máy bị nguồn , còn dao động, ae xem giúp
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0855D93
Using device: HTI, FW ver: 00.50, SN: 0000B3E9
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: A97E B21A 1BBE 0BE2 7958 6BE4 DBEE 6114
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00CB8E13A3BDA66
ASIC type: 11
UEM Imei: 35290402358401
Flash Imei: B61E93BFA04A6B
Invalid imei checksum !
Processing MCU file: rh99_06.000
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
UEM ID: 00CB8E13:2984DA60
Area [01000000-0100FFFF] erased in 1.094 s
Area [01010000-013AFFFF] erased in 1 min 3.000 s
Area [013B0000-013EFFFF] erased in 4.297 s
Area [017C0000-017EFFFF] erased in 0.016 s
Area [01FC0000-01FEFFFF] erased in 0.015 s
Flash programming ...
Programming completed in 17.594 s
File processed in 1 min 33.172 s
Processing CNT file: rh990_nai6.00mr
[DCT4,DCT4 ALGORITHM] size: 110.55 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 3.235 s
Programming completed in 0.860 s
Content extract fail, continue anyway ...
File processed in 1 min 14.515 s
Processing PPM file: rh99_06.00mr
[DCT4,DCT4 ALGORITHM] size: 1.13 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 1.078 s
Area [01250000-0137FFFF] erased in 20.812 s
Programming completed in 8.860 s
File processed in 37.906 s
Total time for flashing process(boot+erase+write) was 3 min 25.593 s
