thay cặp di bạn.ko thì trả khách di nhé
phonenix thì làm sao mà xem lock được hả bác...lấy hộp ra mà chạy...
Báo lỗi không đồng bộ được kìa cho vào tool best hoặc crack gì đó chọn 3 file chạy xem sao rùi quăng log lên ae giúp cho
Đức Tưởng Mobile 0984553860
đây là log em chạy bằng ATF các bác xem hộ rồi giúp em với
ATF Software Version v9.10
ATF Nitro FBUS Flash Started...
Number of Image Files: 5
Forcing Test Mode via BUSCHECK...
Booting Phone via FBUS...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000C35
3 EM_ASIC_ID 02
ID DWORD 0 : 00000C30
4 PUBLIC_ID 12
ID DWORD 0 : 17100016
ID DWORD 1 : 07D10344
ID DWORD 2 : C71A8DFC
ID DWORD 3 : 08D9A49B
ID DWORD 4 : E8831D9C
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 44
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Boot File - Version 012.014.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MessageID : 06
SubBlocks : 06
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0050 -> Type not in database
Revision ID : 0031
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.6
Checksum : 09
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0050 ExtID :0000 RevID :0031
Flash Descriptor
Device ID : 0050
Revision ID : 0000
Size : 20000000 (512 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm File - Version 012.014.00
Algorithm File - Revision 0x0003 (3)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
D172C32473AE199B213465ABB3853246F9631231
Scanning Simlock Applet Type...
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 44
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data : XSR 1.6
Checksum : 09
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0050
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
BB Asic Index : 00
CMT PAPUBKEYS HASH:
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
OK
Reading : MDM_KEYS (CMT)
MDM_KEYS : Empty
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 355490494640467
PRODUCT CODE : 059D159
WLAN ID : A0:71:A9:F5:7F:71
BLUETOOTH ID : A0:71:A9:F4:46:F1
PUBLIC_ID : 1710001607D10344C71A8DFC08D9A49BE8831D9C
PAPUB_KEYS_HASH: D172C32473AE199B213465ABB3853246F9631231
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\355944049464076\3559440494640 76_120320.rpl
Processing Image File :
C:\Program Files\Nokia\Phoenix\Products\RM-596\RM-596_025.008_79.92_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000 Hz
Algorithm Sending Speed : 6500000 Hz
Program Sending Speed : 13000000 Hz
Message Reading Speed : 98000 Hz
Number of Blocks : 514
Entry Point : 0x01FC
Page Format : 128K
Maximum Page Size : 0x00040000
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
Checksum 44
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0031
Block Length : 09
Data : XSR 1.6
Checksum : 09
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0050
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00020000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00140000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 02E60000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 0EA00000
Partition 4
Start Address : 1F000000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 00020014000002D20000000000040000000202E600000BB200 0000000008000000010EA00000106000000000000A00000001 1F0000000040000052
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x4F (79)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x1B (27)
Device Index : 0x00
0 : 00040000-0007FFFF
1 : 000C0000-008BFFFF
2 : 00DC0000-0E97FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x03000000
Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing : RM-596_025.008_79.92_prd.core.fpsx
Total blocks to write : 514
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [D172C32473AE199B213465ABB3853246F9631231]
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:01:08
C:\Program Files\Nokia\Phoenix\Products\RM-596\RM-596_025.008_C09.01_NAM_79.92_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks : 2
Entry Point : 0x00EE
Page Format : 128K
Maximum Page Size : 0x00002800
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 0DA80000-0E97FFFF
Time Taken to Erase : 00:00:00
Processing : RM-596_025.008_C09.01_NAM_79.92_prd.rofs3.fpsx
Total blocks to write : 2
>> CMT Rootkey Hash CERT : SOS+ROFS3
Time Taken to Flash : 00:00:00
C:\Program Files\Nokia\Phoenix\Products\RM-596\RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks : 201
Entry Point : 0x00F4
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 09F40000-0DA7FFFF
Processing : RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx
Total blocks to write : 201
>> CMT Rootkey Hash CERT : SOS+ROFS2
Time Taken to Flash : 00:00:27
C:\Program Files\Nokia\Phoenix\Products\RM-596\RM-596_025.008_U05.01_79.92.uda.fpsx
CMT Type : BB5
Number of Blocks : 357
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 0EA00000-1EFFFFFF
Processing : RM-596_025.008_U05.01_79.92.uda.fpsx
Total blocks to write : 357
Time Taken to Flash : 00:00:52
C:\Program Files\Nokia\Phoenix\Products\RM-596\RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
CMT Type : BB5
Program Sending Speed : 6500000 Hz
Number of Blocks : 18
Page Format : 128K
StartErase_DCT5...
Device Index : 0x00
0 : 008C0000-00DBFFFF
Processing : RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
Total blocks to write : 18
>> CMT Rootkey Hash CERT : SOS*ENO
Time Taken to Flash : 00:00:02
Total Flash Write Time (Flashing Only) : 00:02:31
Total Flashing Time (Booting + Erase + Flashing) : 00:02:32
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000005
Additional Bad : 00000005
Correctable ECC : 00000000
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
các bác vào giúp hộ em với
ae nào đi qua đóng topic lại hộ em với nha . thanks
tiền sử máy bị rớt đất + khách giục kinh quá nên e rả lại khách rồi , cảm ơn các bác đã nhiệt tình giúp đỡ
