Kết quả 1 tới 10 của 11
    Thành viên chính thức ty nguyen's Avatar
    Arrow 1200 bệnh lạ đây
    1200 rớt nước,sấy khô xái được2 tháng mất nguồn,em thay cpu+flash+uem.bỏ vô jaf nạp sw 5.80,ok hết,chưa có imei????????????,info ok,chuyển chế độ normal,máy lên nguồn.nhưng khi kẹp nguồn thì không lên,dao động khoảng 0.3v rồi rớt xuống,em đã thay con uem khác,tình trạng vẫn y như vậy.anh nào gặp rồi chỉ giáo em với.cám ơn các anh trước nha.
    MCU ID: 0x2292
    FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 2A7E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.80
    14-11-08
    RH-99
    (c) NMP
    HW version:
    PCI version:
    UEM version: 1314
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: WIN:MYKS:04
    ST7507
    PPM version: V 5.80
    14-11-08
    RH-99
    (c) NMP
    MR
    ADSP SW version: V 5.80\n14-11-08\nRH-99\n(c) NMP\nmr
    Production serial number:
    Product code:
    Module code:
    Basic production code:
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: ???????????????
    IMEI spare to net: FA FF FF FF FF FF FF 0F
    IMEI SV to net: F3 FF FF FF FF FF FF 6F F8
    Master Code: 5013663745
    Failed reading simlock data...
    Phone type: RH-99, Software version: 5.80, Language Pack: MR
    User code: ÿ#
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
    Checking path: \Products\RH-99\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ij
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ij
    Done!
    V.I.P thinhtam's Avatar
    Nov 2008
    xem lại bsi chưa.
    Thành viên tích cực vantuan_huemobile's Avatar
    Jun 2008
    vùng cao nam đông _huế
    nếu như bạn nói thì bị lổi main rồi mình cũng bị một cây như thế sang ic qua main khác thì ok đó
  4. ( vantuan_huemobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    quangtrung1987 (27-10-2009)
    Thành viên kỳ cựu thanhnammobile07's Avatar
    hơ hơ !!! tội nghiệp cây máy.
    bạn thay hết đồ củ nó vô rồi kiểm tra làm đường BSI làm cho kỹ sẽ được thôi bạn à.
    không ai quan tâm_nhưng tôi quan tâm
    thanks all
    Nov 2008
    thay con giao động ở gấn uem đi bạn..
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    kiểm tra lại đường bsi cho nó đi anh.
  8. #7
    Thành viên mới hoangthinh090's Avatar
    kiểm tra lại đường bsi rùi làm lại cpu
    cứu người...người cứu...lại cứu người
  9. #8
    Jan 2009
    thay con giao động cho nó rồi làm gì thì làm, con 1200 cũng chuối lắm
  10. ( Hà Linh Mobile™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    baomobile8855 (25-10-2009)
  11. #9
    Thành viên mới chauteo's Avatar
    có thế bị mất IMEI đó bạn nên gởi file đồng bộ lại thử xem
  12. #10
    em thay giao động rồi,cũng y vậy thôi,banh imei cũng phãi lên nguồn chứ,lên một chút rồi tắt.đằng này nó nín thin hà.kiểm tra bsi là sao?gỡ bõ các con tụ trên đó hả?kẹp nguồn không lên mà.gắn vào bõ jaf thì lên testmode,chuyển qua chế độ nomal là lên liền.
  1. Trả lời: 3
  2. xin sơ đồ câu led 1200
    By LươngTuyên_mobile in forum DCT4 - WD2
    Bài viết cuối: 12-10-2012, 15:00
  3. 1200 mất đèn màn hình và bàn phím
    By thanhnhungmobile in forum DCT4 - WD2
    Bài viết cuối: 31-05-2012, 13:29
  4. 1200 can so đồ mic
    By ngocminhhungyen in forum DCT4 - WD2
    Bài viết cuối: 09-07-2010, 16:10
  5. 1200 ko den` cua
    By nhattan0812 in forum DCT4 - WD2
    Trả lời: 12
    Bài viết cuối: 15-12-2008, 20:26
