Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-647_85F4BDDE601F3E4C_IMEI.back"
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08593E1
Using device: HTI, FW ver: 00.50, SN: 0100BCDF
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm647_006.200
Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 38.984 s
Erasing area 0x00C60000-0x00E4D5BE ...OK
Programming completed in 36.469 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.156 s
Error reading checksum!
Processing file: rm647_006.20mr
Downloading item CUST:hw_b2_rm647_006.20mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003288BE ...OK
Programming completed in 18.578 s
Checksum mismatch: Phone calculated 0x0033, software calculated 0xB874
Processing file: rm6470_nai06.20mr
Downloading item CUST:hw_b2_rm6470_nai06.20mr.fls, num block: 1, size: 305.83 KB
Erasing area 0x00EB0000-0x00EFBA3E ...OK
Programming completed in 5.110 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0xD819
Total time for flashing process(boot+erase+write) was 2 min 57.688 s
Phone type: RM-647
SW version: V 06.20 01-12-10 RM-647 (c) Nokia
Imei plain: 35167205525913-0
Product code: 0593211
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
English,Hindi,Bengali
Imei net: 35167205525913
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
log cua em nó đây xin các bác chỉ giúp
