510.21.010
    Imei plain: 35150204654340-1
    Battery voltage: 4526 mV, current: 7 mA
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Phone version(510.21.010) outdated, latest version on server is: 42.0.004
    Imei net: 351502046543401
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    V.I.P DAKLAK-GSM's Avatar
    Aug 2010
    SECURITY_TEST failed! hên xui, thử bằng mxbox , write 1 va 309 , (sl3}
    Thành viên mới Phú SàiGòn-GSM's Avatar
    Dec 2011
    Vấn đề nằm ở đây.Repair SD + Write pm + Super SD lại ok
    Thành viên kỳ cựu KUNEK_GSM™'s Avatar
    Jun 2011
    THIẾU LÂM TỰ
    phu saigon chuẩn khỏi chỉnh làm theo đi bạn
    NGỌC NĂNG SERVICE LÂM HÀ-LÂM ĐỒNG
    CHUYÊN : unlock repair update Firmware tiếng việt ALL MOBILE
    Y/H nangngocdao09@yahoo.com
    SDT:0977+1+7+1+0+3+7
    TK AGRIBANK 5404205189059
    Mar 2012
    dạ vâng... cảm ơn các anh
    hơi khó hiểu 1 chút...
    Write pm,,, có phải là nạp lại pm mới không
    repair SD + Super SD là gì ạ.......
    chỉ em kĩ kĩ với..... xl em không được đi học sửa Dt....nên hơi khó hiểu 1 chút ... mong các anh dậy bả thêm
    Mar 2012
    và em cần dùng box nào ạ.......
    hiện em có 2 hộp..... MX box với Hwk
    Dec 2011
    Mở Mx-box lên,info cho nó thấy máy.Rồi bấm qua bản Service ---> PM bạn sẻ thấy mục Repair SD
    Repair SD => SUPER SD Auth => pm full => lượm lúa
    Mar 2012
    Pm full là nạp pm mới ak
    Mar 2012
    không được anh ak
    yahoo của em .... mr.manh71@yahoo.com
    Mar 2012
    em làm giống như các bước như anh Phú Sài Gòn mà không được.... hay là em làm sai bước nào...
  1. Trả lời: 18
    Bài viết cuối: 24-09-2013, 21:36
  2. cần ae giúp chạy phần mềm n8
    By mobingoc in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-04-2013, 14:06
  3. n72 chạy phần mềm báo lỗi
    By hoanglong33a in forum BB5
    Bài viết cuối: 29-09-2010, 09:48
  4. Xin phần mềm chuyển .avi cho smartmovie
    By nguyen_hiep778 in forum BB5
    Bài viết cuối: 25-03-2010, 11:38
