máy sài bình thường nhưng không có sống viettel,em xóa file nạp lại,nạp pm unlock bằng jaf thì bị contac bỏ qua mxkey thì như vầy.
MXKEY Serial: [FT SCR2000 0] - C084AC37
Using device: POTATO BOX, FW ver: 01.B6
Driver: uhci:hub:FTDIBUS, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00434664A3BDA66
ASIC type: 11
UEM Imei: 35196103966087
Flash Imei: 35196103966087
MasterCode: 2640010601
RPL saved to "C:\mobileEx\3.5\data\backup\35196103966087_133705 0442_BACK.rpl"
Phone Type: RH-99
SW Version: V 6.00 30-09-09 RH-99 (c) NMP
Imei plain: 35196103966087-1
Product Code: 0546861
Cellular System: GSM
ASIC ID: 0x2292, type: 0
Ppm Id: MR
Language Pack:
- not available.
SIMLOCK_DATA corrupted!
[B][I]update splock thì nó báo
Calculating SIMLOCK RPL using security server ...
[UnauthorizedFault] Service closed, please use MXBOX/HTI for better stability !
CHO EM HỎI CÓ CÁCH NÀO KHẮC PHỤC KHÔNG VẬY. THANKS ALL.
A3BDA66
