mấy anh coi dùm em lỗi này là lỗi gi.máy mất nguồn đưa vào máy cấp nguồn kim đồng hồ lên chút rồi đứng im luôn
Boot...
TIKU BT2
te_2nd.fia
te_amd.fia
ASIC ID: 1052
Configuration Info (9F):
Number of Flashes: 4
00000000: Samsung, 00EC 22F8 0000 0011, 10
02000000: Samsung, 00EC 0039 0000 0000, 9
04000000: NotUsed, 0000 0100 0000 0000, 0
06000000: NotUsed, 0000 0100 0000 0000, 0
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
UEM IMEI is: 35503800802612
============= Set FBus mode for info =============
VBat is 4.00V
Vpp pin has 1.86V, Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
VPP is DISABLED.
Processing File: rh12_28_11004.440
Boot...
ASIC ID: 1052
TIKU BT2
te_2nd.fia
te_amd.fia
848E5CD78389FA0696CEA3C96E70
Erase[13.81 MB]...
erasing region [00000000 to 0000FFFF]
erasing region [00010000 to 007FFFFF]
erasing region [00800000 to 0093FFFF]
erasing region [00B60000 to 00FEFFFF]
in 134.61s
Flash[8.77 MB]...in 50.52s
* * Processed file in 196.95 seconds
Processing File: rh12_28_11004.44.ucp_v
Low level format...fail
Boot...
ASIC ID: 1052
TIKU BT2
te_2nd.fia
te_amd.fia
849E5778812A917A9F5218E41754
ExtBUSC: 18F0 9FE5 18F0 9FE5 18F0 9FE5 18F0 9FE5
Erase[2.00 MB]...
erasing region [00940000 to 00B3FFFF]
in 19.50s
Flash[1.57 MB]...in 9.08s
* * Processed file in 72.55 seconds
Extract content...fail
Processing File: rh12_28_11004.44v
Boot...
ASIC ID: 1052
TIKU BT2
te_2nd.fia
te_amd.fia
847C316B6AB139571AAF1E8E4DF6
Erase[2.00 MB]...
in 19.58s
Flash[1.67 MB]...in 9.66s
* * Processed file in 41.08 seconds
* * * Phone flashing done in 6:15 minutes
Post Flash serial tunning of phone....
Pooling mode for full factory set...
Phone not responding, try to set manually!
