Kết quả 1 tới 4 của 4
    Thành viên chính thức zinzai420's Avatar
    Mặc định Help FPT B122 Mất nguồn
    Mọi người giúp mình với ạk
    Cây B122 thay mic chả đụng chạm gì tự dưng thay xong mất nguồn, Kim lên 0.2 thả power ra thì rớt xuống về 0
    CPU đóng chuẩn
    Thay dao động
    Flash, format đều không lên nguồn
    Không biết nó hư chỗ nào nữa
    Máy kỷ niẹm nên khách không chịu đền cái khác hoặc bù tiền 1 mực bảo đưa về hiện trạng cũ
    Volcano Updated: 2014-08-08
    Connecting...
    Connection successful,connected state!
    Version: V3.8
    SN:306-692-699
    Port:COM3
    After format or Flash you have to press & hold power button for at least 1.30 mins.
    Note for win7 users :
    Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
    After that the spd drivers will have the ability to be loaded.
    Available Ports:COM3
    Detection initiated, connect the phone and power on it...
    Vcc: null
    Gnd: 1
    RX: 7, TX: 6
    File versiZL75A04_PCB01_GPRS_MT6223P_S00.ZL75J_04A0_V1_ 0_4.BIN
    Searching for passwords...
    Could not find any potential passwords.
    MTK6250/52 choose Boot V3.1108 or v5.1130 and try it.
    Connecting...
    Phone hardware version:8A05
    CPU TYPE:MT6223
    CPUID :E3790C00
    Bootloader download complete.
    ×Ö¿âID:208848FFFFFFFF20884800000000
    Chip Capacity: 0x00800000
    Flash write complete.
    Flash file C:\Users\Tri Mobile\Desktop\fpt-b188 cpu [6223] flash [numonyx]\FPT-B188 CPU [6223] FLASH [NUMONYX].bin has been written.
    Vcc: null
    Gnd: 1
    Analyzing Rx and Tx...
    Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient...
    Failed to detect.
    Pinouts are not fonud!
    Vcc: null
    Gnd: 1
    RX: 7, TX: 6
    File versiZL75A04_PCB01_GPRS_MT6223P_S00.ZL75A_04A0_V1_ 0_8.BIN
    1234[SMS lock]
    Found 1 possible passwords.
    [Privacy Lock]1234
    Connecting...
    CPU TYPE:MT6223
    CPUID :E3790C00
    Flash writing...11%
    Failed to write 1A Command !
    Error 204
    Vcc: null
    Gnd: 1
    RX: 7, TX: 6
    1234[SMS lock]
    [Privacy Lock]1234
    Connecting...
    CPU TYPE:MT6223
    CPUID :E3790C00
    Flash file C:\Users\Tri Mobile\Downloads\b188 no lock\b188 no lock.bin has been written.
    Vcc: null
    Gnd: 1
    RX: 7, TX: 6
    >>Waiting for phone's response, press and hold power on/off >>>>>>Waiting for phone's response, press and hold power on/off >>Waiting for phone's response, press and hold power on/off >>>>>>Waiting for phone's response, press and hold power on/off Waiting for phone's response, press and hold power on/off button...
    Connecting...
    CPU TYPE:MT6223
    CPUID :E3790C00
    Format Address:0-800000
    Format length:800000
    >>Flash formatting complete!
