Em Có Cây 1200 Bị Contacsevit .!
Máy Đang Dùng Bình Thường Thì Bị Không Rơi Nước .
Ban Đầu Nhổ Con Tụ Kép Ra Thì Hết Dùng Bình Thường Nhưng Hôm Sau Bỏ Ra Tắt Nguồn Bật Lên Lại Bịn .
Làm ic Nguồn Rùi Mà Hông Được Cho Vào Chạy Lại Phần Mềm Cũng Not ok Xin Các ACE Chỉ Giáo
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.71
12-09-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.71
12-09-08
RH-99
(c) NMP
MR
ADSP SW version: V 5.71\n12-09-08\nRH-99\n(c) NMP\nmr
Production serial number: ILE274013
Product code: 0546885
Module code: 0203402
Basic production code: 0544418
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352934026766182
IMEI spare to net: 3A 25 39 04 62 67 16 08
IMEI SV to net: 33 25 39 04 62 67 16 68 F7
Master Code: 7332620640
Phone type: RH-99, Software version: 5.71, Language Pack: MR
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0546885
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Checking path: \Products\RH-99\
No ini files found...
Done!
Phone Type:
MCU Flash file: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh99_05.800
Phone Type:
PPM Flash file: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh99_05.80mr
Phone Type:
CNT Flash file: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh990_nai5.80mr
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84D2748A91CC908FE040968C7B
MSID decoded: 3E4EBAE9005AA2CCA9000000
FAID: 7C732CF3468890A0504FA28E
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 9 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
Restarting MCU...
PPM: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh99_05.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84C68A77676CF5A9375AE35BCC
MSID decoded: 3E4EBAE9005AA2CCA8000000
FAID: 2C34F741642ED36841D49102
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 22 seconds...
Writing...
Operation took 0 minutes 8 seconds...
Restarting MCU...
CNT: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh990_nai5.80mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 8457EB6DE5257DF81703C1C52D
MSID decoded: 3E4EBAE9005AA2CCAA000000
FAID: 75DF2FB5A03918710E1D81AA
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013AFFFF...
Operation took 0 minutes 3 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 21 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 5.80
IMEI: 352934026766182
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 7 seconds...
Done!
Done!
Unlocking...
ASIC: b
SW version: 5.80
Selected flash file: C:\Documents and Settings\Do Tat Tiep\Desktop\New Folder\1200_RH-99_v5.80\RH-99\rh99_05.800
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Erasing area: 011E0000 - 011FFFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 178
Done!
