nhờ anh em xem hộ em cái log
đầu tiên máy bị mã bảo vệ em INPHO không đc. thế là em chạy thì nó bị thế này ( và giờ nó đang bị cotacsevit ) nhờ anh em giúp đỡ
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.230
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader size is 0x5548; Loader chk: d9
Loader is ready...
MSID: 8457BBD3283EAB6D69C970523F
MSID decoded: 3E4EBAE900420896A8000000
FAID: 07ACEA0640EFCF719C1C4926
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 0 minutes 36 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 19 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.23mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84D56621906FDFBDE0989547B3
MSID decoded: 3E4EBAE900420896A9000000
FAID: 0A34241F91AF9DBF5B9847DC
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 11 seconds...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 5 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
