Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 30
    Thành viên tích cực uyếnhà's Avatar
    Oct 2011
    Mặc định 1280 mất sóng
    Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-647_85F4BDDE601F3E4C_IMEI.back"
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08593E1
    Using device: HTI, FW ver: 00.50, SN: 0100BCDF
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm647_006.200
    Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 38.984 s
    Erasing area 0x00C60000-0x00E4D5BE ...OK
    Programming completed in 36.469 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.156 s
    Error reading checksum!
    Processing file: rm647_006.20mr
    Downloading item CUST:hw_b2_rm647_006.20mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 18.578 s
    Checksum mismatch: Phone calculated 0x0033, software calculated 0xB874
    Processing file: rm6470_nai06.20mr
    Downloading item CUST:hw_b2_rm6470_nai06.20mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 5.110 s
    Checksum mismatch: Phone calculated 0x00F0, software calculated 0xD819
    Total time for flashing process(boot+erase+write) was 2 min 57.688 s
    Phone type: RM-647
    SW version: V 06.20 01-12-10 RM-647 (c) Nokia
    Imei plain: 35167205525913-0
    Product code: 0593211
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    English,Hindi,Bengali
    Imei net: 35167205525913
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    log cua em nó đây xin các bác chỉ giúp
    0972648789
    Thành viên tích cực 99999's Avatar
    Dec 2011
    làm cứng đi bạn , lod đẹp
    Oct 2011
    đã làm lai cặp lấy cặp đó thay sang men khác vẫn no ok
    0972648789
    V.I.P LOC_PHAT_ĐAT's Avatar
    Jan 2010
    dò mạng dc ko vậy..thay lọc+pa xem..
    Oct 2011
    đã thay pa và +lọc vẫn ko dc dò mạng ko tìm thấy mạng bác nào có fia pm cua con này ko cho em với ah
    0972648789
    Thành viên chính thức hieupy's Avatar
    thay pa đi bạn
    Jan 2009
    Hải Phòng
    cặp đó sang máy khác not ok thì thay cặp thôi còn chờ gì nữa.
    Oct 2011
    bác nào có fai pm của nó ko cho em sin với ah
    0972648789
    Thành viên mới gialong_mobile's Avatar
    Mar 2012
    bon này chuyên mấy chân u bạn ạ
    gial0ng_m0bile
    Thành viên tích cực QuocDat_mobile's Avatar
    Oct 2011
    Đà Nẵng
    Trích Được post bởi uyenha_1 Xem bài viết
    bạn đẫ làm như vậy rùi thì làm gì cho mất công nhiều thời gian bạn .thay cặp khác vào xem nó có hiệu quả hơn không.bệnh muôn thủa của 1280
    zalo: 0905 990078
    Tel;0905990078.0979233646
  1. 1280 mât sóng thu
    By yb_pro2012 in forum DCT4 - WD2
    Bài viết cuối: 29-02-2012, 14:40
  2. 1280 mất sóng
    By tuan_mai in forum DCT4 - WD2
    Bài viết cuối: 27-12-2011, 19:07
  3. 1280 mất sóng
    By ducmobile84 in forum DCT4 - WD2
    Bài viết cuối: 27-12-2011, 13:36
  4. 1280 mất sóng
    By xecgayhiep in forum DCT4 - WD2
    Bài viết cuối: 23-12-2011, 16:31
  5. Trả lời: 4
    Bài viết cuối: 17-10-2011, 15:13
