em có cây 1200 rớt nước mất nguồn , đã vệ sinh kĩ máy có nguồn nhưng báo contact sẻvice em đã làm lại nguồn + u nhưng k hết chạy ct máy báo lỗi ae xem xem
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.91
27-03-09
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: WIN:MYKS:04
ST7507
PPM version: r$ÓÊ…ÖPñħØKDW³Šå–0EfY‘„Ç ˜<kjw
ªË¶
ADSP SW version: no NAI version
Production serial number: IGR250012
Product code: 0574502
Module code: 0203402
Basic production code: 0571402
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356858029601953
IMEI spare to net: 3A 65 58 08 92 06 91 05
IMEI SV to net: 33 65 58 08 92 06 91 75 F0
Master Code: 7344311721
Failed reading simlock data...
Phone type: RH-99, Software version: 5.91, Language Pack: ªË¶
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0574502
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
No ini files found...
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.910
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.91mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.91mr
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.910
Booting phone...
Phone didn't answer to request flash routine!
Causes:
1. UPP damaged -> replace UPP
MCU ID: 0xEEEE
This MCU ID is not supported in chosen flash file...
Error booting phone...
Failed! Aborting!
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84F6AE7DA9FCBBB10DAA0B656F
MSID decoded: 3E4EBAE9009312A5A8000000
FAID: 6C22526CDF43CF1BFCB2AF16
Operation took 0 minutes 13 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 19 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.91mr
Booting phone...
Causes:
MCU ID: 0xEEEE
Failed! Aborting!
FAILED
dùm cai loock của nó em cảm ơn
