Kết quả 11 tới 20 của 21
    Aug 2008
    Trích Được post bởi quocchuong566 Xem bài viết
    bạn vào đây tham khảo thêm đi, câu chỗ này not ok thì câu chỗ khác, http://saigonmobile.vn/forum/showthread.php?t=51138
    Bài viết bị xóa rồi anh Chưởng ơi.Link die
    Anh Minh Mobile
    32-Hoàng Diệu-Eakar-Dak Lak
    Thành viên tích cực tronghienmobile's Avatar
    Apr 2009
    JAF version 1.98.62
    Detected PKEY: 90009699
    Card life counter: 99.99%
    Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.1.17.0
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101012200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0B50010FE5515D511BF3793D23B8663836CB747B
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv2_2nd.fg
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v47
    30-01-07
    RM-180
    (c) Nokia.
    HW version: 5100
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_espresso_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: DQC739246
    Product code: 0531541
    Module code:
    Basic production code: 0530940
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356966014433736
    IMEI spare to net: 3A 65 69 06 41 34 73 03
    IMEI SV to net: 33 65 69 06 41 34 73 03 F6
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
    Setting local mode...
    Reading product code...
    Product Code: 0531541
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
    Checking path: \Products\RM-180\
    No ini files found...
    Done!
    đây là log của máy.mình ngi chắc vẫn do con ic dó rùi để minh câu lại rùi ae giúp nhe.........
    Apr 2009
    bac phatdat ơi con n42oo câu sao vậy nhìn ko rõ lắm
    quocchuong566
    Guest quocchuong566's Avatar
    APE Variant file: NONE, khoan đã bạn, chạy cho nó cái đã
    Apr 2009
    ko dc rùi bác ơi.em cho pin vao mới bật nguồn cái đèn plash phía sau sáng lun.vạy có phải chập chỗ nao ko vậy ....giúp em với
    Apr 2009
    em dem sang hwk thì khi check máy báo như vậy...chữ đó la gì vậy huynh..
    PRODUCT SELECTION MISMATCH
    Hình đính kèm
    Apr 2009
    KHÔNG có ai giúp mình ư!ae ai gặp rui bảo em với
    Apr 2009
    Mặc định anh em xem hộ cài log N70
    máy giơ bị treo trắng màn không lên dc nguồn
    Default
    JAF version 1.98.62
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Done!
    Reading...
    30-01-07
    RM-180
    (c) Nokia.
    HW version: 5100
    PCI version:
    Retu version: 32
    Tahvo version: 53
    Module code:
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    LOCK STATUS:
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done
    còn đây là khi boot băng hwk. nó báo vậy là sao vạy ae giup mjnh với
    Hình đính kèm
    Thành viên tích cực minhthucmobile's Avatar
    Nov 2008
    Sóc Sơn -Hà Nội
    Trích Được post bởi kaka kura Xem bài viết
    mong các huynh cho ý kiến.trươc máy vấn lên nguồn chỉ bị trăng màn thôi.em gơ bỏ con N4200
    làm theo hình này thì giờ máy treo ko lên nguồn nữa mong ae cho y kiến.dóng lại vẫn vậy
    thaycn ic kiếng bên phải là ok.cứ hử xem.mình đã test ok rùi
    yahoo and skype:minhthucmobile
    Thành viên chính thức maingoc186's Avatar
    haiduong city
    Dạ cái này do đại ca chưa trọn đời máy thì phải
    GOODLUCK
    0987219892
  1. N70 trắng màn hình+Treo
    By Lephuocquang_QB in forum BB5
    Trả lời: 18
    Bài viết cuối: 27-06-2010, 14:00
  2. n70 trắng màn hình treo máy
    By truong in forum BB5
    Trả lời: 20
    Bài viết cuối: 30-05-2010, 12:10
  3. n72 trắng màn treo ko tắt được
    By minhtu2326 in forum BB5
    Trả lời: 12
    Bài viết cuối: 16-12-2009, 21:28
  4. n70 trắng treo
    By BIBI&KUTE in forum BB5
    Bài viết cuối: 13-02-2009, 18:52
  5. Trả lời: 6
    Bài viết cuối: 12-09-2007, 10:06
