Kết quả 1 tới 3 của 3
    Thành viên chính thức canhlamdl's Avatar
    Mặc định 1200 sumô bệnh lạ
    xin ý kiến anh em. đã unlook. nhưng vẫn chỉ nhận sin việt tell còn vina thì găpn1 sim vào tới nokia thì tren mô bi thì ko nhận sim luôn
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\99\rh99_05.510
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\99\rh99_05.51mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\99\rh990_nai5.51mr
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\99\rh99_05.510
    Booting phone...
    MCU ID: 0x2292
    Loader version: 04.4F.00 -> Revision: 0007
    Boot size is 0x09D8
    Boot is ready...
    FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x28882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
    Loader size is 0x4C68; Loader chk: ff
    Loader is ready...
    MSID: 844468BB55CAF9821971A112A0
    MSID decoded: 3E4EBAE90043BBD3A8000000
    FAID: C3109FB9EE2042AC5DBAED0E
    Operation took 0 minutes 8 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013AFFFF...
    Erasing area: 013B0000 - 013EFFFF...
    Operation took 1 minutes 5 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 14 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\99\rh99_05.51mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 84F6AFD67352A0479118EEF47E
    MSID decoded: 3E4EBAE90043BBD3A9000000
    FAID: ED9546F7492B4E051596E6C7
    Operation took 0 minutes 7 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0124FFFF...
    Erasing area: 01250000 - 0137FFFF...
    Operation took 0 minutes 20 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\99\rh990_nai5.51mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013AFFFF...
    Operation took 0 minutes 3 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 21 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-99, Software version: 5.51
    IMEI: 352936026376706
    Product Code: 0546885
    Resetting PPC...
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 5.51
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\99\rh99_05.510
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 02
    MCU ID: 0x2292
    Algo is ready...
    Erasing area: 011E0000 - 011FFFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 31876
    Changing mode...
    Done!
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    viết cho nó cái file pm nữa rồi đồng bộ lại
  3. ( VŨ PRO ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    canhlamdl (31-07-2011)
    thank Mod ok rồi
  1. Trả lời: 3
  2. xin sơ đồ câu led 1200
    By LươngTuyên_mobile in forum DCT4 - WD2
    Bài viết cuối: 12-10-2012, 15:00
  3. 1200 rớt nước
    By danbui88 in forum DCT4 - WD2
    Bài viết cuối: 05-03-2010, 21:39
  4. help me log 1200
    By huynhduy in forum DCT4 - WD2
    Bài viết cuối: 04-02-2010, 15:23
  5. 1200 ko den` cua
    By nhattan0812 in forum DCT4 - WD2
    Trả lời: 12
    Bài viết cuối: 15-12-2008, 20:26
