Kết quả 1 tới 10 của 11
    Thành viên chính thức THmobile.KH's Avatar
    Jul 2011
    Mặc định 1280 Báo sóng ảo
    Máy có sóng nhưng không nghe gọi được các bác ạ e chạy PM thì nó báo thế này:
    Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-647_512022D5BE2086AE_IMEI.back"
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087ACC6
    Using device: HTI, FW ver: 00.50, SN: 0100987B
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm647_006.510
    Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 33.141 s
    Erasing area 0x00C60000-0x00E5933E ...OK
    Programming completed in 31.922 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.140 s
    Error reading checksum!
    Processing file: rm647_006.51mr
    Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 15.328 s
    Checksum mismatch: Phone calculated 0x0033, software calculated 0x1507
    Processing file: rm6470_nai06.51mr
    Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 4.235 s
    Checksum mismatch: Phone calculated 0x00F0, software calculated 0xA1D0
    Total time for flashing process(boot+erase+write) was 2 min 42.171 s
    Phone type: RM-647
    SW version: V 06.51 13-05-11 RM-647 (c) Nokia
    Imei plain: 35825204504705-2
    Product code: 0593094
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    English,Hindi,Bengali
    Imei net: 35825204504705
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPENghkl/';dfnmdfghl\
    pơe
    poiuy0
    Xin anh em cho ý kiến
    Flash không hết thì thay con Pa là ok 100% Test By Me ^^ !
    Trích Được post bởi NKMobile™ Xem bài viết
    chính xác đóng PA dòng này cũng rễ
    thay pa bác
    Thành viên tích cực vonhubao's Avatar
    Oct 2012
    Quảng Nam
    thay PA cũng k được Bụp nguồn hay U đi
    Làm lại từ đầu......Xin lổi tất cả......Mong được tha thứ..........
    Thành viên mới NHATHUYSAVAN's Avatar
    đóng pa chuân vào b oi khoan hay làm u
    V.I.P ĐƠ_NGUYỄN's Avatar
    bệnh thường gặp ở 1280, thay pa lụm lúa
    Thành viên chính thức hung mobille's Avatar
    dúng vạy có són k gọi dược thì 90%là pa con 10% la cpu
    May 2012
    câu kết luận vẫn là pa chiếm tình nghi cao nhất===>>múc
    Jan 2009
    Hải Phòng
    log này bt, thay pa lụm lúa thôi.
  1. 1280 mât sóng thu
    By yb_pro2012 in forum DCT4 - WD2
    Bài viết cuối: 29-02-2012, 14:40
  2. 1280 mất sóng
    By tuan_mai in forum DCT4 - WD2
    Bài viết cuối: 27-12-2011, 19:07
  3. 1280 mất sóng
    By ducmobile84 in forum DCT4 - WD2
    Bài viết cuối: 27-12-2011, 13:36
  4. 1280 mất sóng
    By xecgayhiep in forum DCT4 - WD2
    Bài viết cuối: 23-12-2011, 16:31
  5. Trả lời: 4
    Bài viết cuối: 17-10-2011, 15:13
